Old 24th April 2017, 12:26   #7246
Thanked: 78,904 Times
Re: Maruti S-Cross : Official Review
Maruti Suzuki is likely to offer the 1.0L boosterjet variant of the S Cross after the relaese of the face-lift as phase 2. A CVT offer is also in the plan.
Maruti will continue to sell the S-cross in India with the same 1.3- and 1.6-litre diesel engines, but once the facelift is here, the updated 111hp(?) Boosterjet engine is also likely to join the line-up. There’s likely to be a CVT automatic in the mix as well.
Link
volkman10 is offline   (4) Thanks
Old 24th April 2017, 14:20   #7247
Thanked: 3,365 Times
Originally Posted by Dr.Naren View Post
I was going through the UK brochure and some interesting observations!!
1. 1.6 DDIS 2WD weighs 1275 Kg in India and 1290 Kg in UK. There is only 15 Kg difference and it should be due to extra airbags and other gizmos. Full points to Maruti for not compromising on the body shell.
2. 1.6 DDIS has lesser CO2 emissions than 1.0 booster jet and 1.4 booster jet engines. Who said bigger diesel engines are always more polluting?
3. 0-62 mph (UK) :
1.6 DDIS : 12 sec
1.0 Booster jet : 11 sec
1.4 Booster jet : 10.2 sec
Note : Open the image for better resolution
Interesting that the 1.0 Booster Jet still manages to give a respectable 11.0 sec 0 -100 kmph time in the S-Cross which is over 200kgs heavier than the Baleno.
Drive on,
Shibu.
shibujp is offline
Old 24th April 2017, 15:11   #7248
Dr.Naren's Avatar
Thanked: 17,278 Times
As per Suzuki UK Baleno brochure, Even Baleno 1.0 booster jet does 0-100 in 11 seconds. Power output is same in both S-Cross and Baleno. But the final gear ratio is different.
Dr.Naren is offline
Old 24th April 2017, 15:46   #7249
srishiva's Avatar
Thanked: 2,260 Times
Diesels are usually better only in CO2 emissions ! Not to mention the other real bad parts in exhaust.
srishiva is offline   (1) Thanks
Old 24th April 2017, 17:48   #7250
Is there any resource that gives out in gear acceleration timings for these cars? That is where the real story lies.
Drive on,
Shibu.
shibujp is offline
Old 24th April 2017, 20:28   #7251
supremeBaleno's Avatar
Thanked: 2,917 Times
Originally Posted by shankar.balan
But then, in India, with the limited 4WD buyers and the typical "Kitna Deti Hai" mentality, I don't see Suzuki bringing this spec into this country in the near future.
Agree that AWD & 4WD might not have takers here. My wish was for them to only bring the frontal facelift here - to make this car look more butch & thus appeal to a wider audience, who today reject it because the front looks too tame.
supremeBaleno is offline
Old 24th April 2017, 21:33   #7252
Thanked: 542 Times
Question to owners: Does the 1.3 Zeta variant (that does not get auto-dimming IRVMs) get at least manual or mechanical day-night IRVM, or is it the basic one without night setting lever/switch?
In case it doesn't come with manual day-night IRVM, is it possible to get either an auto-dimming or regular day/night IRVM fitted as an accessory?
chncar is offline
Old 24th April 2017, 21:36   #7253
Sree73's Avatar
Thanked: 1,012 Times
Zeta comes with manual switch for dimming IRVM
Sree73 is offline   (2) Thanks
Old 24th April 2017, 21:37   #7254
Aiel's Avatar
Thanked: 599 Times
The 1.3 Zeta comes with a manual/mechanical IRVM.
It is also possible to get the auto-dimming IRVM as an accessory. The cost is 13K (approximately), if I recall.
Aiel is offline   (2) Thanks
Old 24th April 2017, 21:42   #7255
Thanked: 209 Times
Could you please attach a photo of the switch? I never found it in mine and always thought it is a basic one.
jaganpec2002 is offline   (1) Thanks
Old 24th April 2017, 21:56   #7256
Leoshashi's Avatar
Thanked: 43,541 Times
I was quoted Rs. 7k for the same at a Maruti dealership.
Leoshashi is offline   (6) Thanks
Old 24th April 2017, 21:58   #7257
Thanked: 21,452 Times
IIRC it costs Rs 6990 when I saw it at NEXA recently.
13K is too much.
a4anurag is offline   (3) Thanks
Old 24th April 2017, 22:32   #7258
Sree73's Avatar
Had a freak accident on my S-Cross yesterday. I'm on a vacation visit in Kerala. Had parked the vehicle on the road side. While parking I had noticed a tree stump in the front (1-1.5m ahead). Returned to the vehicle after around 3 hrs and got inside.
While seated, this stump was not visible and the front side was pretty clean. Without realising took the vehicle forward and in this process the radiator / Intercooler / AC condenser got damaged. The engine coolant drained out in a couple of minutes. It was not possible to drive as the coolant was drained out in a few minutes.
Called for a flatbed recovery vehicle and took the car to BRD Karupadanna Service centre (Near Irinjalakuda). All the 3 items needs replacement. Expected to get the car back on 26th April.
Will update later about the details.
Maruti S-Cross : Official Review-psx_20170424_220836.jpg
Maruti S-Cross : Official Review-psx_20170424_220948.jpg
Sree73 is offline
Old 24th April 2017, 22:44   #7259
Thanked: 1,327 Times
Unable to find a pic from office network but if you have owned any Maruti vehicle earlier like Wagon R or Swift Vxi or lower, you should be aware of the little plastic thingy at the center of the IRVM which you can push and pull to enable day-night mode. In fact it is common across manufacturers so you would have surely encountered this on one or the other car without auto dimming IRVM.
abhinav.s is offline   (1) Thanks
Old 24th April 2017, 23:51   #7260
sunejarahul's Avatar
Thanked: 275 Times
It's right on top of your IRVM. The swift has it below the IRVM, it is basically a tilt function. You can achieve the same result by manually tilting the mirror vertically up/down. Using this push switch is the most inconvenient, it should have been present on the bottom as usual.
sunejarahul is offline   (1) Thanks
