Old 27th July 2021, 11:55   #1786
the_joker's Avatar
Thanked: 222 Times
Re: Hyderabad to Bangalore : Route Queries
I'm traveling from Bangalore to Hyderabad and back this week.
I read in the past couple of pages of this thread that Telangana e-pass is no longer required. Is it the same for Andhra Pradesh also?
Is there a night curfew in Andhra Pradesh or is it done away with now? I may need to adjust my departure time if needed.
Thank you..
the_joker is offline
Old 27th July 2021, 13:33   #1787
ashis89's Avatar
Thanked: 12,223 Times
Thank you..
No e-pass required for Telangana or Andhra Pradesh. They had night curfew from 10PM onwards but inter-state movement won't be affected. Carry a local address proof (hotel booking/friend's or relative's address) of Hyderabad, just in case someone asks for proof of travel.
ashis89 is offline   (2) Thanks
Old 27th July 2021, 13:46   #1788
Thanked: 233 Times
Thank you..
Did Hyderabad to Bangalore and back on 24th & 26th July respectively. Started around 5am both times and was not asked for any RT-PCR test report or vaccination certificate anywhere. Since it was early morning drive, I'm not sure of any night curfews in any state.
Aside, the roads are good as always with trucks taking out the fun. Some major overpass works in Kurnool and everything else same as it is. There is some serious opportunity if anyone wants to open a big restaurant somewhere in between. 550 kms of nothingness is too boring even for the cruise control.
brownkaiser is offline   (2) Thanks
Old 2nd August 2021, 12:11   #1789
Thanked: 45 Times
Thank you @FlashMustang for your wonderful and timely tips. I could check them a few minutes before my start and it really helped me plan for the stops on the way. Just came back and could not thank earlier as I was not carrying my laptop.
Overall the journey was good except for many slow moving trucks enroute and the Hyderabad city traffic while coming back. I would strongly advise carrying packed food, as you can call it my fate, all the wonderful options I gathered from here were closed. Thankfully, it was red bull that came to rescue.
roadlover1705 is offline   (2) Thanks
Old 4th August 2021, 02:18   #1790
SanjuInGgn's Avatar
Thanked: 73 Times
I drove from Bangalore to Hyderabad on Saturday. Started from Bellandur around 6:30AM and reached Serilingampally by 2PM (includes 3-4 small breaks of 5-10 mins each)
I'm planning to drive down from BLR to HYD for the weekend but the 10+ hour time prediction by Google Maps is making me rethink. Curious to know if 7 to 8 hours is the norm? I find Google Maps predictions to be fairly close for the most part and hence the questions.
I typically drive in the 120-140km/hr range if roads are good.
SanjuInGgn is offline
Old 4th August 2021, 06:38   #1791
hserus's Avatar
Thanked: 9,335 Times
The default maps prediction is calculated for max 100 kmph speeds. If you do faster speeds the Maps time remaining will adjust itself as you drive, stop for lunch etc. 8 hours is quite doable.
hserus is offline   (1) Thanks
Old 4th August 2021, 08:17   #1792
ashis89's Avatar
Yes, if you are starting early from Bangalore (or Hyderabad while returning) and manage to beat the peak traffic, it would take 7-8 hrs point to point. Similar or even lesser cruising speeds should be fine.
On the way to Hyderabad, three sections on the highway cost you time - exiting Bangalore outskirts, Kurnool city and finally, last 60 kms before you hit Hyderabad ORR.
Old 4th August 2021, 16:11   #1793
samkat1's Avatar
Thanked: 92 Times
For travel from Miyapur (HYD) to Marathahalli (BLR) & vice-a-versa, I've clocked between 8 hours and 11.5 hours in various trips. Travel time remains pretty much the same. What makes a difference is the number of breaks that we take.
PS: I usually cruise on 80-100 kmph.
samkat1 is offline   (2) Thanks
Old 4th August 2021, 16:26   #1794
Thanked: 31 Times
Planning to do BLR-HYD-BLR drive on the Aug 13-15 weekend. No e-pass is required in Telangana. Do we need a negative RT-PCR report on the way back (or is it only for flight passengers)?
Anyone who's travelled post Aug 1 from HYD-BLR, were you asked for this report?
maheshsm12 is offline
Old 5th August 2021, 10:21   #1795
mtnrajdeep's Avatar
Thanked: 409 Times
No RT-PCR required for flight passengers too (my mother travelled by flight on 01-Aug-2021) - but I am reading some reports that Bangalore police is going to enforce RT-PCR requirement for entry to Bangalore.
mtnrajdeep is offline
Old 5th August 2021, 10:48   #1796
hserus's Avatar
RTPCR is currently required in Karnataka only for travellers from Kerala and Maharashtra
Old 9th August 2021, 18:56   #1797
smsrini's Avatar
Thanked: 443 Times
Are there any curfew timings for entering Hyderabad ?
Do they need RTPCR ? if i have a double vax certificate is it enough ?
Travelling on the 10th Aug.
thanks
Srinivas
smsrini is offline
Old 10th August 2021, 12:32   #1798
mtnrajdeep's Avatar
Thanked: 409 Times
thanks
Srinivas
There is no lockdown or curfew in Hyderabad. No RT-PCR requirements too for Telangana.
mtnrajdeep is offline   (2) Thanks
Old 10th August 2021, 17:32   #1799
jkrishnakj's Avatar
Thanked: 4,615 Times
Bangalore to Hyd is the easiest these days, when it comes to restrictions et all.
No such requirements, no barricades, no checkpoints - essentially, no drama. It’s just like the old times.
I did a round trip 2 weeks back. Very pleasant.
jkrishnakj is offline   (3) Thanks
Old 23rd August 2021, 10:34   #1800
androdev's Avatar
Thanked: 25,298 Times
Telangana state is going nuts with automated speed cameras. Rs 1035 per violation. City limits, ORR, HYD-BLR highways, etc. are all covered. How do I know? ;-)
I have few questions to 'experienced' folks:
1. Hypothetically, if I travel on ORR the whole day above speed limit, will I accumulate a ticket for each and every camera-location or do they have any logic to ignore if already fined once based on distance/time since last violation?
2. Is there anyway to get an instant notification that I have been fined, even for out of state cars? It looks like the only way to know about fines is to visit their portal and check your registration number. Most people won't even know that they have been fined.
3. Is there any cumulative damage for repeated violations? Would it be a clean slate if I pay off existing tickets.
4. Does the severity of violation/ticket change based on the speed? If I remember right, in Bangalore, they charge different amounts for 80-100 and 100+ speeds when the speed limit is 80kmph.
5. Is there any interest/penalty for late payment of such tickets?
6. On the photo uploaded on the portal, I see GPS coordinates as 16.090771,77.895134. Does it mean the camera is permanently fixed at this location and I can potentially make a note to drive slow at this spot to avoid tickets in the future?
Hyderabad to Bangalore : Route Queries-ticket.png
Thanks!
androdev is offline   (1) Thanks
