Originally Posted by fine69 Is there a substitute to using Torque wrench? I need to fit some heavy duty hook eye anchor bolts on the walls and realized that they require specific torque to be applied to these bolts. I don't really want to buy a torque wrench costing 10k so looking for an alternative here.
While we are on the topic, I have never seen any of the carpenters using torque wrench when using anchor bolts, they tighten them with all their might and the bolt tends to hang on to stuff pretty well too. In fact I have a pull-up bar hanging from anchor bolts which the carpenter had tightened using a regular adjustable spanner, no torque measurement considered at all. | Quote:
Originally Posted by ajitkommini Is there some place that offers high value tools like this on rent? The local hardware guy near my place has a collection of large drills, demolition hammers etc. displayed outside the store that he gives out on a rental basis. There might be some similar service for precision tools as well. | Quote:
Originally Posted by Aroy How much torque is specified? Normally tightening fully (10-12mm dia bolt) with 300mm long arm of the wrench does the job for most masonry jobs. Torque ratings are given for critical fastener. Just enough to tighten them but not enough to break the bolt. In general the "just enough" stretches the bolt a tiny bit, so it is not to be used a second time | Quote:
Originally Posted by Jeroen You can make your own Torque wrench, have a look: http://www.engineeringtoolbox.com/to...le-d_1909.html
Not sure why the carpenters don’t use them, maybe they havent got them, or they don’t know what specific torque needs to be applied? Or they haven’t got a clue why you would need to torque. But then again, I have seen a number of houses and apartments collapsing in India over the last year. So somebody got something wrong or forgot something!
Jeroen | Quote:
Originally Posted by Thad E Ginathom I never heard of torque wrenches being used outside of mechanics!
Perhaps, though, where lives may depend on a bolt (eg lift-shaft fittings or building safety-harness points) it might be necessary for the manufacturers to state such a thing.
My bet is that they want to prevent overtightening, as many installers would go for this "all their might" approach. I see plumbers doing the same thing with screw-thread steel pipes. | Quote:
Originally Posted by fine69 http://www.boun.in/Anchore7ba.html?T...d%29%20Anchors
Are you saying that if I normally tighten it enough, it should be ok. I don't mean to use it ever again, just put it and forget it.
Or would using too much of strength defeat the purpose of the anchor bolt?
EDIT: My objective is to put these bolts (in the link) in the wall so that they don't come out even if I try to pull them out with all my strength. I will be using them for a workout. | Quote:
Originally Posted by Aroy See the posts above, which give a method of measuring the torque and in your case getting the right torque for tightening the bolt.
If it is a 10mm or 12mm bolt, tightening with all your strength will be fine (it is difficult to break the bolt), for thinner bolt you may break it by over tightening.
In my experience, anchor bolts in the wall need tightening enough to prevent their working loose with vibration, but you have to be sure that the hole in the wall is not only the proper diameter, but the wall material should be solid brick/concrete, not plaster or material which will crumble. All our geysers (20L and 30L) models are secured using 8mm bolts, tightened till they are firmly embedded.
Anchor bolts expand as you tighten them, so once fully tightened you can not pull them out, unless the wall material crumbles. | Quote:
Originally Posted by Jeroen Torque wrenches are (or should be) used in all sorts of application and or industries. Other then car mechanics, marine/naval engineers uses them on a vast array of different equipement, they are used in the aviation industry.
They are used in the telecom industry, certain (fiber) connectors need to be torque-ed properly.
People who put up the likes of ferris wheels and such use them.
Lots of bits and pieces on many industrial plants require torque wrenches. E.g. think of pressure vessels.
We often think of torque wrenches as putting a lot of torque on a bolt/nut. But it’s about getting the exact correct amount. The torque that is needed to properly install a simple fiber connector is very small. A six year old has enough strength. But the trick is to get it exact right so the fiber doesn’t deform, but it’s still tight enough to ensure a water tight seal.
Watch makers use torque wrenches! The list is endless.
If you want some of the basics behind torque, have a look at this:
Way past the DIY stage, but here is the sort of stuff we used on the big marine Diesels etc. This (hydraulic) tool actually stretches the bolt without twisting (torquing) it. Very precise loading of the bolts!
Enjoy, Jeroen | Quote:
Originally Posted by Thad E Ginathom Yes, like I said: mechanics. I never limited that to cars! But no matter: nice examples
The last torque wrench I came close to was in the hands of my dentist: he was getting the torque on an implant right. |
Can you guys give pointers on good Torque Wrenches available here but not too expensive? I could find mostly Taparia and Ambika? Which of these would you recommend?
I need something that covers the range starting from 7 NM up to 300 NM. I think this will need to be broken into two wrenches (14-68 & 70-340)?
Oh and continuing on that topic.
Do some of you guys think these old beam or deflection type wrenches still have their uses?
Might I say they are much cheaper and could be something very usefull for a DIYer. http://www.aliexpress.com/item/whole...6-6d6f8cab5db7
I admit on this particular chinese one the markings are not so very precise but for a DIYer who does oil pan nuts, drain nuts, wheel lugs, head cover bolts...is something like this close enough?
Reason: Back to back posts merged. Please edit your previous post within the 30 minute window to add more contents to it. Thanks!
