Sorry to revive a dead thread, but there were some unanswered questions which I will answer to my best knowledge.
Originally Posted by Samurai
Ah, you are right. Let's wait for a current owner to respond. I don't see anything else on the bumper.
You are right. there is no place for the towhook at the rear and Ford has not given us an option to get one installed either.
Originally Posted by SS-Traveller The unprotected oil cooler and its pipe (marked in green) hanging down at the edge of the bumper may be a matter of concern when off-roading, |
can something be done here? probably custom made plates and installed to give the necessary protection while offroad?
Originally Posted by Mpower I take it this is one of few vehicles with factory fitted GPS? Any good? |
The GPS is from Map My India and I am pretty satisfied with it, though there are times when I could have done better without it. Lets face it, It will be ages before India get the realtime GPS system up and running.
funny incident was when i was driving the endeavour from bangalore to Goa and the GPS was showing that the car (Red Arrow mark, yes no option to have a car on the screen) was somewhere over a lake where I was driving right next to it. sorry no pics.
Originally Posted by tanwaramit
I think I had read that the 4WD is shift-on-fly, however in this case, you needed to shift to N in order to move to 2H, which means either it is not shift on the fly OR there was an issue with this vehicle !
Where is the lock for Spare tyre cover ? We are aware of the demands in the chor market for them. |
you need to shift to N only when changing From or To 4L.
The lock is placed below the spare tyre cover.
Originally Posted by Samurai 4L -> 4H : Shift-on-fly
But the caveat of doing 4L -> 4H in neutral voids the above statement. |
you need to get the car into N before shifting, otherwise the 4L light does not go off. have seen this in my endeavour.
Originally Posted by Samurai No, it is not. The Endeavour 4WD system is exactly like Safari, it even has the rear LSD like Safari. But the oral info I got on hub unlocking and shift-on-fly is little inconsistent.
I am hoping that a current owner will jump in and answer some of these questions. |
No need to drive back whatever meters (generally 2 times car length) i guess this is already answered in posts above.
Originally Posted by MNandy I have checked the FE with both 30psi and 32psi...no difference at all. 7.5 and 7.6kmpl to be precise in NCR. The ride quality changes perceptibly though with 30psi. I think only with a fully laden vehicle will have to use 32psi. |
Thats the FE you will get no matter what the tire pressure is. make sure you fill in at fuel stations that are recommended or tested for quality.
quality of fuel plays a huge role in this.
Originally Posted by siddheshb Here's an update. I was driving on pretty rough roads yesterday, and my co-driver placed her purse in the middle of the seats... unintentionally slotting the rotary switch from 2H into 4H and into 4L. Of course, neither was I in neutral nor had I stopped, so what happened is that the 4L and O/D Off indicators started flashing on my dash. I immediately pulled over, went into neutral, slotted the SUV back into 2H, and we were off. Net net, no harm as far as I could see - but I really wish the rotary switch wasn't that easy to operate! |
you need to be pretty carefull in this. the switch can be broken easily.
my driver has done this many times while cleaning slotting the car into 4wd mode and now the switch is broken.
broken in the sense that the car now shifts to 4wd mode (4H) even when the switch is pointing to 2wd. the switch needs to be imported and will take a week to come. till then the only way to drive the endeavour is to keep the switch pressed for sometime till the light goes off.
luckily its still under warranty.
