Old 19th February 2010, 17:03   #406
Lucas_2007's Avatar
Thanked: 12 Times
Well, for everyone's reference i am posting pics here. it is a maruti800 door switch fitted under the bonnet. From the picture you can easily guess the location of the arm/disarm switch :-). Hope this will be helpful.
The FIAT 1100/Premier Padmini Technical Information thread-1.jpg
The FIAT 1100/Premier Padmini Technical Information thread-2.jpg
The FIAT 1100/Premier Padmini Technical Information thread-3.jpg
Lucas_2007 is offline
Old 19th February 2010, 17:18   #407
funkykar's Avatar
Thanked: 6,887 Times
Cool stuff this! I would want to give it a try to my cars some time just for the heck of it
funkykar is offline
Old 19th February 2010, 20:20   #408
samsag12's Avatar
Thanked: 263 Times
Thanks LUCAS 2007 for the pics. Appreciate that. BTW wasn't able to understand the 3rd pic. The pic is of what area ?
samsag12 is offline
Old 19th February 2010, 21:11   #409
Lucas_2007's Avatar
Thanked: 12 Times
Watch the pic upside down.then you'll understand.
Old 19th February 2010, 22:24   #410
samsag12's Avatar
Thanked: 263 Times
OK got it. Its the pic of button. Also in view is the exhaust pipe.
BTW what is the switch fitted inside called? I know it is a toggle switch but what do the spare part dealers call it.
samsag12 is offline
Old 20th February 2010, 12:50   #411
planet_rocker's Avatar
Thanked: 426 Times
i need the black hub caps of the Padmini - i cannot source it in Kolkata. Can someone send it to me and I will pay in advance. My car's refurbishing work in progress: http://www.team-bhp.com/forum/indiancarpicture-527.html
http://www.team-bhp.com/forum/890976-post36.html
http://www.team-bhp.com/forum/951832-post49.html
Here is the pic of the hub cap i am talking about (Pic: Mr. Dhabhar's LHD FIAT)
The FIAT 1100/Premier Padmini Technical Information thread-bd.jpg
Second Issue:
The mechanic says that if i want to fix the Closed Type Radiator (with overflow tank), I need to buy a Thermostat and a new Fan to work with the new radiator. Can i use the original fan along with the Closed Type Radiator? Also do i need a thermostat? I guess he is talking about an electric fan with motor!
A full pictorial help will be great.
Thanks in advance.
Last edited by Technocrat : 22nd February 2010 at 16:28. Reason: added additional links on request, thanks
planet_rocker is offline
Old 20th February 2010, 19:54   #412
adheesh's Avatar
Thanked: 54 Times
Originally Posted by planet_rocker View Post
i need the black hub caps of the Padmini - i cannot source it in Kolkata. Can someone send it to me and I will pay in advance. My car's refurbishing work in progress: 1988 Premier Padmini W.I.P. - planet_rocker's Photo Gallery - Team-BHP
Attachment 291671
Second Issue:
Thanks in advance.
Incorrect. The S1 sealed type radiator with Degassing tank can also be used with the mechanical fan but vice versa is not true since the shroud of the electrical fan would not fit on the standard radiator. I would suggest you to use the original standard radiator currently present in your car with the filler end removed (Just heat it with a welding gun, the solder will simply melt) and sealed with connections for degassing tank which can be salvaged from a S1.
Hope this helps.
PS: I am attaching a photograph supporting the above from Mr. Dhabhars LHD. This car has the radiator from the AC Deluxe Premier Padmini
Adheesh Parelkar
The FIAT 1100/Premier Padmini Technical Information thread-dsc02432.jpg
adheesh is offline
Old 21st February 2010, 00:10   #413
Mehul1100's Avatar
It is better to stick to original radiator of padmini rather than going for alteration for sealed type radiator. My S1 had problem with faulty thermostat switch. I tried M800 switch, but it fail to perform good in a Padmini.
So I altered as below.
The FIAT 1100/Premier Padmini Technical Information thread-image0417.jpg
The FIAT 1100/Premier Padmini Technical Information thread-image057.jpg
The FIAT 1100/Premier Padmini Technical Information thread-image0415.jpg
The FIAT 1100/Premier Padmini Technical Information thread-image041.jpg
Mehul1100 is offline
Old 21st February 2010, 10:48   #414
samsag12's Avatar
Thanked: 263 Times
Can anybody tell how (and what is the correct way of adjusting) is the clock in this meter adjusted.
The FIAT 1100/Premier Padmini Technical Information thread-image0047.jpg
samsag12 is offline
Old 21st February 2010, 11:38   #415
pradipk's Avatar
Thanked: 57 Times
Press the button located on lower left corner using bolpoint pen or something like that, it will move minute hand forward. that's the only way to set the time. AFAIK, there's no way you can rotate anti clock wise.
Pradip.
pradipk is offline
Old 21st February 2010, 11:39   #416
funkykar's Avatar
Wow! Interesting question. I too look forward to the answer for this. My S1 nor the NE clock works. Till date, i have seen only 1 car with clock working. Have seen atleast 20-30 where the clock doesnt work.
funkykar is offline
Old 21st February 2010, 12:41   #417
samsag12's Avatar
Thanked: 263 Times
Hey Karthik you are scaring me. I bought this meter just for the sake of an internal clock. If it doesn't works, probably will have a run to the scrapyard again.
samsag12 is offline
Old 21st February 2010, 13:05   #418
samsag12's Avatar
Thanked: 263 Times
One more thing which i want to know is that, the clock on the meter(the pic is posted above) can be adjusted when it is connected to the car or can the time be adjusted without powering the clock.
samsag12 is offline
Old 21st February 2010, 23:41   #419
Thanked: 132 Times
can anyone post pics of the engine bay of the s1 engine from multiple angles. i have never seen an s1 engine so i want to know the changes that were made.
mehul sir posted pics of his car which he says is an s1 ...but his car seems to hav a fan run off the engine while the s1 from what i hear has an electric fan
mycarhasablower is offline
Old 22nd February 2010, 08:34   #420
ilangop's Avatar
Thanked: 928 Times
You can, but thats a little tricky. You can connect battery (-ve) to one of the screws you see in the backside of the meter. Power each pin one after the other and see on which pin the clock works. But the best and harmless way to do that is to open the 6 or 8 nuts on the rear side and remove the clock from the instrument cluster. The +ve and -vew leads for the clock are clearly visible. Now you can peacefully check the clock.
ilangop is offline
