Old 22nd February 2008, 15:31   #76
DerAlte's Avatar
Thanked: 2,920 Times
... driving under the influence of alchohol is not advisable and is against the law (and a damn good law if you ask me).
Costs you 5K if caught, apart from the nuisance that your vehicle will be impounded. More if you happen to drive on the pavement or into a lamp-post or tree.
DerAlte is offline
Old 22nd February 2008, 15:32   #77
navin's Avatar
Thanked: 9,965 Times
I thought it was a mandatory jail term.
navin is offline
Old 22nd February 2008, 15:56   #78
anarchist's Avatar
I've got Focal Access 165A 6.5" Component Speaker paid 21k for my set they sound amazing you should check these out, these are rated the best...
anarchist is offline
Old 22nd February 2008, 16:41   #79
DerAlte's Avatar
Overnight only, unless there has been "culpable homicide NAM"! Longer than that and they would have more problems than if the culprit was left on the road.
Where did you get them from? Have you compared them with others like Hertz High-energy, Illusion Lucent/Carbon, Infinity Kappa etc. which are in the same price / performance band? Your objective review would be much appreciated.
DerAlte is offline
Old 22nd February 2008, 16:53   #80
gunbir's Avatar
Thanked: 33 Times
21K for Access is a bit pricey considering they retail for around $300. Nevertheless, a nice product and sounds good if paired with the right equipment.
Enjoy!
gunbir is offline
Old 25th February 2008, 13:40   #81
Best component speaker
Hi Bro,
I stay in a village in interios of Vasai (a distant suburb of mumbai) in my duplex house in a village away from the concrete near vasai railway satation. We have 3 virgin beaches close by & a couple of small hills where we chill out, (we r the law in vasai hehe)
Anyways bro, which are the best speakers which i can use with my exisitng sub & will it have any effect on the battery when the car is running (draining weak etc) & which will be a good HU budget no constraint
cheers nilesh
1. There are quite a few good pairs of speakers. Some of which would cost you 2-3 installments of your EMI (if you have one). :-) do fix a budget even if the ICE Gurus believe it is their calling to ensure that you dont stick to it. If you are upgrading from Pioneer then listen to Hertz, Illusion, JBL/Infinity, Blaupunkt (not GT series), etc..
2. The bass a good sub provides cannot be replicated by most coax (6" or 6x9") speakers.
3. You battery is not designed to be used this way. Buy a pair of Jumper cables to start your car with another car. BTW driving under the influence of alchohol is not advisable and is against the law (and a damn good law if you ask me).
ngonsalves is offline
Old 25th February 2008, 13:43   #82
Bro,
Vasai mein woh takleef nahi hai.cheers:
Old 26th February 2008, 13:53   #83
Component speaker system
I had been to the Blau dealer yest at Bandra who has suggested that I can use my old Blau 250 GTA AMP with blau gtc 662 & blau thx 693 speakers without my pioneer amp being shifted to my new getz & i will get good enough bass.
any feedback on the same
cheers
nilesh
Originally Posted by ngonsalves View Post
Bro,
Old 26th February 2008, 14:41   #84
Bass&Trouble's Avatar
Thanked: 137 Times
2 channel amp to drive 2 pairs of dissimilar speakers?
Bass&Trouble is offline
Old 26th February 2008, 15:36   #85
navin's Avatar
The effect on the battery depends on (a) how loud you play / how many watts you use (b) how long you play and (c) the condition of the battery.
In any case we do NOT recommend using any ICE system that includes amplifiers when the car's engine is not running.
BTW what is the model of your existing sub. What would you consider to be a fair budget. There are people here youhave spent 5000 and others who have spent only 500,000.
few amps can handle a 2 ohm load.
navin is offline
Old 26th February 2008, 16:08   #86
Thanked: 268 Times
Does running components without any amps cause damage to the HU in the long run ?
mithun is offline
Old 26th February 2008, 16:20   #87
nishantgandhi's Avatar
Thanked: 156 Times
Just a refinement on the above query - Does running components without any amps when the engine is not running cause damage to the HU in the long run? Or any other damage (like Navinji mentioned, battery drainage?)
nishantgandhi is offline
Old 26th February 2008, 17:46   #88
Thanked: 137 Times
All current generation Class AB amps can handle 2 ohm loads.
No
No damage to HU. Battery health will depend upon how often/ how long you play the system without the engine running.
Old 28th February 2008, 11:42   #89
Best Componet Speaker
I have deciced to do in for Blau THX 693 6"9 280 W speakers for my rear & use my existing blau amp GTA 250 without a woofer in my hyundai getz.
Pls. suggest the below
which alpine HU (range below 12k) will pair the best for the above.
which comp (range below 7 k) will give best sound & bass effect.
pls. suggest if the Blau THX 693 6"9 280 W speakers are good or i can look at other alternatives (range below 7-8 k)
thanks
Old 29th February 2008, 19:57   #90
Best Component Speaker
Hi Bro,
Pls. advice on below.
cheers
nilesh
thanks
