Old 2nd June 2011, 11:52   #7741
shajufx's Avatar
Thanked: 832 Times
Re: The DSLR Thread
Actually, you do not need to keep long exposure NR on.....
Mine is kept back to OFF mode.
Originally Posted by VW2010 View Post
.....The camera just takes twice the time to finish that picture. Hate it
Not twice but 5 times delay when you are on RAW mode, thats what made me put it back to OFF. In fact I could not find any difference in RAW on both modes. Does it really make a difference ? I am curious.
shajufx is offline
Old 2nd June 2011, 11:59   #7742
Thanked: 323,269 Times
Re: The DSLR Thread
Originally Posted by rajb3125 View Post
I do use multi quote but if i made a post and want to reply to something else (lets say after 5mins), I have no choice left but to make another post. Or is there a way to edit posts, not yet approved ?
No, there is no way to edit unapproved posts. And sorry, but we cannot allow back to back posts either. I would recommend gathering all your thoughts in one shot and putting them into a post.
We are going off-topic here, so if you want to continue the discussion, feel free to use the contact us form and write in. But again, strictly no back to back posts, whatever the reason.
GTO is offline
Old 2nd June 2011, 12:05   #7743
tsk1979's Avatar
Thanked: 23,495 Times
Re: The DSLR Thread
On very long exposure in not so low temperatures, it will result in lower number of "hot pixels", i.e blue/green/red dots which randomly appear on the picture.
tsk1979 is offline
Old 2nd June 2011, 16:52   #7744
Thanked: 482 Times
Re: The DSLR Thread
A few user shots from the 50mm f1/.8G (showing bokeh and sharpness wide open)
New Nikon 50mm f1.8 "G" lens - Page 15 - Digital Photographer Philippines
WindRide is offline
Old 2nd June 2011, 19:52   #7745
Thanked: 3,038 Times
Re: The DSLR Thread
I cannot figure out where the figure of five come from. In normal case the camera takes a shot, and then immediately takes a dark frame of the same duration. As far as I know the camera always shoots in RAW mode, and processes the output it to JPEG or TIFF if required.
The dark frame is used to detect thermal and shot noise which increases in long exposures. By the way the lower the temparature the lower the noise and longer the exposures possible for the same noise figure.
Aroy is offline
Old 2nd June 2011, 20:25   #7746
shajufx's Avatar
Thanked: 832 Times
Re: The DSLR Thread
....where the figure of five come from......
I dont know how to explain that, 5 is not meant in the literal sens but used as a 'longer' delay.
Ok here is something about it straight from the User Manual. D700 Page-277:
"Job nr" will blink in the shutter speed/aperture displays for a period of time approximately equal to the current shutter speed.
That means a 20 second exposure with NR ON can take upto 20 seconds processing time, thats normal. Again, this delay might also depend on the Memory Card grade which is yet to be checked. I have 3 different types, Ultra II, Ultra compact and Extreme.
shajufx is offline
Old 3rd June 2011, 10:34   #7747
Re: The DSLR Thread
So it boils down to twice the time taken, that is normal behaviour for "long exposures".
Tips for long exposures
What is the best technique for long-exposure photography in good light? - Photography - Stack Exchange
Here is an interesting link where the "clean exposure" times for the Medium Format, P45+ is given (this is one of the worlds best camera backs for long exposures!). It ranges from 8 minutes at 41 degrees to 17 hours at -25 degrees!
Tech Info :: Capture Integration – Medium Format Digital Back Sales & Rental and Other Professional Photographic Equipment
It is further down the page.
Aroy is offline
Old 3rd June 2011, 10:43   #7748
Re: The DSLR Thread
Are the following prices of DSLR's attractive enough to call a "good buy"
Canon 1100D with 18-55 IS Lens INR 23,790
Canon 500D with 18-55 IS lens INR 27,990
Nikon D3000 with 18-55 VR lens INR 22,490
Nikon D3100 with 18-55 VR lens INR 28,300
Expert opinions would be helpful to decide
Jidousha is offline
Old 3rd June 2011, 11:07   #7749
Thanked: 66 Times
Re: The DSLR Thread
Originally Posted by Jidousha View Post
Are the following prices of DSLR's attractive enough to call a "good buy"....
Absolutely attractive!!! If I had to chose 'only from the above four' and has no inclination to a particular brand, I would buy the 500D.
kkr2k2 is offline   (1) Thanks
Old 3rd June 2011, 12:01   #7750
anujmishra's Avatar
Thanked: 529 Times
Re: The DSLR Thread
Can we(you DSLR Owner) display here nice pics taken only from basic 18-55 lens. This will give new DSLR owner a boost and would try to do some new thing with this lens. It takes a while when new DSLR owner upgrades to other lenses. All composition should be from 18-55 lens with various camera settings.
anujmishra is offline
Old 3rd June 2011, 12:16   #7751
mukeshgoel's Avatar
Thanked: 2,412 Times
Re: The DSLR Thread
I want to buy a 50mm 1.8 for D7000.
So, should I buy 50mm 1.8D since D7000 has built in motor. Or, 1.8G is more advanced besides having motor for entry level bodies?
mukeshgoel is offline
Old 3rd June 2011, 12:37   #7752
neoonwheels's Avatar
Thanked: 1,883 Times
Re: The DSLR Thread
Wow, Canon lists 1100D as 29XXX, even the stores sell it for 28-29K. I got it for 27250/- last week (B&W) and this was the lowest I heard. If you dont mind, could you please share where you got these prices? Also, could you please let me know the price for 50mm 1.8 if your sources sell it?
neoonwheels is offline
Old 3rd June 2011, 12:52   #7753
Re: The DSLR Thread
canon prices are from the deals of the week from Ebay.
You can check Ebay for the 50mm 1.8 as well.
Jidousha is offline
Old 3rd June 2011, 12:55   #7754
tsk1979's Avatar
Re: The DSLR Thread
MY entire ladakh 2009 trip was shot almost exclusively by 18-55 on a 350D.
Check this out
Favorites - Tanveer Singh (tanveer)'s Photos
An example
Yes, the 1.8D is good enough for you. 1.8G will cost significantly more
Dark frame does not measure anything. Its just like taking a pic with lens cap on, and then subtracting this image from your original image.
tsk1979 is offline   (2) Thanks
Old 3rd June 2011, 14:01   #7755
ampere's Avatar
Thanked: 13,656 Times
Re: The DSLR Thread
Any user experiences with Canon 17-55 IS f2.8?
Was plan to upgrade kit lens. Main reasons :
- Good wide range (apart from 10-22)
- Faster lens.
- Also makes a good walk through
Hesitation: Is it worth the price? As I hear that 90% of the snaps can be managed by kit lens (18-55 itself). Main interests : Landscape and Low lights.
Camera is 550D
ampere is offline
