Old 26th April 2015, 13:04   #5146
PatienceWins's Avatar
Thanked: 983 Times
Re: The Home Appliance thread
Originally Posted by PatienceWins View Post
The motor of IFB washing machine seems to have conked again, we got the same symptom of house main switch dripping while switching the machine. The washing machine is used rarely. The AMC expired 2 months back, the person did not turn up to renew the AMC even after reminding him. Anyway, I have raised a complaint for the service advisor to look at it.
The issue was with the sensor, alhamdulillah. We renewed the warranty for one more year. The machine is running well even after 12 years.
PatienceWins is offline
Old 27th April 2015, 13:31   #5147
S_U_N's Avatar
Thanked: 418 Times
What washing powder is recommended for top-loading LG washing machines?
We are using Surf+Tide mixed and last few months, it seems the washing quality has gone down substantially. The white shirts seem to come out 60-70% clean.
We did a tub clean and I manually cleaned the tub inside with a moist cloth.
Water levels are generally kept high and soap quantity is also decent, I suppose.
S_U_N is offline
Old 27th April 2015, 15:26   #5148
sgiitk's Avatar
Thanked: 4,809 Times
even in a top loader you need near zero foam. We have been on front loaders since 1980 or so where foam is lethal. We use the front loading version of Henko.
sgiitk is offline
Old 27th April 2015, 15:29   #5149
saket77's Avatar
Thanked: 14,737 Times
Sir, I have been using normal Henko for at least 5-6 years on my 16 year old IFB with no problems. I just make sure that I do not use too much detergent and not to generate too much foam. Would like to ask that why exactly foaming is bad for front loaders? Your insight will be valuable.
Regards.
saket77 is offline
Old 27th April 2015, 15:42   #5150
sgiitk's Avatar
In a front loader washing action is totally by tumbling. So if there is foam then the splash action is damped out.
sgiitk is offline
Old 27th April 2015, 16:06   #5151
Gannu_1's Avatar
Thanked: 20,681 Times
Got a nice plastic cover for my Bosch front loader 5.5 kg from Amazon India (link). Perfect fit, zips at the front corners and holes at the rear for routing the power cable, water inlet and discharge.
A pigeon has found her new home at the corner and she has already laid 2 eggs as on yesterday.
PS: No worries with the mounts at the front. There are no vibrations on the machine during the spin cycles. Had no other option unfortunately.
Gannu_1 is offline
Old 27th April 2015, 20:49   #5152
diyguy's Avatar
Thanked: 588 Times
Is it ok to cover the machine completely? How will heat dissipate? I had one for my ifb but since then have changed three machines and never bought a cover for any.
diyguy is offline
Old 27th April 2015, 21:17   #5153
Thad E Ginathom's Avatar
Thanked: 29,987 Times
I keep mine covered, but it lives outside and would become filthy otherwise. Also... the cat lives on top of it
Thad E Ginathom is offline
Old 27th April 2015, 22:20   #5154
khoj's Avatar
Thanked: 1,288 Times
LG recommends Arielmatic, at least LG says so, it comes in front loading and top loading variants.
khoj is offline
Old 5th May 2015, 00:24   #5155
Thanked: 271 Times
Looking to buy a chimney to replace the exhaust fan at home. What are all the points I need to consider before buying a chimney. Expecting valuable advice as always. TIA
smrtdvl is offline
Old 5th May 2015, 08:06   #5156
sgiitk's Avatar
The boss says that the Henko is just the box, the stuff is Arielmatic Front Loader!
sgiitk is offline
Old 5th May 2015, 08:31   #5157
Sheel's Avatar
Thanked: 15,118 Times
And I have been using Surf Excelmatic front load for more than a year.
http://www.rapidration.com/surf-exce...kg-carton.html
I see lots of froth. Don't the automatics take detergent as per requirement?
Only in Surf, I do see different packs available for top/front load. Else, most dish out just one variety. At least, this is what I recall seeing at Big Bazaar/Spencers. IIRC Ariel too has just one pack for both.
Sheel is offline
Old 5th May 2015, 12:39   #5158
sgiitk's Avatar
And I have been using Surf Excelmatic front load for more than a year. .
We use that also. Excellent product, but sometimes the availability is suspect. So keep two brands in your folio!
sgiitk is offline
Old 5th May 2015, 13:49   #5159
Gannu_1's Avatar
Couldn't find any specific instructions/warning w.r.t. not covering the appliance anywhere in the user manual of the Bosch machine I own so went ahead. We have a 15 year old IFB front loader doing duty at my hometown which is covered when not in use - no issues so far. *touchwood*
I covered the machine because it was located in the balcony open to the atmosphere. No direct sunlight but rainwater ingress.
Gannu_1 is offline
Old 5th May 2015, 15:49   #5160
fine69's Avatar
Thanked: 1,468 Times
Would a dishwasher make sense for me?
A good quality dishwasher would cost between 30-40k. I would end up paying the same amount to the maid over the next 3-4 years. Not to mention that it'd use some amount of electricity also.
Then there's the possibility that it might conk-off within the 3-5 years I try to break even with it. What exactly am I missing here?
PS: We are a family of two, going to be three by next year.
fine69 is offline
