Old 7th September 2013, 14:04   #646
ampere's Avatar
Thanked: 13,612 Times
re: On Wi-Fi & Routers
Originally Posted by carboy View Post
Yeah - that's what I am looking for.
I do agree. But I think for streaming media you may need a stronger network. For example a drive being accessed on the router and casted through the home network; a superior .1N network instead of .B/.G or a dual band router for example.
ampere is offline
Old 7th September 2013, 14:06   #647
Thanked: 1,911 Times
I don't understand. I am not looking to create a home network. I am not planning to have a media file server at home used by different comps at home. All I am looking for is to have a wifi router and have a laptop and a tablet use it for their Internet connectivity.
However, I still don't understand why any modem will not be able to handle media files.
carboy is offline
Old 7th September 2013, 14:16   #648
ampere's Avatar
Then what you say is true. You can just use any router. Just need to confirm if your router can reach all parts of the house (has enough strength)
Why I meant it this way was, for example for streaming a full HD content the Wifi BW may/may-not be enough. You may want to check those aspects, in case you are looking at these direction. If not then yes this does not apply.
ampere is offline
Old 7th September 2013, 14:25   #649
How do I figure out which router has how much strength - is this based on some parameter in technical specs?
Is BW mentioned in technical specs of the router - I know very little about routers.
carboy is offline
Old 7th September 2013, 14:32   #650
ampere's Avatar
I myself dont know. Its difficult. May be as you said, you can try the one you have. Once in a corner of the house, if your signal is week, try changing the location of the modem/router. If not, you may need to for alternatives.
(basic but works. I also did the same way!)
For Example look at this spec:
http://www.linksys.com/en-apac/products/gateways/X3500
It indicates a BW of 750MBps for wireless transfer.
Supprt for .N std of Wifi compared for .B .G makes a lot of difference.
And the other part is support for a MIMO antenna (Multiple Input/Output)
ampere is offline
Old 7th September 2013, 15:10   #651
mroptimist's Avatar
Thanked: 371 Times
Why can the BSNL modem not do media? For a modem any file should be stream of bytes or is it different?
What has modem to do with media streaming? Modem connects you with internet not networking.
So usage requirements should be considered while choosing a wifi router/modem?
I meant simultaneously how many devices will connect this router, whether you need MAC filtering and do you need dual band or single band router? Plus there are many other questions also like number of years of warranty (Linksys notoriously provides only one year warranty).
Thank You.
mroptimist is offline
Old 7th September 2013, 17:18   #652
I asked because of this post - http://www.team-bhp.com/forum/gadget...ml#post3230731
Mostly 2 devices at max - a laptop and a tablet.
I doubt it - I am not sure why I would need it? I assume this is a security feature, right?
again, what's the need for a dual band?
I see 900 & 1200 Rs wifi modems on flipkart
Are these good enough for me?
http://www.flipkart.com/netgear-wire...md6354qsufyzwf
http://www.flipkart.com/d-link-dir-6...mdbemyeh7t8rkt (what is a cloud router anyway)
http://www.flipkart.com/netgear-jnr1...mdekmq26udbjdt
My 5 year old Huwei model just about covered a 900 sq ft 2 BHK - but signals at the furthest corners weren't strong, I think. My current flat is 800 sq ft 2 BHK, I would like it cover the flat comfortably.
carboy is offline
Old 8th September 2013, 00:15   #653
scorpion_blore's Avatar
Thanked: 530 Times
Have a look at Asus RT N-13 (URL: http://www.flipkart.com/asus-rt-n13u...b-9ad4114e860a). It's an all-rounder and has a lot of positive reviews.
scorpion_blore is offline
Old 8th September 2013, 07:54   #654
I don't need an allrounder - all I need is one which acts as Modem + Wifi router and serves 2 rooms.
carboy is offline
Old 15th September 2013, 20:32   #655
Thanked: 957 Times
Settled on the TP-Link WDR4300 after reading a lot of reviews. Snapdeal - Rs. 5,850.
vinu_h is offline
Old 16th September 2013, 18:47   #656
naveenroy's Avatar
Thanked: 1,318 Times
Guys, want some advise.
I watch Netflix on both my computer and by connecting an ethernet cable from the router to my Bluray player - which has a Netflix app and I can play it from there.
Now, the problem is that it streams without any problems on the computer. When I enable HD, it takes around 5 minutes to move to a HD stream - but it keeps playing in SD. But the problem is in the Bluray player. When I play (even the same movie) on the player, it plays it fine. But then it stops after 2 minutes, buffers. Then plays. Then buffers. I actually didn't have this problem when I watched the first HD movie on Netflix. It played it then without any problems!
Could it be a problem with the router? It is a Netgear WiFi router - WGR614. The problem surely isn't with my internet connection - ACT Broadband with a 15mbps line. No issues there.
naveenroy is offline
Old 16th September 2013, 19:34   #657
Thanked: 21 Times
Are you watching Netflix in India? If yes then how did you manage it on the Blu-ray player?
Diamond_dawg is offline
Old 16th September 2013, 19:40   #658
naveenroy's Avatar
Ah, knew this question was coming. PM'ed you.
Old 16th September 2013, 19:44   #659
Thanked: 21 Times
Haha well thank you!
Old 16th September 2013, 21:07   #660
Raj1008's Avatar
Thanked: 66 Times
Probably the Ethernet is not a gig switch so transfer speed is suffering. You may need to go in to tweak qos. May or may not work. Next option is to buy a gig switch and install it before the router. Or get a wireless dongle for the blu ray
Raj1008 is offline
