Old 15th October 2013, 12:23   #16576
Thanked: 72 Times
Originally Posted by h@r$h@l View Post
FK has an offer "Get Extra 15% Cashback on purchases above Rs. 10,000 on Standard Chartered Cards."
I would say you look around for a Standard Chartered Card if you dont have one and get it from FK.
Have been trying to get hold of someone with Standard Chartered card, but no luck so far. :( As you said, it's a great deal !
neerajpv87 is offline
Old 15th October 2013, 17:18   #16577
h@r$h@l's Avatar
Thanked: 743 Times
Guys,
I have a funny question. and i am sure some of you here might also agree with me. I am looking for an app / solution which would let me block / disable whatsapp / FB etc when i want to.
The issue is, WA is running 24/7 in background and during working hours i want to stay away from it. due to the double tick thing ppl know the msgs have been delivered and i am being ignorant and not replying. So if there is an app which lets me disable certain set of apps it would be awesome.
So say during working hrs i disable WA just like i sign off my personal messengers, i wont have to deal with unwanted messages and sign back in after 6PM and deal with them all
I know the simplest way would be to delete WA account. Trust me, i am on the verge of doing that if i don't find a solution to this.
h@r$h@l is offline
Old 15th October 2013, 17:48   #16578
phamilyman's Avatar
Thanked: 4,673 Times
Guys,
Tasker or a firewall solution?
phamilyman is offline
Old 15th October 2013, 18:24   #16579
bluevolt's Avatar
Thanked: 3,477 Times
Guys,
You can force close the app and tap on when you want to retrieve messages. Other than that what you can do is to read messages after turning off the data connection and close the app and restart the app, with this way your time stamp will not change and you will be able to read messages also.
I have fooled many of my friends with this trick for more than one month during a vacation
Other than above two ways, there is no other solution AFAIK.
bluevolt is offline
Old 15th October 2013, 18:39   #16580
Top-Gear's Avatar
Thanked: 114 Times
Guys,
Not a funny question at all! For this and most such automation requirements, Tasker is the answer! It's an amazing app (or rather a toolkit).
Top-Gear is offline
Old 15th October 2013, 19:49   #16581
ampere's Avatar
Thanked: 13,617 Times
+1 to Top-Gear (or should I say Holmes! ). Tasker is the mother of all phone automation Apps for Android. I use it day in day out. The best part is you can code it the way you want it.
Check the the Xda You tube channel on Tasker. In fact if I remember correctly one of the guys on the video goes on to say: One of the main reasons to buy an Android would be tasker ! That is stretching it a bit. But I fully agree!
Its a paid App. Initially you may get lost after seeing so many options and buttons. But once you get the hang of it, it is delightful. Then you start thinking what more of your mundane scenarios you can automate.
ampere is offline
Old 15th October 2013, 20:15   #16582
condor's Avatar
Thanked: 16,893 Times
Guys, how to disable the feature where the phone suggests "correc" spellings ? in an Xperia ?
am running 4.1.x, and dictionary option is already off.
Yet when I type in a sms, it keeps suggesting spellings. So unless I keep responding to each word, it will swap the spellings to what it thinks is correct
2)
Where are teh smileys ? I dont find any in the Xperia
condor is offline
Old 15th October 2013, 20:30   #16583
Top-Gear's Avatar
Thanked: 114 Times
So, Holmes has been uncovered! Elementary, dear Watson!
Anyway, felt great to hear from you about Tasker! I've discovered a kindred soul!
I am very eager to know what all profiles you've set up! Should we start a new thread for Tasker?
Top-Gear is offline
Old 15th October 2013, 20:43   #16584
h@r$h@l's Avatar
Thanked: 743 Times
Thanks a ton guys for the pointers. I always had tasker installed but never really struck me that i could use it for my this particular requirement.
Managed to crate a tasker rule.
Thanks once again.
h@r$h@l is offline
Old 15th October 2013, 21:01   #16585
vivekiny2k's Avatar
Thanked: 212 Times
Guys,
I accomplished the same by turning off my network completely as soon as i turn off my phone. Or, you can only turn off the wifi and leave the mobile on, but restrict background data on WA (from "data usage" panel)so it will not be online until you turn the screen on. This way you can continue to get important updates even when screen is off (email/ calendar etc).
The downside is if you use your phone for streaming music (or any other network intensive application), that will turn off as well, as soon as you turn off the screen.
look at my posts earlier in this thread to see my app that turns off the data connection wen screen is turned off.
vivekiny2k is offline
Old 15th October 2013, 21:27   #16586
Top-Gear's Avatar
Thanked: 114 Times
Thanks once again.
Wouldn't you need an exit task as well?
Top-Gear is offline
Old 15th October 2013, 21:35   #16587
abishek2222's Avatar
Thanked: 166 Times
Hi
Can someone point me to , how to exactly export a Tasker profile.
I have a Tasker profile set , which. Works perfectly as of now to basically put my tab into flight mode and turn the screen off the moment the charger/ power is disconnected from the tab. However this takes a few seconds to kick in almost 4-5 seconds.
Is there a better way to instantly turn the screen off when the power is disconnected.
abishek2222 is offline
Old 15th October 2013, 21:47   #16588
h@r$h@l's Avatar
Thanked: 743 Times
What do you mean by Exit task? You meam enabling it after that end time?
I have restricted whatsapp to be non operational between 10:30 and 19:00. Ill test it tomorrow and see how it goes.
h@r$h@l is offline
Old 15th October 2013, 21:55   #16589
Top-Gear's Avatar
Thanked: 114 Times
Yes. Reason is, the action I saw in tasker was "Kill App" which to me suggests that an exit task might be needed. Right, Ampere?
Top-Gear is offline
Old 15th October 2013, 22:42   #16590
sachinj12's Avatar
Thanked: 169 Times
Any free app which does what tasker does? I dont want to pay for an app
sachinj12 is offline
