Old 21st December 2019, 10:14   #1096
Thanked: 1,850 Times
Re: Buying & Using a Pressure Washer
Originally Posted by honeybee View Post
Did you try to charge it again?
Yes mate I tried charging it multiple times. The charge shows as complete indicated by the green LED light on the charger. I have also tried to toggling the on/off switch multiple times to see if it works. Nada, no sign of the motor turning on.
Their contact numbers should be available online. Try calling them again.
I have sent them a Whatsapp message (describing the issue in detail) on all their 4 numbers but haven't heard back as yet.
Also it is a small setup and just about one or two people handling customer calls. At least that's how it was then.
Yes maybe, I am ready to wait for a few days more for receiving a response from them. If not then I will probably call them to find out a resolution.
navin_v8 is offline
Old 21st January 2020, 12:39   #1097
Salikt's Avatar
Thanked: 35 Times
Hi Guys,
planning to buy a pressure washer for domestic use. main usage will be cleaning car, pergola glass and few natural stone layered area in front of the house. which is the best brand Karcher or Bosche?
I have checked in the market for the price of Karcher brand K2 (Rs 12K), K3 (Rs 13.5K) and K4 (Rs 25K).
expecting the experts opinion here.
thanks
Salikt is offline
Old 22nd January 2020, 00:52   #1098
Randhawa's Avatar
Thanked: 361 Times
Originally Posted by Salikt View Post
Hi Guys,
thanks
Any day Karcher and K3 or up model in the range. Using K3 Premium for over a year now with no issues. Used it nonstop for 8Hrs without a hint of issue. Very robust and easy to repair units.
Randhawa is offline   (2) Thanks
Old 22nd January 2020, 03:39   #1099
Thanked: 12,179 Times
Infractions: 0/2 (11)
Bosch is not as reliable as Karcher. Karcher K2 purchased more than four years back cost me about Rs. 4000 in the UAE with a length of pipe thrown in and wall roll/stand. Today, I'd opt for a higher model like K4 or K5. The shop keeper advised me to never use extension wire and have constant water running, and it's all good.
which is the best brand Karcher or Bosche? I have checked in the market for the price of Karcher brand K2 (Rs 12K), K3 (Rs 13.5K) and K4 (Rs 25K).
Sebring is offline   (1) Thanks
Old 22nd January 2020, 18:53   #1100
Salikt's Avatar
Thanked: 35 Times
Thank you for the feed back. yesterday I had chat with the Karcher agency at Calicut and the guy advised me to go for K3 450 model, which is enough for my usage.
thanks.
Salikt is offline
Old 10th February 2020, 12:47   #1101
mercedised's Avatar
Thanked: 449 Times
I have recently purchased Karcher K4 Basic from a dealer. My only query is : Can I use it to suck water from underground tank with a ball valve\filter?
mercedised is offline   (1) Thanks
Old 10th February 2020, 14:08   #1102
500ContyCruiser's Avatar
Thanked: 771 Times
I recently got this from Aliexpress for my Karcher car washer. And its worth every penny.
500ContyCruiser is offline   (2) Thanks
Old 10th February 2020, 19:02   #1103
mercedised's Avatar
Thanked: 449 Times
Attachment 1968476
How is this used, what purpose does it serve? Plz explain.
Old 6th March 2020, 08:20   #1104
virgopal's Avatar
Thanked: 120 Times
Originally Posted by Lambydude View Post
Can anyone suggest a car washer which works on car battery/ 12v outlet and takes water from.bucket. I don't have power outlet or water pipe in my apartment parking.
I have already seen Resqtech option. Anything from Bosch, karcher or similar brands would help.
Came across this Portable pressure washer on seniority.com website.
As described, it is portable and can be operated on DC( car DC socket) or AC also.
Perhaps it fits the bill.
Note: I am not associated in anyway with the manufacturers. Posting for the benefit of interested group members. User reviews seems positive/helpful
I have not bought or used it.
https://www.seniority.in/portable-ca...eid=1b1a7437bc
virgopal is offline
Old 6th March 2020, 15:09   #1105
Randhawa's Avatar
Thanked: 361 Times
Yes you can but the depth should not be more then 3-6ft.
Randhawa is offline   (1) Thanks
Old 16th May 2020, 08:41   #1106
Crazy_Bean's Avatar
Thanked: 267 Times
Guys, Need advise. Looking to buy my first pressure washer. I will be using this mainly to wash my car and patio at times. No heavy duty cleaning but looking for a good washer. I have two options:
1. Karcher K2 Compact - 6.5K (Amazon) (20% smaller than Bosch)
2. Bosch Aquatak 125 - 9.8K (Amazon)
Bosch is a bit more expensive but has 100W higher wattage, a foam lance included and a trolley design. Rest of the things seem similar.
Please advise which one of these would be better, reliable. Also if the heavy induction motor washers are the way to go instead from JPT, Resqtech etc.?
Crazy_Bean is offline   (1) Thanks
Old 17th June 2020, 11:47   #1107
Surprise's Avatar
Thanked: 463 Times
thanks.
Did you purchase it? If yes, what's the feedback? Any accessories along with the main equipment you bought??
Surprise is offline
Old 17th June 2020, 14:17   #1108
Thanked: 117 Times
thanks.
If the price difference isn't much, I suggest you go for K4 which comes with a water cooled motor!
I've one for almost 1.5 years & it's been working well. I got my K4 for around 18K from the dealer itself.
raihan is offline   (1) Thanks
Old 18th June 2020, 18:16   #1109
sridhu's Avatar
Thanked: 2,756 Times
Folks
Got a Bosch Aquatac 125. Yet to use
Re the foam gel & foam lance, any recommendations?
Exactly how bad is the OEM lance?
The MJJC Foam lance has become obscenely expensive (₹ 4,000!!)
Any other options? Saw this VMTC Lance for a more reasonable ₹ 1,000.
Is it any good? Better than the OEM one?
Regarding the gel to be used, can I use 3M car wash shampoo or should I buy one of the pressure wash gels? Any opinions between ProKlear or Wavex?
The consensus seems to be ProKlear but it is quite an old opinion. Hence the question.
Thanks in advance
sridhu is offline
Old 18th June 2020, 21:04   #1110
praveen_v's Avatar
Thanked: 219 Times
Originally Posted by sridhu View Post
Folks
Thanks in advance
The OEM lance is no good and cannot make thick foam. MJJC is best but its cheaper to get from aliexpress. The VMTC one looks pretty similar an might give similar results to MJJC. I have the Foam Lance from Resqtech and it costed around 900/- which gives good result but it might not fit Bosch.
I am using the 3M shampoo and diluting with lukewarm water and using with the lance gives a good thick foam. You can try that out.
praveen_v is offline   (1) Thanks
