Old 19th February 2025, 19:13   #2506
Thanked: 31 Times
Re: Mahindra Thar Roxx Review
Originally Posted by ArSh View Post
Has anyone found a way to add bottle holders to AX7L variant? Or any DIY/hack to store water bottles. I am currently using a 750ml bottle but it's not enough for a trip.
I could fit a 1 litre Bisleri bottle on both front door bottle holders.
GEMINI is offline
Old 19th February 2025, 19:25   #2507
Thanked: 31 Times
Originally Posted by CARbun View Post
Thar Roxx Carplay Now Available in MX5.
Can anyone confirm ?
I got my car serviced last week but there was no update as such , but its working on new lot vehicles ?
https://Youtube.com/watch?v=7ucfzbDx...IIBMDrcFvcP7Fc
I took delivery of AX7L on 01/02/2025. Received a message from Mahindra on 05/02/2025 stating that they are awaiting Apple CarPlay certification, and they appreciate your patience.
GEMINI is offline   (2) Thanks
Old 19th February 2025, 19:27   #2508
Thanked: 55 Times
Originally Posted by Monti View Post
Yes, I've heard the same. The dealer is suggesting at least a 10mm spacer for the other alloys wheels, not sure if there's better. Unfortunately, I need to make this decision today if I need to have this alloy changed.
Have you tried cutting the bumper slightly? That helped ensure it doesn't touch at full lock. Also, do you have any other issues regarding stability or vibrations? I'm worried about warranty and insurance with these 32mm spacers.
I initially used 10mm spacers when the alloys were initially installed. I had issues with vibrations over 100kph and it was only resolved once the 32mm Proman spacers were installed.
Originally Posted by raghut456 View Post
I have booked the MX1 diesel variant, and the waiting period is 12 months. I am considering updating my booking to the MX3 P AT variant. My main concern is the mileage, as I plan to use it as my primary car. On average, I will be driving around 1,000 km per month, with about 500 km per month in bumper-to-bumper traffic in Hyderabad. What mileage are you getting?
I am getting around 6kpL in my P AT in Bangalore city driving and around 9 during highway runs.
Jayhawker is offline   (1) Thanks
Old 19th February 2025, 23:55   #2509
CARbun's Avatar
Thanked: 192 Times
CarPlay is working on AX variants since launch , I am talking about the MX variants.
CARbun is offline
Old 20th February 2025, 00:13   #2510
You don't get any vibrations now? How are you managing with Blore traffic? I find it a nightmare to manage with the wider tyres. You intend to continue using this set up?
Same here, around 6.5 city is the max one can expect.
Monti is offline
Old 20th February 2025, 09:54   #2511
himanshu_j's Avatar
Thanked: 209 Times
Took delivery of my AX7L just last evening, Carplay is not working.
himanshu_j is offline   (2) Thanks
Old 20th February 2025, 09:56   #2512
Thanked: 101 Times
Carplay is not working AX7L variant for sure. We have it and only Android Auto works. At the time of delivery we were asked to sign an acknowledgement that Carplay would be available only from Q1 2025.
ArSh is offline   (2) Thanks
Old 20th February 2025, 10:00   #2513
Thanked: 101 Times
Originally Posted by for_cars1 View Post
One way would be to utilize the cup holder between the seats with the following type of bottle.
Quencher
Originally Posted by Victor18 View Post
A Car Cup Holder Expander is one solution, https://www.amazon.in/dp/B0C7SVNF9H/
I find the cup holders to be placed quite awkwardly to be honest. Any cup or bottle kept in them would interfere with the hand brake and also with reaching the gear lever. Might be specific to me but the extenders would not be very useful.
Is it the normal cylindrical shaped bottle? I could fit the square "Clear" branded bottle but it was a tight fit and also don't think these PET bottles are safe to be used for extended period especially considering the heat in the car when parked.
ArSh is offline
Old 20th February 2025, 11:10   #2514
You don't get any vibrations now at high speeds? I commute to work often, so I'm not sure, with Bangalore traffic and the cop situation here, if this will be an issue.
Do you intend to continue using this setup? I think 22mm could be an option, but I don't think it'll change it much. I'm still contemplating what to do.
Monti is offline
Old 20th February 2025, 11:20   #2515
ACM
ACM's Avatar
Thanked: 4,502 Times
Originally Posted by xotiq View Post
Cancelling you can do online, else dealer can initiate the same. For my XUV700 booking, had to send a mail and follow up with Mahindra support, around a weeks time including refund. Below snip shows status once vehicle is invoiced, and cancellation.
Could you share the online location of link for cancellation. I couldn't find it even after logging in.
ACM is offline
Old 20th February 2025, 11:33   #2516
Sk8r's Avatar
Thanked: 3,455 Times
If I were in your shoes, my bigger worry would be DPF issues in Diesel. If your running is low, better to stick to petrol in spite of low Mileage! It's a SUV Behemoth, please keep your expectations very very low.
Sk8r is online now   (1) Thanks
Old 20th February 2025, 12:59   #2517
LokiPilaniya's Avatar
Thanked: 338 Times
After login, go to My Profile > Vehicle Booking > Select your vehicle > Press 3 vertical dotes and you will see the cancel booking option.
Adding a link so you can land directly to Vehicle Bookings section after login;
https://auto.mahindra.com/myaccount/view-all-bookings
The process is pretty straight forward, I hope this helps.
LokiPilaniya is offline   (2) Thanks
Old 20th February 2025, 13:06   #2518
Thanked: 31 Times
Not even showing a option of Apple CarPlay on mine. If any process to activate it please let me know. Can't use Google maps & Apple music a must needed one's.
GEMINI is offline   (1) Thanks
Old 20th February 2025, 13:41   #2519
Thanked: 136 Times
I got delivery of my AX7L D AT RWD last week. Serial number is 26,719 and MY25.
Carplay is not active.
No pending software updates either. So I dont think the update to unlock Carplay like they did for the XUV700, is out yet.
DCTfanatic is offline   (1) Thanks
Old 20th February 2025, 15:40   #2520
himanshu_j's Avatar
Thanked: 209 Times
Try the built-in navigation- Mappls by MapMyIndia, showed me better routes & more accurate timing than Gmaps. Music can be piped by bluetooth till CarPlay becomes available.
Any audiophiles here who have tuned the 9-speaker JBL for a better sound?
