Old 10th March 2025, 08:32   #2641
me&mymachine's Avatar
Thanked: 50 Times
Re: Mahindra Thar Roxx Review
My delivery date is April to May, so I hope to receive the new interiors then. Sometimes, waiting is beneficial.
me&mymachine is offline
Old 10th March 2025, 10:09   #2642
Thanked: 3,687 Times
Just for the sake of clarity, Haven't you opted for the Mocha Brown Interior variant in the first place while booking or have you changed to the Mocha Brown Interior variant later?
As far as I know, the variants themselves are named AX5L Diesel AT 4WD Mocha Interiors and AX7L Diesel AT 4WD Mocha Interiors.
bijims is offline   (1) Thanks
Old 10th March 2025, 10:32   #2643
Thanked: 50 Times
I booked an AX7L 4WD with a white interior on the first day of booking at 11:10 am, hoping to receive delivery in 2024, but my delivery date is set for April 8.
Old 10th March 2025, 15:20   #2644
Originally Posted by himanshu_j View Post
After speaking to a few dealers, I have confirmed direct fitment only for Fuel Rebel 5 (17", 20"). Excluding brands like Neo, Plati etc
One dealer offered 18" Momo Seven as a direct fit, this may need to be confirmed via a second opinion.
I spoke to a few dealers as well. I've been told a few models of Wilcrox and GTR Pro are direct fit, but I don't want to risk these.
Plati PY 023 is the one that I've been told is a direct fitment, but since there is only on order, i can't confirm verify this. I saw someone here also mentioned that they installed Plati and didn't have any problems, but that was 20-inch, so I'm not sure if tire size would make a difference.
Monti is offline
Old 10th March 2025, 16:25   #2645
himanshu_j's Avatar
Thanked: 210 Times
If alloy width and offset are same, it will fit, diameter is unimportant.
himanshu_j is offline
Old 10th March 2025, 16:54   #2646
Width and offset are the same, he said something about the sidewall having more circumference. His quote's below:
"20" is better upsize in terms of circumference vis a vis original 19" vs 18" which has more sidewall with more circumference"
Monti is offline
Old 10th March 2025, 17:04   #2647
himanshu_j's Avatar
Thanked: 210 Times
Suggest you read this article (https://www.team-bhp.com/forum/tyre-...ffset-etc.html (Understanding Alloy Wheels (width, PCD, offset etc.)))
to understand better the different terms, alloy width is the width of the alloy as implied. Offset is the distance between the mounting hub and the wheel centreline.
Sidewall is in relation to the tyre, not the alloy.
himanshu_j is offline   (1) Thanks
Old 10th March 2025, 17:17   #2648
SithDefender's Avatar
Thanked: 1,123 Times
Originally Posted by xotiq View Post
Will be getting the doors and boot damped. During my Roxx TD, had measured sound level inside with a sound decibel meter. Was less than the seltos diesel (damped).
Is it really necessary to damp it further? Just asking because during the test drive, I was very impressed with the stock NVH damping, even for the diesel.
#Storage- Continues to be a royal challenge!. The bottle holders next to drivers seat are quite narrow and shallow. Door pockets are weirdly shaped.
Yes, it is quite unfortunate. How did you manage this?
#Drive Comfort, Motion Sickness- Over 1300+ kms, absolutely no hint of motion sickness or uneasiness. (PAX were those who typically are sensitive to this in other cars).
Glad to read this, since I had dreaded this would be a deal-breaker given the tall BoF structure. I guess the white interiors, high roof height and panoramic sunroof also contribute to the airy feel that prevents motion sickness!
Originally Posted by Puneet0051 View Post
Speedometer view is changed from the older one. Attaching a pic below, can somebody verify the same who have got the Software update.
Wow that new speedometer looks fantastic! It is good to see a slight differentiation from the tachometer as well, especially during quick glances.
Originally Posted by wannabe loser View Post
Received this from my dealer yesterday
That is excellent news! Hope this is true, as it will address one of the major pain points of the new Roxx without going for the Mocha brown that is available only on the 4x4 variants.
Originally Posted by kgt.v8 View Post
Mahindra should clarify whether the seat material used for Mocha interiors in Thar Roxx is same as the one in Scorpio-N or is different to make buyers comfortable. Nobody has seen Mocha interior in-person to indicate is the seat material soft or same as Scorpio-N one.
XUV700 and Roxx both have white interiors, but the XUV uses a leatherette material that is easier to keep clean. This is what is coming to the Roxx, if I read it correctly.
On the other hand, Mahindra has not claimed that the Scorpio-N material is coming to the Roxx, despite both being Mocha Brown (for the 4x4 variants). If the material is not changed, then the brown on the Roxx is still going to get soiled faster than the Big Daddy Scorpio.
By the way, I am really happy to see Mahindra listening to it's fans! This is the right way to engage and retain customers!
SithDefender is offline
Old 10th March 2025, 17:24   #2649
Thanks for sharing that, I've checked the dimensions, and confirm that the 20 inch and 18inch Alloy have the same -10 ET, so ideally shouldn't have any issues.
Monti is offline   (1) Thanks
Old 10th March 2025, 18:38   #2650
Rex52's Avatar
Thanked: 38 Times
https://www.instagram.com/platialloys/reel/DG-71qFzezF/
You can find out something related to your questions. Someone uploaded a video on the Insta. According to him the Plati PY 023 both 18" and 19" he has with him. This video shows the the 20".
Last edited by aah78 : 10th March 2025 at 19:12. Reason: Quote trimmed. Please quote relevant sections of posts only. Thanks.
Rex52 is offline
Old 10th March 2025, 18:49   #2651
Originally Posted by puntolover View Post
Tried blacking out the front grill, similar to new wrangler.
I remember you making modifications to your uncle's MX3 variant. Was it the Plati alloy you went with? How happy are you with the alloys? You said 1.5-inch offset; I thought it was more like -10 ET?
Monti is offline
Old 10th March 2025, 19:49   #2652
sgmuser's Avatar
Thanked: 1,370 Times
Attachment 2734487
What Mahindra people are smoking. Why this change only affects AX7L and nothing else. How someone calls this "listening to customer"? This is absurd and simply idiotic from M. Giving an interior that's is dirt magnet and then changing it in only top variants. Isn't this simply nonsensical? Just give a grey interior to all the lower variants and call it a day. Just with a stupid white interior you're trying to force buyers to go for top end variants? This is getting into my nerves really.
sgmuser is offline   (2) Thanks
Old 10th March 2025, 20:20   #2653
Thanked: 203 Times
If this is true, it honestly leaves a false taste in mouth. Feeling like us, people who helped build the hype and booked first were treated like Guinea pigs by Mahindra. Earlier they were hellbent that white interiors in this car aren’t a bad idea and now finally admitting their mistake. Guess I’ve no option left but reupholster the seats but even then I don’t want the roof liner touched, can’t see the new car being taken apart like that so that will remain a dust magnet.
shivamk11 is online now   (1) Thanks
Old 11th March 2025, 13:05   #2654
Thanked: 11 Times
Got my Roxx yesterday from Meridian Moto, Alappuzha, Kerala. its MX3 P AT version, Tango Red colour. Changed the steel rims to company alloys and installed JKTT TPMS for CAR (link https://thereliablecompany.in/product/jktreel-tpms/) .
TPMS works flawlessly and as the TPMS is connected with phone over bluetooth, there is no need to open the car to check tyre pressure status and alerts. Apple car play (Wired) working smoothly.
Photos of the Roxx MX3 P AT with new company alloys. Need to update the fog lamp also once Mahindra can unlock the fog switch of the vehicle. Can anyone suggest a better way around.
Last edited by Axe77 : 11th March 2025 at 18:58. Reason: Please use the EDIT or QUOTE+ (multi-quote) button instead of typing one post after another on the same thread. Thanks!
rajtvm is offline   (9) Thanks
Old 11th March 2025, 14:55   #2655
Photos of the Roxx MX3 P AT with new company alloys . Need to update the fog lamp also once Mahindra can unlock the fog switch of the vehicle , Can any one suggest a better way around.
Nice! Congratulations on the purchase.
Did you instal the TPMS at the showroom itself?
