Old 31st October 2015, 01:35   #3616
HotChillyPepper's Avatar
Thanked: 376 Times
re: Mahindra XUV500 niggles & solutions
Originally Posted by kaiserketkar View Post
thanks a lot for the info HCP.
one more thing i forgot to ask was if any other voice alerts like the scorpio has- such as fuel reserve, door open, etc are also added?
Confirmed: Door Open audio warning has been added with this update. Though it does not say which door.
I think even fuel low should also be there as in Scorpio, not tested yet.
-HCP
HotChillyPepper is offline   (1) Thanks
Old 1st November 2015, 15:07   #3617
Thanked: 41 Times
Originally Posted by HotChillyPepper View Post
[u]50K service update:
[*]Infotainment system software updated with latest map (MMI version 9). Now audible seat belt warning through speakers is added. Its a good feature in my opinion.
I went to the service centre recently and was told that my MMI can not be upgraded to Version 9x as they had some hardware failure issues as a result of this upgrade. My vehicle is Dec 2014 make. I was told that the upgrade can only be made if M&M authorises replacement of the silver box. Has anyone else encountered this?
10K service upgrade
The tyres were rotated. No vehicle alignment report was given. The vehicle started to drift strongly to the right side.
Took it back and also complained about a noise that I suspected came from near the B pillar on the right hand side. They said the noise came from the brake area on the right hand side, dismantled the whole thing including suspension, replaced the lower arm, etc and after about 10 hours of trying, said that I need to leave the vehicle there overnight. This 'shooting in the dark' process of diagnosis was quite offputting. The next day someone else looked into the issue and said that the noise in fact was coming from the LEFT side.
The vehicle was delivered late evening, with a vehicle alignment report. Some values were out of the normal range mentioned. Then I found that the vehicle was drifting to the left. Some serious talk with the M&M person resulted in the vehicle being taken to another service location of the same company. Now the vehicle is back, with another alignment report, with some values out of range. Have not checked on the drift issue as I have only been driving in Bangalore traffic since I got the vehicle back.
Incidentally, the delivery driver synched his own phone to the ICE - I discovered this only when I had an incoming call while driving and could not talk on the bluetooth.
A great vehicle, but with some unpleasant ownership experience because of the service quality.
Thanks!
Last edited by Zappo : 3rd November 2015 at 14:48. Reason: Please do not make back to back posts. In the 1st 20 minutes use the edit button to add content to your previous post. Also, try to use multiquote option to answer to multiple people in a single post.
arao is offline   (1) Thanks
Old 1st November 2015, 22:05   #3618
Thanked: 47 Times
Thanks for the update on the update
I got my XUV's software updated as well, but I haven't managed to get the audible warning. Did this come on by default or did you have to manually enable it?
Can you please post a pic of the software version?
I did update on my w8 over the weekend but did not find any audible warning. My RM does not seem to aware of this feature. However found the display of external temp a welcome change. But earlier when we use the auto wiper there used to be a display at the bottom indicating the wiper on status. This is gone now.. There is no way to find the status of auto wiper
gpriyesh is offline
Old 2nd November 2015, 21:01   #3619
Thanked: 2,365 Times
Do you have an image of the display indicating the auto wiper on status? I do not see any image of the auto wiper status on my April 2015 XUV.
Also what temperature display are you mentioning about? It is already there right
fusionbang is offline
Old 3rd November 2015, 08:25   #3620
Thanked: 47 Times
Sorry I do not have a picture of the wiper status. It used to be a small icon at the bottom bar. Regarding temp earlier it used to display only the internal temperature but now it displays both internal and external temperatures always. Mine is not a new age xuv.
gpriyesh is offline
Old 3rd November 2015, 09:35   #3621
If you look at this image, it is displaying both outside and inside temperature, there is no signs of the auto wiper status. Even mine is not a new age XUV.
Anybody with the old gen XUV can confirm if this was the case with their cars.
Old 3rd November 2015, 10:24   #3622
rahul_kej's Avatar
Thanked: 602 Times
In my old gen XUV W6 it shows auto wiper status.
rahul_kej is offline
Old 3rd November 2015, 11:07   #3623
Thanked: 47 Times
I started seeing this in my xuv after the update to maps 9 and update to the infotainment software this weekend. Till then ext temp was not there and used to get the status of auto wiper when it is switched on
gpriyesh is offline
Old 3rd November 2015, 12:03   #3624
Guess the software was updated in the last batch of XUV's to display both the temperatures. Apart from this what all update does the new software has?
I am planning to give my car for second service tomorrow or day after, should I ask them for an update?
Old 3rd November 2015, 12:21   #3625
adu
Thanked: 54 Times
This is not an acceptable answer. In cases where the software upgrades require a change of the silver box, Mahindra is required to do so. Take this up with the M&M Customer Service and drop them a mail, things will happen then.
10K service upgrade
Which MASS do you go to?
Last edited by Zappo : 3rd November 2015 at 14:52. Reason: No back to back posts please. Use the Edit and the Multiquote options.
adu is offline
Old 3rd November 2015, 13:57   #3626
Thanked: 41 Times
India Garage, Bangalore - first Mahavenpura, and then Peenya.
arao is offline
Old 3rd November 2015, 14:12   #3627
adu
Thanked: 54 Times
Visit Sireesh in Marthahalli. They are good and very proactive.
adu is offline   (2) Thanks
Old 3rd November 2015, 21:34   #3628
Thanked: 48 Times
Cant agree more. For my 20K service, I stood by my vehicle while it was being serviced. Everything was very meticulously and professionally done. Cool guys...
sk7671 is offline   (1) Thanks
Old 4th November 2015, 08:43   #3629
Thanked: 47 Times
I have not seen anything else visible apart from this. It is always good to update the software if one is provided.
gpriyesh is offline
Old 4th November 2015, 12:56   #3630
djpeesh's Avatar
Thanked: 778 Times
Any clue on whether the update can be installed on a Jan 2013 make xuv? The service guys were saying that so far, they don't have any update and I'd have to ask nippon. They said they'd get it by end of the month.
Also, I just found out that the outside temperature sensor is located in the right side ORVM. So if it goes kaput, you have to replace the entire mirror unit. Not a smart move no?
djpeesh is offline
