Old 9th March 2016, 02:10   #7276
vasoo's Avatar
Thanked: 248 Times
Re: Honda Civic : Maintenance, Service Costs and Must dos
My car is lying idle for the last 5 months since I moved to US in October. I was planning to go to India in between and hence I did not sell the car. Now I am not sure when will I be going back and in what condition the car will be. Anybody here has similar experience ?
vasoo is offline
Old 9th March 2016, 09:15   #7277
sgiitk's Avatar
Thanked: 4,809 Times
@vasoo; When I had my heart surgery my Accent was not started for three months. Nothing was required.
sgiitk is offline
Old 9th March 2016, 20:04   #7278
Thanked: 76 Times
@Vasoo- My Civic was run only once for 10-15 kms over a period of 6 months in 2013.No issues whatsoever.
ramanak is offline
Old 10th March 2016, 08:25   #7279
sumeethaldankar's Avatar
Thanked: 3,666 Times
Has anybody got their cars steering wheel leather replaced ? What are the costs ? Any alternatives ?
Thanks.
sumeethaldankar is online now
Old 10th March 2016, 11:12   #7280
WasavaTyres's Avatar
Thanked: 459 Times
Thanks.
I think replacing the leather is not going to have the same finish. Mine had worn off the perforations on either side of where we grip the wheel. I bought one from chor bazar ( salvage vehicle perhaps) It came without the steering boss / SRS unit and cost me 2,000
WasavaTyres is offline   (1) Thanks
Old 10th March 2016, 13:01   #7281
coolkurt's Avatar
Thanked: 1,724 Times
Thanks.
I'm getting my civic's interiors revamped.
I'm getting the following deal:
Hi - Tech Nappa art leather seat covers + door trims+ armrest + gear fob + leather steering wheel cover ( art leather doesn't last) + re-painting of control panels on doors = 15,500/-
I've decided on a leather steering wheel cover..costing around 1200 as art leather doesn't last.
coolkurt is offline   (2) Thanks
Old 10th March 2016, 15:15   #7282
SmartCat's Avatar
Thanked: 51,899 Times
I need to get the door trims replaced. What kind of shop do I need to go to? Will the big guys like Stanley do it at reasonable price?
SmartCat is online now
Old 10th March 2016, 16:43   #7283
coolkurt's Avatar
Stanley is expensive. Would suit you to match it with whatever quality you've used for your seat covers.
There are places where you could get it done for a nominal cost. Should cost anywhere between 2k -4k for the door trims - considering you'll want good quality art leather.
Team bhp directory should guide you to a good place in bangalore. Or you could probably go to the place you got your seat covers done.
coolkurt is offline   (1) Thanks
Old 11th March 2016, 11:10   #7284
Thanked: 459 Times
Stanley will charge a bomb ! Try Epona lifestyle. Harish is the guy who runs the outfit. I can PM you his details if required.
Old 12th March 2016, 13:39   #7285
petroguzzler's Avatar
Thanked: 264 Times
Team,
When I start my civic in the morning, droplets of water come from the exhaust. On close observation these droplets have a slightly black colour. Is it normal?
petroguzzler is offline
Old 12th March 2016, 14:50   #7286
Thanked: 61,524 Times
Perfectly normal upon start up. It's just a little water condensation from the exhaust gas on your still relatively cold exhaust system. It's black because of the soot in the exhaust. Condensation stops as your exhaust system heats up.
Jeroen is offline
Old 13th March 2016, 18:05   #7287
manim's Avatar
Thanked: 925 Times
How long I can go between oil changes for very low running?
My Civic is nearing nine years old, and I have so far faithfully done the routine services (oil changes every six months (or) 10,000 kms). Now, my car has been mostly idle for the past six months. My last oil change was in June-2015 and has done around 6,000 kms after it. I have a 1,500 kms trip coming up shortly. So I am in a dilemma: do the change before the trip or after.
manim is offline
Old 13th March 2016, 21:47   #7288
ImmortalZ's Avatar
Thanked: 601 Times
My car is 9 years old. I do know how to set the AC on auto and change the fan speed manually
The issue I am facing is, on a long drive, the fan speed suddenly drops, and despite cranking it up manually, the fan speed remains the same. There is just very little airflow. It still throws cool air but absolutely no airflow. I tried getting the temperature lower, but even at Lo, the fan speed stays the same. Then If I turn the compressor off, and put it only on blower, the fan speed issue corrects itself and I'm able to manually alter the fan speed.
So every half an hour, I have to either switch the compressor off for 10 mins or switch the AC off. When I switch it back, it works fine for a while. Then same issue. Any advice?
This is something I faced myself. It's the thermostat.
See what happens is that the AC compressor doesn't turn off. This happens because the temperature sensor on the evaporator coil inside the dash doesn't work. So the the compressor doesn't cut off and ice builds up on the evaporator, impeding air flow. When you turn off the AC for a while, the ice melts off and everything is normal again. You can even observe this by turning on the AC again with the air on full blast after a few minutes. Ice crystals will come flying through the vents.
Take the car to a reputed AC shop and have the thermostat changed. Driving the car around this way will have a noticeable impact on FE and I doubt it is too good on the compressor either.
ImmortalZ is offline
Old 13th March 2016, 22:31   #7289
UPDATE : Mar 13, 2016 - Ultimately I did take the Civic to Raghav and after a test drive, he said everything seems ok. However knowing my car well, I pointed out the nuances and ultimately he opined that the clutch might replacement. Although there was no slippage or any such thing, I respected Raghav's diagnosis and dropped the car off after a few days. Raghav called up and went over the options and I did end up getting a XCD performance clutch. Also I was updated on the constant progress and we had to have the spark plugs changed to NGK as the earlier ones were Santro plugs, not sure how or why the previous owner did so. A through check up later, so water was found in the drive shaft boot (I think), cleaned, engine, brake oil, filters, plugs and clutch assembly changed.
Its a huge change when I drive the car now, yes I do have to rev the RPM to be around 1800 or so, but clutch is smooth and so is the car. Raghav encourages me to push the car around Long story short, very happy with Ignite and I coincidentally found that Raghav also graduated from the same college as me, so I have some alumni bonding as well. Irrespective of that his professionalism and personal ethics sets him apart.
Yes, while Raghav set some high standards for himself, there is always scope to improve. Not a make or break deal, few small items like keeping the shop floor clothing off the car upholstery etc. I'm sure it will be a thing of the past when I visit him again...Thanks guys/Team bhp. Definitely looking forward to my next visit to Ignite!
Originally Posted by slickshots View Post
Thank you fellow BHPians. I have a lot to go after now First step I will try and check on the clutch cylinders with a trusted mechanic of mine cylinders, fluid level (?) and cable play etc. However I have already ruled out the obvious issues like obstruction under the mat or any such visibly simple issue. I have heard a lot about Raghav and Ignite garage, will take it there too, hoping its a simple case to fix. Will update post after I fix it, many thanks again guys
slickshots is offline   (1) Thanks
Old 17th March 2016, 12:15   #7290
laluks's Avatar
Thanked: 16,485 Times
A new issue has cropped up, that too in summer
The fan which cools the condenser is making some weird noise, as it is scrapping somewhere. Hope the motor is fine and its just some lubrication issue.
laluks is offline
