Old 23rd September 2009, 14:10   #646
aks_karthik's Avatar
Thanked: 342 Times
Originally Posted by sharma_sanjeevi View Post
Thanks for the reply VP, Yes, in his case there is a huge difference, he has manually calculated 2 times & the figure was almost the same with a difference of .5.
Till now the display for the Average Consumption shows 7-8 Kmpl only.
Amit Bhai, Yes, hopefully this option should solve it if there is a problem of display getting hanged, may be i am wrong as there has been no reports of display getting hanged, i conveyed this to him, but also told him to take the advise from TASS SA before going for a reset.
Ask him to check the display,whether it's in km/litre or 100km/litre.
we can change the display using the menu controls for Average Consumption..
aks_karthik is offline
Old 23rd September 2009, 14:47   #647
sharma_sanjeevi's Avatar
Thanked: 114 Times
I hope it is Km/Litre, as he confirmed, but i will ask him to check it once again & let you guys know about it
sharma_sanjeevi is offline
Old 23rd September 2009, 15:00   #648
lightinin95's Avatar
Thanked: 7 Times
Hi Sanjeevi,
Just check if the setting is miles/lit or km/lit. I think it is set at miles /litre.
Cheers, Sam
lightinin95 is offline
Old 23rd September 2009, 15:32   #649
Thanked: 114 Times
Originally Posted by lightinin95 View Post
Hi Sanjeevi,
Cheers, Sam
Thanks buddy, i will check it out with him & update you guys.
Old 23rd September 2009, 18:15   #650
coolboy007's Avatar
Thanked: 2,144 Times
But when he calculated manually the FE was 15.20 Kmpl with 100% AC in City B2B traffic, these FE figures are very good.
As the display is same in the Linea also, have you experienced this issue ? if yes, then what can be a probable solution to this ?
Did he RESET the trip meters after filling in at the bunk?
Trip meters can be reset by pressing and holding the small round button on the right hand lever which cycles through various MID modes.
Dealer guys handle car roughly and that 8km/l may be showing for that drive.
Just ask you friend to RESET both Trip A and trip B and if still problem persists, he can disconnet -ve terminal of battery and whole system will reboot.
coolboy007 is offline
Old 24th September 2009, 10:07   #651
Thanked: 114 Times
Ok, that is also a good information, i will check it with him.
@VP,
Sorry for hijacking your thread
Old 24th September 2009, 10:12   #652
Thanked: 342 Times
Update
It's not 100km/ltr.
It's ltrs/100kms and Km/ltr conversion only.
Old 24th September 2009, 10:57   #653
@VP,
You're always Wel Come, Sanjeev
Guys - What about my query ? Pls pay some attention to it also. ... kidding
VahanPujari is offline
Old 24th September 2009, 11:51   #654
coolboy007's Avatar
Originally Posted by VahanPujari
At Loanavala 2-3 times while idling, the car blurted out small whistle-type sound. When engaged in gear imdtly it vanished. What is that? Definitely nothing serious but want to get it checked
Once again ,
Why dont you buy a house within a striking distance from TASS. Now whats the whistling sound you are talking about?
Will ask dad to check, when i drive, its AC on full fan speed and Music sys on 16-17(it crackes after that) so never heard that type of noise.
Did you go through any water logged areas? In my Santro, whenever i started the car in the morning, it gave a whistle type from front and vanished after few secs but that was noise from some belt.
Amit, are you experiencing it daily or was a one off affair like clutch going down? Phew, your car is really a "gaadi zameen par" special.
What a keen oberver you are....
Old 24th September 2009, 12:16   #655
No. My car has never launched into water logging as yet. Its a soft whistle type or hissing type noise. It sounds as if it comes from outside. This time Music was ON still I could hear it. First I thought its from Music system, stopped it, then I thought its from vipers, stopped it also.
Both the times, common items were - Rains & Humidity/ fogging/ misting (probably higher cabin temp vs low outside temp). Could any of these 2 common items do something (friction in belts or some part of engine etc) which can result into this sound?
Old 24th September 2009, 12:29   #656
Thanked: 451 Times
Does it come from the underbody of the car? Sometimes the hissing sound is of the fuel pump. But fuel pumps have a hissing sound, not a whistle. Fuel pump hissing sound can be compared to gas leaking from somewhere.
amit is offline
Old 24th September 2009, 12:57   #657
I could not actually check the location where its coming from. If it comes again, will have to do it. Can't explain the sound - its something like when you try to make this sound with lips - shhhhshhhhhhshhhhhhshhhh - continuous with slightly varying pich
But there is not a trace of any vibration. So I guess friction ma be rulled out.
Yes. Will have to check the location if it comes again.
Old 24th September 2009, 14:18   #658
Thanked: 44 Times
ssssssssssshhhh sound
Hi Amit (VP) , does the sound like the cooker wistle ?
i used to get similar sssssshhh sounds in my palio few years ago from the front wheels. later on it was diagnosed as "ball bearings have worn out"
Wassan motor (deonar) guys replaced the same and the sound vanished.
i am not sure whether the sound in your car is related to this
may be you can check with the TASS.
StarVegabond is offline
Old 24th September 2009, 14:21   #659
StarVB
Yes. Its somewhat similar to cooker whistle but not that severe. And it has surfaced only 2-3 times. If its bearings, then won't the sound be permanent or persist more?
Old 24th September 2009, 14:54   #660
Thanked: 44 Times
StarVB
In my Palio's case, the (cooker whistle like) sound used to be heard during idle condition and used to vanshi once the car picks up speed
initially it was intermittent, but over 1-2 months it became very consistent. then i referred it to servcie station and they replaced the ball bearings and sound was never heard again.
in your case, i am not saying it could be ball bearing, but it is better for your refer the issue to TASS and let them diagnose what it is .
