Search Forums |
Advanced Search |
Go to Page... |
Search this Thread | 335,396 views |
25th May 2012, 00:10 | #541 |
BHPian Join Date: Oct 2011 Location: mumbai
Thanked: 189 Times
| Re: Leh and Ladakh - Trip Planning - All queries go here Indian21r/SunnyPaaji Hi Since you are doing the entire circular route it is better to go via Srinagar and return via Manali. This way the chances of AMS are reduced.Remember if one of the group has a problem everybody suffers. Also you dont need a HP permit when you drive Leh to Manali.(HVK saar has also pointed this out) You definitely need more days.It is not just touching base and leaving. Indian2r You are going to Delhi twice.That is going to be painful.You can save time by staying there only once. IMHO taking a swift.Reason being that it is newer and the wide network of service.Gives you an experience of driving the easier part first.Negative: low ground clearance specially when you do the rohtang part.(I did it in a beat via srinagar and except for scraping the bottom at a few places it wasnt a problem).This is my opinion.The rest is up to you. Regards PS:What I have gathered from different websites is that the car rental companies can be difficult if they know you are driving to Leh and Manali. |
(1) Thanks |
The following BHPian Thanks faustus77 for this useful post: | indian21r |
25th May 2012, 08:36 | #542 | |
Senior - BHPian Join Date: Nov 2006 Location: Mumbai
Thanked: 3,463 Times
| Re: Leh and Ladakh - Trip Planning - All queries go here Quote:
(1) Thanks |
The following BHPian Thanks hvkumar for this useful post: | indian21r |
25th May 2012, 12:02 | #543 | |
BHPian Join Date: Mar 2006 Location: Hyderabad
Thanked: 814 Times
| Re: Leh and Ladakh - Trip Planning - All queries go here [quote=faustus77;2787855]Indian21r/SunnyPaaji Hi Since you are doing the entire circular route it is better to go via Srinagar and return via Manali. This way the chances of AMS are reduced.Remember if one of the group has a problem everybody suffers. Also you dont need a HP permit when you drive Leh to Manali.(HVK saar has also pointed this out) You definitely need more days.It is not just touching base and leaving. Indian2r You are going to Delhi twice.That is going to be painful.You can save time by staying there only once. IMHO taking a swift.Reason being that it is newer and the wide network of service.Gives you an experience of driving the easier part first.Negative: low ground clearance specially when you do the rohtang part.(I did it in a beat via srinagar and except for scraping the bottom at a few places it wasnt a problem).This is my opinion.The rest is up to you. Regards PS:What I have gathered from different websites is that the car rental companies can be difficult if they know you are driving to Leh and Manali.[/ QUOTE] For a trip more than 7-10 days, car rental is not worth it. it may be cheaper to buy and car and sell than rent. The time spent in Delhi is for meeting family friends. It can be cut short to 3-4 days. The reason we may have to do 2 trips here is to catch flight back to Hyderabad. Also it falls kind of midway from Hyderabad. And Taj Mahal will have to be there. Quote:
Now I have one very important question did you guys book accommodation before hand or was it when you reached there. Since I will be having my sisters traveling I am keen on places which have good facilities. Will the clockwise (via Srinagar - Leh) and anticlockwise (via Manali - Leh) routes be drastically different in terms of scenic beauty and experience to drive. Thanks for the inputs on permits. With respect to AMS, will patients of Asthma face major issues? While I was doing Sikkim in 2008 October, I have seen few people fall down at Gurudongmar lake. As of now I will be doing most of the driving. My sisters have never driven in the highway or Hills apart from what are there in Hyderabad. | |
() Thanks |
25th May 2012, 12:19 | #544 | ||
Depends on the season. Till mid-Aug, it is best if you can arrange acco in advance but then you will also end up paying very high rates. From mid-Aug onwards, you can walk in and get acco anywhere bargaining heavily. Quote:
() Thanks |
25th May 2012, 12:35 | #545 | ||
Thanked: 814 Times
() Thanks |
25th May 2012, 13:02 | #546 | |||
(1) Thanks |
25th May 2012, 13:49 | #547 | |
BHPian Join Date: May 2009 Location: India
Thanked: 652 Times
What about the heart patients, who have undergone Angioplasty? Low temperatures can create a problem. Any idea about this? Cheers! Irish | |
() Thanks |
25th May 2012, 15:27 | #548 | |||
Thanked: 814 Times
If someone wants to join the trip will Jammu / Srinagar Flight make sense. Acclimatization can happen from Srinagar to Leh. If this is a good option, then I can consider driving from Hyd - Nagpur- Indore - Chittorgarh - Ajmer - Bikaner - Amritsar - pathankot - jammu 2540kms vs Hyd - Nagpur- Indore - Gwalior- Delhi- ludhiana - pathankot - jammu 2450kms Vs Hyd - Nagpur- Sagar/Jabalpur - Gwalior- Delhi- ludhiana - pathankot - jammu 2110kms Option 1 we can avoid Delhi one way. I remember part of highway from Bikaner to Pathankot being butter smooth. and Rajasthan roads to be generally very good Should be doable in 3 days. What do you guys feel. | |||
() Thanks |
25th May 2012, 15:52 | #549 | |||||||
Alternatively, you have to lug along the large oxygen cylinders that you see used in hospitals, which are meant for use for longer time like, say, 30-60 minutes and more. But these are normally hired out from outfits who supply these cylinders against deposit, etc. Too bulky....and unnecessary. Quote:
You do not have to go via Bikaner to go to Amritsar. You should be going on Chittorgarh-Bhilwara-Nasirabad-Kishangarh-Ladnun-Ratangad-Sardarshahr-Hanumangarh-Abohar-Taran Taran-Amritsar. Please check earlier posts of mine, I have uploaded a file with detailed route plans to go to Ladakh by all route combinations. Quote:
(1) Thanks |
25th May 2012, 18:15 | #550 | ||||
Thanked: 814 Times
To avoid since roads are bad between MH border-Seoni, Laknadon-Sagar and Jhansi-Gwalior. Doing Hyderabad-Jammu in 3 days is not easy, it will be a flog of a drive, starting very early every morning and stopping late night all the 3 days.[/quote] With Innova 3 days will surely be difficult, Swift maybe. Why I was asking was to plan arrival of my sisters directly to Jammu. They are keen on doing road trip but I feel that they should not stress themselves out too much before we reach Leh. Further Flights are also quite reasonable 1 way fare around 8k. I am getting more and more clarity from your inputs Mr Kumar. Hats off to your patience | ||||
() Thanks |
27th May 2012, 16:14 | #551 |
Thanked: 814 Times
| Re: Leh and Ladakh - Trip Planning - All queries go here Hi all, I have finally managed to get a leave of 27 days from June 2nd to June 28th. Will use June 2nd to do a final checklist. Below is the itinerary prepared taking Inputs from Humbleh'd threads, urban_legend itinerary and other travelouges. We will be 5 people in all when traveling in Kashmir, 2 guys (both will drive) and 3 girls. Leg 1. Driver, myself and cousin will be in this leg of Journey till Delhi. What alternatives will be better to get onto NH3. DAY - 1 Sunday, June 03, 2012 Hyderabad – Nagpur – Betul (750 Kms) DAY - 2 Monday, June 04, 2012 Betul – Indore – Shivpuri/ Gwalior (NH3) DAY - 3 Tuesday, June 05, 2012 Shivpuri/Gwalior -Agra – Delhi (NH3, Yamuna Expressway) Take some rest here DAY - 4 Wednesday, June 06, 2012. From Delhi the car will have 5 pax Delhi –Ambala- Ludiana-Amritsar / Pathankot (470 Kms) DAY - 5 Thursday, June 07, 2012 Amritsar/ Pathankot - Ramban - Banhal - Anantnag - Srinagar ( Avoid Jammu) How can day 4&5 be managed DAYs – 6,7 Friday, June 08 & Saturday June 09, 2012 Srinagar Holiday ( Effectively 3 night here. One day in boat House, Gulmarg etc) Leg 2 Leh DAY - 8 Sunday, June 10, 2012 Srinagar - Sonamarg - Zojila - drass - Kargil DAY - 9 Monday, June 11, 2012 Kargil – Padum (To be done if we can manage an extra day. And is Padum really worth the travel) / Buffer day DAY - 10 Tuesday, June 12, 2012 Kargil - Mulbek - Namik La - Fotu La -Lamayaru - Khaltse - Nimmu - Magnetic Hill - Leh - Vehicle check up (if possible) DAY - 11 Wednesday, June 13, 2012 Rest Day in Leh/ acclamatising (permits for Khardung La, Mahe, Pangong Tso, Chang La, Tso Moriri, Tso Kar) Leh City tour/ - Hemis, Thikse, Shey - and Stok (Palace and Monasteries), Shanti Stupa etc. DAY - 12 Thursday, June 14, 2012 Leh - Khardung La - Hunder - Diskit - Panamik - Diskit (Nubra Valley) DAY - 13 Friday, June 15, 2012 Diskit - Wari La - Chang La - Tangtse - Pagal Nallah - Pangong Tso/ Tangtse DAY - 14 Saturday, June 16, 2012 Pangong Tso/Tangtse - Changla - Sakti - Karu - Upshi - Mahe - Chumathang - Sumdo - Tso Kiagar -Tso Morriri (Stay at Korzok/Tso Moriri) DAY - 15 Sunday, June 17, 2012 Tso Moriri - Debring - More Plains - Pang - Lachulung La - Naki La - Gata Loops - Whicsky Nallah - Brandy Nallah - Sarchu DAY - 16 Monday, June 18, 2012 Sarchu- Jispa / Keylong –Rohtang Pass – Manali Leg 3 – Spiti Valley Picked straight from Humbleh'd II, By the way will this open by June 15th? DAY - 17 Tuesday, June 19, 2012 Manali -Rohtang Pass-Losar -Kaza DAY - 18 Wednesday, June 20, 2012 Kaaza - Dhankar -PinValley - Kaaza DAY - 19 Thursday, June 21, 2012 Kaaza - Komik - Kaaza DAY - 20 Friday, June 22, 2012 Kaaza - Kee - Kibber - Tashi Ganga - Kaaza Day 21 Saturday, June 23, 2012 Kaaza- Pooh – Chtikul Day 22 Sunday, June 24, 2012 Chtikul- Rampur - Shimla Leg- 4 Return Day 23 Monday, June 24, 2012 Shimla -Delhi- Agra Day 24 Tuesday, June 25, 2012 Agra - Gwalior-Shivpuri – Indore Day 25 Wednesday, June 26, 2012 Indore -Betul – Nagpur Day 26 Thursday, June 27, 2012 Nagpur - Hyderabad Will this be too hectic or can we do it comfortably. Already initiated the process for getting BSNL post paid Mobile, will be picking 3 of them. For the, will be replacing Engine oil, tyres have done 25k, so will have to see if they have to be replaced. Air Pump etc have to be procured. Will do a vet of the checklist this week thanks Last edited by indian21r : 27th May 2012 at 16:17. Reason: permit list |
() Thanks |
27th May 2012, 17:29 | #552 | ||||||||
Do not take the direct Harda-Indore road, it is always in very bad condition. Quote:
The road via Jammu is quite god now thanks to the 4-laning, although you may still consider the Dyala Chak/Samba-Mansar-Udhampur route. You will face heavy traffic on the Jammu-Srinagar road. YOu can easily reach Srinagar the same day from Pathankot. You do not have to go via Amritsar. Quote:
(2) Thanks |
The following 2 BHPians Thank hvkumar for this useful post: | gajadonga, indian21r |
27th May 2012, 18:12 | #553 | ||||||||
Thanked: 814 Times
Leg 3 – Spiti Valley DAY - 17 Tuesday, June 19, 2012 Manali -Rohtang Pass-Losar -Kaza DAY - 18 Wednesday, June 20, 2012 Kaaza - Dhankar -PinValley - Kaaza DAY - 19 Thursday, June 21, 2012 Kaaza - Komik - Kaaza DAY - 20 Friday, June 22, 2012 Kaaza - Kee - Kibber - Tashi Ganga - Kaaza Day 21 Saturday, June 23, 2012 Kaaza- Pooh – Chtikul Day 22 Sunday, June 24, 2012 Chtikul- Rampur - Shimla By the way with 5 people, we can manage right. As of now I am thing of removing one seat at the back fully to create space. No roof top carriage yet. Thanks Rahul | ||||||||
() Thanks |
27th May 2012, 18:51 | #554 | |||||
Going to Vaishnodevi will involve a 18+18 km detour to Katra. Choppers have to be booked online (?) and you seldom get a seat on demand or on arrival, therefore a darshan will entail at least an extra day. Quote:
(1) Thanks |
27th May 2012, 20:50 | #555 | ||||
Thanked: 814 Times
By the way anyone here doing routes days similar to mine. If we are same locations , we can meet up Last edited by indian21r : 27th May 2012 at 20:53. | ||||
() Thanks |
