Old 1st June 2011, 17:03   #7726
TaureanBull's Avatar
Thanked: 329 Times
Re: The DSLR Thread
If thats the information you got from reading this thread, then you did not read the whole thing or your attention got caught only to the word "30 secs". Thats why I suggested, play with your camera, try atleast a 1 minute bulb mode on your D90 and see how it functions, probably you will also realize what was all this discussion about.
Listen Mr Shaju, you need to chill big time.
What you learned from thread I know very well.
How you read and interpret message also clears my doubt about your intelligence level. I NEVER said that I have read this thread entirely nor did I say that thats the only information I got. Thats what YOU interpreted.
My advise is that instead of trying to answer every question on the thread spend some time on your camera. That is if you are serious about photography.
I said before, I know what I am talking about. It seems like you came across the bulb mode for first time from your friends. I know you have lot of time to spend on the thread, please go ahead with counter accusations.
TaureanBull is offline
Old 1st June 2011, 17:09   #7727
Samurai's Avatar
Thanked: 50,165 Times
Re: The DSLR Thread
Last year I came across a special need where I had to capture and compare the intensity of new fog lights. I had to go to manual mode for that.
Check this: https://www.team-bhp.com/forum/4x4-v...ml#post2033183 (Mahindra CJ340 joins Team-BHP family)
Samurai is offline
Old 1st June 2011, 17:10   #7728
Re: The DSLR Thread
Originally Posted by TaureanBull View Post
Please refer to page 86 of D90 User Manual. "The shutter automatically closes after 30 minutes in BULB mode."
So all the asto photographers should throw there D90's?, since there exposures start at 15-30mins and go in hours.
Same in D7000 when using the "Remote Wireless remote".
With a wired remote, it will keep on as long as shutter is depressed.
So if you set bulb mode, and press shutter and release it after 1/2 second, you will get a 1/2 second exposure.
If you release if after 40 minutes, you will get 40 minutes exposure.
If you use a wireless remote to trigger shutter, it will take exposure upto a max for 30 minutes.
You can again trigger the shutter within 30 minutes to get a shorter exposure.
^^ Correct
Longer power is due to the extra battery inside and again extra FPS is still a mystery. D700 default 5 fps becomes 8 fps with the battery pack. Both batteries are never used simultaneously as dying one is shifted to the full power one through internal auto setting. Or do they suck from both batteries when 'burst'/CSh (continuous shooting high) is used ?
Its more about battery refresh times, life flash recycle times (4xAA vs 4xAA+external battery pack).
Moreover do you really need 8fps?, I ahve done motorsport, weddings, landscapes, street and never needed more than 3fps.
Let me tell you unless you dont read and be thorough with the manual you can not explore your piece to max. Not only camera but any item with a manual.
Hearsay can be very dangerous. If I read here and keep thinking that I can capture BULB mode only for 30secs then I am doomed. The functioning of each button, what and how it does must be clear to utilize the equipment to max.
BTW, I had just replied to a statistical question someone did not know correctly. I just referred to manual and quoted the page number so that all doubts are killed once and for all. That does not mean that I restrict myself to manuals and dont explore my equipment. But I explore it with manual first, rather than hit and trial method which may teach some one how to click a photograph but wont teach photography.
Just my opinion. Not to hurt anyone.
On the contrary, photography is learnt by hit and trail, spending 3yrs with a camera vs 3yrs photography degree, degree students still spend another 3yrs with camera working for free to LEARN via HIT AND TRIAL.
And AFAIK manual doesn't teach photography, none of the manuals i have touched even explained Rule of thirds let alone how to break it.
Technocrat : 1st June 2011 at 06:46. Reason: The note was from a moderator, While it takes for your posts to show, you can use multi quote option in the first post itself
I do use multi quote but if i made a post and want to reply to something else (lets say after 5mins), I have no choice left but to make another post. Or is there a way to edit posts, not yet approved ?
rajb3125 is offline
Old 1st June 2011, 17:16   #7729
shajufx's Avatar
Thanked: 832 Times
Re: The DSLR Thread
....you need to chill big time.
Sure sir, I will do that
As I said, I ask more questions than answering
....seems like you came across the bulb mode for first time from your friends. I know you have lot of time to spend on the thread, please go ahead with counter accusations.
Yes I am a learner, I will come across many new things in this stage and need to ask questions to help my learning. Thats the whole purpose of this thread. Counter accusations is not my standard of learning.
My answers in bold. If you want to continue quoting for no reason, this is my last post on this topic.
Raj, I never said I needed 8fps as I have never used burst mode till date, even while shooting moving birds. Battery pack was mentioned on the extra grip requirement, not for the other features. I think our CH (continuous high) gives 5 fps, thats more than enough for special situations.
shajufx is offline
Old 1st June 2011, 17:27   #7730
Thanked: 329 Times
To correct you. The exposure is from millisecs to 30 mins WITHOUT wireless remote. If 30 mins not enough for astro guys and can not buy a wired remote then they can follow your advise of throwing the piece. However they can still use it personal use.
Hello, Did I say learning about photography from manuals? Again thats what you are interpreting. I am saying about learning functions of switches and buttons for camera. Well, I dont tweak the buttons to find out what all it can do.
Classic example of what I am saying is by two examples;-
1. You did not know how much time the shutter can remain open so you will never use it for that purpose.
2. Secondly, my dear friend Shaju says that we can not control shutter in BULB mode by ML-3. I can quote the manual for reference. But let me tell you I learned from manual how to do it and D-90 does it! I have done several number of times.
I say again, I learn about my equipment from manuals INITIALLY and then explore the POSSIBILITIES thereafter. One must know the full potential of the equipment by knowing it. Half cooked knowledge is dangerous. This is all what I have to say.
Tanveer, wireless IR remote (ML-L3) does not function as 'press and hold' on bulb mode with D90, I have tried and failed.
Thanks for that. I hate war of words. I am sure you are as competent as you think.
I am quoting you here to tell you that it can be done. ML-3 can be used to hold the shutter open for upto 30mins/until pressed again. Manual says so and tells the procedure. I have done it several times.
If you need help do let me know.
Old 1st June 2011, 17:38   #7731
Speed Pujari's Avatar
Thanked: 399 Times
Re: The DSLR Thread
Well Shaju I just quickly moved the slider to check the video and did not go in detail. Anyway I could not quite understand how exactly a dumb device like battery grip can result in any failure due to firmware update or even responsible for Longer power backup , faster FPS yada yada..
This thought has crossed my mind plenty of times. So my guesses are (assuming this is an ethical system deployed by Nikon)
- The batteries(body and grip) run in parallel circuit supporting 8 fps in D300. If using without a grip, the single battery may be unable to support 8 'number' of shots, i.e. it needs a refresh after storing 6.5 of them. The grip comes for rescue in that case. So it is less about the speed (6.5 v/s 8 fps) and more about the battery juice for 1 sec.
- (Bad guess) The memory controller which writes the data to the CF card may operate fast on a slightly higher voltage thus faster fps.
But the guess made by you does make sense as well, remember Nikon is market leader in gimmicks.
My point is how come the Pentax K5 and Canon 7D are able to achieve similar fps without a battery grip and similar battery profile as D300 if this is a matter of juice.
EDIT: The other day I went I checked the MB-D10 and while trying the same I backed out the idea of buying. I was unable to justify the reason of spending 15k (grip + battery). fps gain did not felt so significant, and I can achieve same backup if I purchase an extra battery for 2k INR. Note that the maximum physical length lens I have is the 70-300 VR, the lens is light and does not poise any handling issue since D300 is itself big and bulky.
Speed Pujari is offline
Old 1st June 2011, 17:39   #7732
tsk1979's Avatar
Thanked: 23,495 Times
Re: The DSLR Thread
I will have to agree with Bull here.
From page 85 of D90 manual :
1. Set camera in remote immediate release or quick release mode
2. Press button on remote once to open shutter
3. Camera will take a 30 minutes exposure, or an exposure till the remote button is pressed again. So max exposure with wireless remote is 30 minutes.
Shaju, it has worked like this in most nikon cameras. I cannot fathom a reason for Nikon to change this just for D90. I think you had a defective remote, or defective camera.
However, if you use a wired remote, even on D90, you can take an exposure longer than 30 minutes. Infact as long as your battery lasts.
tsk1979 is offline
Old 1st June 2011, 17:47   #7733
Thanked: 399 Times
Re: The DSLR Thread
.... Battery pack was mentioned on the extra grip requirement, not for the other features. I think our CH (continuous high) gives 5 fps, thats more than enough for special situations.
You may need a grip on a D700 if you are using big profile lenses like 200-400 VR , 300mm f/2.8 VR etc.
With a 70-200 f/2.8 VR-II a grip is not required given the size of D700.
Old 1st June 2011, 17:52   #7734
shajufx's Avatar
Thanked: 832 Times
Re: The DSLR Thread
....my dear friend Shaju says that we can not control shutter in BULB mode by ML-3........
Oh my dearest friend, I have only one simple request to you, please read the post before quoting with a reply. Did you read my post as ML-3 or ML-L3 ? Please read again, you are talking about two different remotes.
I see Tanveer's post too, I am not sure if ML-L3 ( 500 bucks) can do that, if it can, may be I had a faulty remote. But again, ML-L3 has a rubbery cheap button which has no hold option. Are you guys sure about it ?
shajufx is offline
Old 1st June 2011, 18:14   #7735
Thanked: 329 Times
Re: The DSLR Thread
I got my remote for Rs 400/- original Nikon. Its ML-L3.
You dont have to hold the button. You have to press once to open shutter and another time to close it. It just replicates the action of camera button. Simple enough. I stand corrected its ML-L3and ML-3 both.
I will write a step by step procedure at night. You may have missed few things.
BTW the manual says ML-L3 remote and quotes some two response modes. Quick Response and Delayed mode. I think they have messed it up because ML-L3 has only one press button. Nevertheless it does the job as I said before.
Old 1st June 2011, 18:15   #7736
tsk1979's Avatar
Shaju, none of the WIRELESS remotes I have owned have a "hold" button. Not in Canon, and not in Nikon.
When you wirelessly trigger the camera using the IR port, one click of the button will open shutter, and another click will close it.
I suspect, you are holding the button too long. So the camera may be getting "two button presses" instead of one.
I got my remote for Rs 400/- original Nikon. You dont have to hold the button. You have to press once to open shutter and another time to close it. It just replicates the action of button. Simple enough. I stand corrected its ML-L3. Obviously ML-3 does it too.
Delayed release is not a function of the remote(like in Canon world). The secondary dial has the delayed or instant release functions.
tsk1979 is offline
Old 1st June 2011, 18:26   #7737
Thanked: 329 Times
Re: The DSLR Thread
There are four things you will have to check:-
1. Camera in Long Exp. NR mode - ON.
2. Shtter release mode - Wireless.
3. Mode - M
4. Shutter Speed - "Bulb" or "--"
You will hear a click of shutter open as you press it once which you can not miss. You click once more to close the shutter.
The two action of button is in BULB mode. For any other shutter speed it should open/close with one button action.
If you ensure all these things and still dont succeed, one of your thing is faulty-camera or remote.
Old 1st June 2011, 18:37   #7738
shajufx's Avatar
Thanked: 832 Times
Re: The DSLR Thread
.....I suspect, you are holding the button too long. So the camera may be getting "two button presses" instead of one...
Yes, I get your point, I might have pressed that rubber too long ( long press for long exposure ). Anyway D90 is no more with me to use that feature Thanks for those ebay and dealextreme links, I am seriously checking the cheap and best options.
shajufx is offline
Old 1st June 2011, 19:03   #7739
tsk1979's Avatar
Re: The DSLR Thread
3. Mode - M
Actually, you do not need to keep long exposure NR on. Its optional. I prefer to take my own dark frame shot, rather than let camera do the long exposure noise reduction.
tsk1979 is offline
Old 1st June 2011, 22:41   #7740
VW2010's Avatar
Thanked: 4,567 Times
Re: The DSLR Thread
Many prefer this way. The camera just takes twice the time to finish that picture. Hate it
VW2010 is offline
