Old 16th March 2012, 11:01   #676
DerAlte's Avatar
Thanked: 2,920 Times
Re: BSNL BroadBand Issues
The trick is to go (physically) to the AE of your telephone exchange, not talk on the phone. They will usually direct you to the stores, who will replace your modem with another one, sometimes similar of another make. They usually keep getting returns from cases where people have cancelled their connection.
DerAlte is offline
Old 16th March 2012, 16:33   #677
Raccoon's Avatar
Thanked: 116 Times
Originally Posted by Ford5 View Post
I am facing the same on/off switch problem. I never used it from the beginning but last two days i had to reboot the modem due to frequent disconnection and what not. I feel it's going to come off very soon. Mine is a teracom modem.
After using 2 Teracom models, I'm inclined to think its not a good modem in several ways. For eg. despite port forwarding, it does not work well with P2P clients. UTStar was best amongst those I'v used, and even a "knowledgeable" BSNL engg. told me UTStar and Huawei are amongst the best they have had. Then they switched to lesser stuff. Sadly, I don't think these are even available in the market.
But they they have no stocks, so they will only give used ones. And I'v had 3 used and useless modems given to me in a row. The 3rd one is still with me... just not getting the time to go there and getting another dud piece. They dont even test the used modems they recirculate. Pathetic BSNL.
Raccoon is offline
Old 11th May 2012, 14:06   #678
S_U_N's Avatar
Thanked: 418 Times
So, after several months of trying, I finally have my account setup correctly on the Selfcare portal.
For western states, it is SAP NetWeaver Portal
This portal works only with IE (I use compatibility mode in IE 9).
The first thing you need is customer ID (BSNL changed the customer ID sometime in March). I was trying with the older customer ID and it used to get rejected.
This morning, I called up 1500 for customer ID and the representative said "Your ID is not present in our system, Sorrry!".
Then I checked my April, bill and noticed that the ID starts with 1 instead of 2 (which was present in March bill). Used that 10 digit number and completed the remaining registration steps.
I got an email after 10 minutes with my login and password.
Now, I can see my landline and broadband details on the portal.
Users of datafox plugin should make sure that they select the correct server (selfcare.wdc.bsnl.co.in). By default, ndc will be available in the drop down list. Change that n to w if you are from western part of India.
Datafox works fine after that.
S_U_N is offline
Old 11th May 2012, 14:53   #679
Jaggu's Avatar
Thanked: 17,296 Times
My connection is randomly becoming slow these days and speedtest shows abnormally long pings. Anything that can be sorted at my end or bsnl has to fix?
Line strength, noise all under normal limits and that too randomly. Somedays it works fine.
Jaggu is offline
Old 11th May 2012, 14:58   #680
Sheel's Avatar
Thanked: 15,118 Times
@Jaggu - Get the BSNL line man to check if all is fine.
I too suffered hugely because of the lax on part of BSNL officials. They changed everything, wires, modems & what not. The tech guys had to personally visit & after changing the ZTE port (I specifically remember) the problem cured. My modem's DSL lamp wasn't getting stable.
As far as problem sorting goes, the lower level workers do a good job. They send a man to inspect if a line is dead or your internet connection is acting up (on the same day the complaint is logged) But, I had to suffer for close to a month.
Sheel is offline
Old 11th May 2012, 15:25   #681
Bluengel180's Avatar
Thanked: 752 Times
Return your modem back to BSNL. they will refund your security deposit and cancel your rental (unless you purchased it ). use that money to buy a good branded modem from the market .setting them up is easy
Bluengel180 is offline
Old 11th May 2012, 16:20   #682
S_U_N's Avatar
Thanked: 418 Times
I have been using the basic model modem from BSNL for 4 years now - never had any modem issues.
I am not saying that modem defect is ruled out in the above case, but the default ones are not bad as such.
S_U_N is offline
Old 13th May 2012, 16:57   #683
clevermax's Avatar
Thanked: 2,897 Times
Slightly off topic, but does anyone know where and how to book a complaint for Bsnl WiMax connection? Any links appreciated..
clevermax is offline
Old 13th May 2012, 17:35   #684
deepclutch's Avatar
Thanked: 164 Times
I wanted to change broadband plan to "BBG COMBO 850 ULD" in Kerala.
Tried the link Udaan: UDAAN PROJECT -- BSNL through Which We can request a plan change. Immediately got a docket number and contact of BSNL Engineer messaged to My cell number.
But, A BSNL Employee called Me to write a application form in plane white paper signed asking for change of plan with details and give it to BSNL Centre. how efficient?
Anyone here paying BSNL bills through http://portal.bsnl.in/ or through selfcare(CRM) . how is the experience. BSNL site sometimes not even accessible so want to know how reliable is the payment procedure through NEFT.
deepclutch is offline
Old 13th May 2012, 18:37   #685
gopikb's Avatar
Thanked: 407 Times
deepclutch, I have been using the portal.bsnl.in to pay my bills in Bangalore and Parents bill in Tuticorin for the past one year. Had no issues so far.
gopikb is offline
Old 13th May 2012, 23:49   #686
deepclutch's Avatar
Thanked: 164 Times
I had previously paid through BSNL customer care centre on last Thursday. CRM reflects the change. but, when I checked http://portal.bsnl.in/ it is still showing the old amount without crediting the payment made directly to BSNL. how BSNL manages "secure payment" when their own selfcare sites showing different balance amount?
I will wait for 2 days to see if the payment is reflected on http://portal.bsnl.in/ .
Old 14th May 2012, 18:15   #687
Jaggu's Avatar
@Jaggu - Get the BSNL line man to check if all is fine..
Thanks man, seems to have been sorted out since last few days, will wait for the issue to repeat so that i can lodge a complaint. Issue would be if the connection is working fine when the line man visits
Jaggu is offline
Old 14th May 2012, 18:25   #688
Vid6639's Avatar
Thanked: 44,137 Times
Does it happen only when it is raining? My BSNL landline is dead when it is raining or during a powercut. Then it takes a few days and several complaints to get alright. Next powercut or rain it's gone again.
Am I glad I went for airtel broadband when I moved into this house.
Vid6639 is offline
Old 14th May 2012, 18:28   #689
Jaggu's Avatar
Nope very random, on the contrary i noticed that speeds are better during longer power cuts. Maybe less load at exchange end.
Jaggu is offline
Old 14th May 2012, 19:52   #690
Sheel's Avatar
During rains the net connection goes for a toss. A bit if palm-grease and you get a fresh wire from the box to your home and its done.
It usually happens with loose ends and rain worsens it.
Sheel is offline
