Old 15th May 2014, 21:34   #811
devilwearsprada's Avatar
Thanked: 1,445 Times
re: On Wi-Fi & Routers
Guys, got the WNR3000P or similar repeater/range extender from Netgear. Works pretty smooth, the wifi connectivity is much much better than my belkin.
The best part, it fits directly into the socket so no ugly wires as such!
devilwearsprada is offline
Old 26th May 2014, 18:03   #812
dass's Avatar
Thanked: 943 Times
Experts.. which of the below two are better?
TP-Link TL-WR740N Wireless Router
D-Link DIR-600L Wireless N 150 Cloud Router
I have a BSNL connection and the current wifi+adsl router is around 6 years old and I get a feeling that it has outlived its age.
My primary requirement is consistent speed and good coverage over my 2 BHK flat. The router would be kept in the hall, on the TV unit, infront of a LED TV.
dass is online now
Old 27th May 2014, 21:37   #813
Thanked: 268 Times
Buy D-Link DIR-600L Wireless N 150 Cloud Router
mithun is offline
Old 1st June 2014, 20:09   #814
turbodude's Avatar
Thanked: 263 Times
I will suggest to go for TP-Link router. It has good range for wireless, better than D-Link. One more suggestion, keep the wireless channel fixed at 1. Observe for half an hour and if you are able to get uninterrupted network keep it like that. My friend is telecom engineer and he said channel 1 has highest range.
turbodude is offline
Old 2nd June 2014, 15:06   #815
dass's Avatar
Thanked: 943 Times
Thanks TD, How do I chose the channel?
dass is online now
Old 2nd June 2014, 15:21   #816
Fillmore's Avatar
Thanked: 597 Times
I don't think the range is high on channel 1.
It depends on how many wifi networks in your vicinity are using the same channel to broadcast. The more networks using the same channel will cause you to get a lot of drops and interruptions.
You can do one thing, install an app like Wifi Analyzer (Android) , am sure you will find other apps / software's that you can use. It will show you how many wifi networks are in the vicinity and at what channel are they operating.
Then set your router to use a channel that is least used.
Fillmore is offline
Old 2nd June 2014, 15:36   #817
Safety is Param's Avatar
Thanked: 462 Times
Once at home, open a browser to http://192.168.1.1 from a system that is connected to a wired connection.
If it's BSNL, and you haven't changed the default password, the login will be "admin" and the password will be "admin" too, both without the quotes.
Once in, go to Wireless / Wireless Settings / Advanced Settings and see if you find the Channel Number section. Also, please make sure you have secured your wireless connection using a strong "key".
I am sure once you are logged in, you will figure these out. Also, take a back up of your current modem configuration (available on the left side Menu) once you are satisfied that everything is working as expected.
I use an app "Wifi Analyzer" on my Android phone that clearly tells me which channel is the least congested. I make sure to run my wi-fi on that channel.
If you have 6 flats on a floor, and all run on channel 1, that is not an ideal situation to be in.
You can get started by referring to the links below, and making suitable modifications at your end - these are for illustration purpose only
http://www.techno18.com/2011/05/how-...wifi-and-wlan/
http://tech.firstpost.com/watch-vide...xggaH6tmc.html
Safety is Param is offline
Old 2nd June 2014, 15:42   #818
turbodude's Avatar
Thanked: 263 Times
Every router has its own web server. By default its located at http://192.168.1.1 (check your router manual for details, it varies with model). You can log into the router and in wireless settings section channel selection can be done.
I have addressed this issue already. If there are too many devices transmitting on this channel, user will experience packet drops and that's why you have to observe for half an hour. Many routers have channel setting at automatic by default hence your router transmitting at channel 1 will force nearby routers to select another channel.
Old 8th June 2014, 02:11   #819
mashmash's Avatar
Thanked: 157 Times
My 5 year old dlink dir 300 died last night. It served me really well providing connection to 4 mobiles, 2 tablets and 4 laptops. Internet connection used is ACT Broadband .
Which the ideal replacement router? I need good Range in a 3 bedroom flat of size 1300sqft, Reliability as I work from home and 1 usb port to connect either an external hard disk, 3g dongle or a usb printer.
Looking for an extremely value for money deal.
MaSh
mashmash is offline
Old 8th June 2014, 10:14   #820
mav2000's Avatar
Thanked: 316 Times
My rt n16 recently died and I got an n56 from Asus as a replacement. I just could not get it to work as stable as I wanted it to. Finally I returned that and bought a n14uhp. This is a beast of a router and easily covers two floors in my house. I am sure it goes to the upstairs flat as well. It does not have all the extra things that some people may want, but it has good range and that's very important for me. The connection is also very stable.
mav2000 is offline
Old 12th June 2014, 19:55   #821
Thanked: 716 Times
My TP-Link Router is dying in less then an year , Wired LAN interface and ADSL modem is working fine but WiFi SSID disappears randomly and also WiFi indicator LED goes blank , If I switch off and let the router cool for an hour it comes up again may be around 60% of the time.
Earlier I had buffalo G router and it worked flawlessly for 6 years before I replaced it with TPLink N router. I had similar heating issue with Huawei ADSL modem which I used with buffalo G router
So lessen learnt say no to Chinese router / modems.
amitk26 is offline
Old 12th June 2014, 20:52   #822
mashmash's Avatar
Thanked: 157 Times
My TP-Link Router is dying in less then an year.
Oh thats not good news for me. I recently bought TP-Link wifi router-TL-WR740N. Its been 4 days and so far its been running OK, serving 5 mobiles and two laptops. The router is Always On, except for a few minutes when change over happens between main power and generator backup. I however had higher expectations on the signal spread, considering it has something called 5dbi antenna. I see no difference compared to the DLink Dir 300 it replaced. My Dlink served me extremely well for good 6 years. The thundershowers killed it.
I notice fluctuating wifi signal on my devices, also the strength is lesser than what was provided by Dlink. Is there any setting that can improve the strength?
MaSh
mashmash is offline
Old 16th June 2014, 20:31   #823
arin_12's Avatar
Thanked: 103 Times
Currently I am running BSNL broadband connection with Modem and router separately. Both are old now. I want to replace both of them with single instrument Modem + Wireless router. Can you suggest something good with ~ 1500 Rs.
arin_12 is offline
Old 16th June 2014, 22:15   #824
akshay87kumar's Avatar
Thanked: 42 Times
It will perhaps be difficult to find something within Rs. 1500
D-Link DSL-2730U is the cheapest router I personally know. Try finding some routers from TP Link.
akshay87kumar is offline
Old 19th June 2014, 20:22   #825
dre@ms's Avatar
Thanked: 206 Times
Currently own a Belkin wifi router, been working for the last 4 years. Only hiccup is the wifi range. Now with my Beam connection, facing lot of interruptions. Had to restart to correct it.
I am in a 2bhk, the router is placed in the middle(hall to dining area) at 2ft roof level. I am not getting strong signal in my master bedroom corner areas which is atleast 15ft apart.
Which router would suffice my need?
dre@ms is offline
