Old 23rd January 2019, 22:27   #151
drhoneycake's Avatar
Thanked: 1,798 Times
Re: Comprehensive guide to LED Headlight upgrades
I think the link to that item is this.
Search for "iLens" in AliExpress, you'll get the item.
Yup this is the one. It’s called “iLens”. It produces a perfect 5000K light. Instant on and the flash is very prominent. People give way instantly.
P.S: ignore that line at the bottom, that’s a huge crack on my windshield
Here are some output shots
Comprehensive guide to LED Headlight upgrades-480b3c60e7a04fc3974fbaa1e796387a.jpeg
Low beam
Comprehensive guide to LED Headlight upgrades-a1df4d2784884a488236cd96b38b3688.jpeg
High beam
drhoneycake is offline   (9) Thanks
Old 23rd January 2019, 23:56   #152
Thanked: 446 Times
Does it have any bulbs in there? What do we do if the LED conks off?
suku_patel_22 is offline
Old 24th January 2019, 20:19   #153
Arsi's Avatar
Thanked: 147 Times
These are H4. Any link to H7? Plus, these are only lenses. Any suggestion for the same sized LEDs that will fit these perfectly? Will these work for global Fiesta?
Arsi is offline
Old 24th January 2019, 21:39   #154
They have LED chips inside that emit the light that is reflected onto the road by a reflector bowl. No bulbs of any sort. If and when the LED conks off, the projector will need to be replaced but I don’t see that happening. The newer cars all use LED projectors.
They are universal projectors, they donot have “H” numbers. They need to be retrofit into existing headlights. They will fit into any modern headlight.
drhoneycake is offline   (1) Thanks
Old 24th January 2019, 22:09   #155
Arsi's Avatar
Thanked: 147 Times
Oh great. From your pics, the light from the projectors seems awesome. I am looking forward to installing these in my Fiesta low beam socket. Plus, another pair of non-projector LEDs for high beams so that while on high beam, both these and the LEDs in high beam will glow.
Arsi is offline
Old 26th January 2019, 10:44   #156
sgiitk's Avatar
Thanked: 4,809 Times
One can expect the LED lamps to last for the life of the car. My take is, if it does not fail in the first month or two then one can expect it to last for the life of the car. I am assuming the charging system is Kosher.
sgiitk is offline   (3) Thanks
Old 31st January 2019, 00:25   #157
supertinu's Avatar
Thanked: 1,408 Times
From the pictures the spread looks outstanding. Hows the reach with high beam on the highway?
My experience tells that LEDs on high beam dont work well unless very focused since they tend to disperse more. I have reverted from LEDs in my car's high beam to Osram night breakers. One short drive in the night on a dark highway was enough to help make that decision.
From the design of the LED that i saw in the aliexpress pics, it has a big heat sink and a fan to cool things down. The biggest failing point usually are the LEDs when they over heat. Keep the heatsink and fan clean to enable optimum cooling which otherwise will deteriorate with time. As pointed by Sir the electronics hopefully is good enough for automotive rating.
supertinu is offline
Old 31st January 2019, 11:58   #158
Thanked: 58 Times
Hello everyone, I was looking to upgrade stock headlights of my car to LED. My car happens to be an old Skoda Octavia 1.9 Rider. Stock lights are pathetic to say the least. Can any of you suggest which leds to go for? currently headlight bulbs are H4 type and fog lamp projector bulb type are H3 type. I wouldnt mind going to a dedicated shop in bangalore too. I am attaching a picture of the car for reference. Thanks
CarMaster is offline
Old 3rd February 2019, 16:18   #159
Parth46's Avatar
Thanked: 577 Times
Given the plethora of options in the LED space, I'm looking to source H11 low beam LED lights for my Honda City 2014.
Based on thoughts in this thread, looking at this Auxbeam option available on this link : https://www.amazon.in/Auxbeam-Headlight-Headlights-Conversion-PHILIPS/dp/B01L1NLSPA/ref=sr_1_1?ie=UTF8&qid=1549177835&sr=8-1&keywords=Auxbeam+H11+LED+Headlight
A doubt I had was on chip type : one image says COB chip (which is not the latest gen) whereas another image says latest CSP type chip. The overall design seems to be CSP though, and is similar to the images shared by supertinu etc. It's in a 2x3 grid though, rather than 1x3.
Would this be the right product for H11 low beam requirements?
Another similar product I'm looking at this, on Aliexpress, which between this and the Auxbeam above would be better : https://www.aliexpress.com/item/2Pcs...3ddb4c4dVZt7TU
Parth46 is offline
Old 7th February 2019, 09:21   #160
sagarpadaki's Avatar
Thanked: 6,864 Times
HLXG products on Aliexpress
A word of caution regarding the HLXG official store products on Aliexpress. They seem to have quality issues.
I had ordered a pair of H11 4300K LED. One of the bulbs stopped working within 10 hours of operation. So i contacted the seller and he agreed to send me a replacement if i pay the shipping costs. The replacement also turned out to be faulty with one of the bulbs conking off within 3 hours of operation.
On the other hand, the H27/880/881 LED i had ordered from CNSUNNYLIGHT is going strong after using them for 50 hours and a few highway drives.
Definitely will not order any more HLXG products after incurring a loss of $44. Wanted to share the experience here for the benefit of others.
sagarpadaki is offline   (4) Thanks
Old 7th February 2019, 09:27   #161
Parth46's Avatar
Thanked: 577 Times
Re: HLXG products on Aliexpress
Thanks for this feedback. In fact, after I wrote my post (right above yours), I did a lot more research and it seems Oslamp is a better bet, product quality wise. They have a huge dedicated store, right within Aliexpress, and have a new fanless series and I'm looking at something like this now, in H11 type : https://www.aliexpress.com/store/pro...pots_2603520.5
Parth46 is offline
Old 7th February 2019, 09:51   #162
hserus's Avatar
Thanked: 9,336 Times
I endorse this. I have a full set of cnsunnylight on both my cars and they're pretty good performers so far over 20k km across both cars. Of course not much of that is night drives but when I do drive at night they've performed flawlessly.
India's climate needs both a fan and a heat sink I guess which cnsunnylight has - heat sink only or fan only models don't work too well.
hserus is offline
Old 7th February 2019, 10:11   #163
archat68's Avatar
Thanked: 643 Times
I have a Oslamp in my headlamp assembly (H4) and a CNSunnylight in my foglamp assembly. Both are with heat sinks only and without fans. Both are going strong since last two years although my usage is limited to one hour daily night drive only.
archat68 is offline
Old 7th February 2019, 11:09   #164
Mr. Nobody's Avatar
Thanked: 637 Times
I too am using 2 pairs of HLXG ones and they are running well with over 100+ hours of use till now. Mine were the 6000k ones, one was fanless and other are the lumiled fan based ones.
Mr. Nobody is offline
Old 7th February 2019, 11:30   #165
Good to hear that. I do not know if mine is case of sheer bad luck or the quality of HLXG has degraded over time.
For me I wanted 4300K and CSP/Flip LED . CNSUNNYLIGHT did not have that combination in H11. Hence had to go with HLXG
Good to hear that!
