Old 12th May 2016, 22:55   #1081
AutoIndian's Avatar
Thanked: 5,042 Times
Re: Mahindra TUV300 : Official Review
Hey ntomer, I had faced exactly the same situation about a month back, suddenly loosing substantial power and knocking badly. After I stopped the car for a tankful and started again, the problem completely vanished. I initially thought this could be because of low fuel, but then as you mentioned, switching off the engine for refueling could have made the trick.
Today again I faced this issue. When I started for office in the morning the engine note was different. Car had already run 630 kms on the tankful and the DTE was showing 143 kms, so in all likelihood about 10-12 litres of diesel was balance in the tank. On pressing the accelerator I could feel sudden loss of power and engine was sounding very coarse as if it was shouting and yelling at me that it was hungry and needed a quick dose of diesel. I refueled the car, tank gulped 48.57 litres of diesel (mileage of 13.09 kmpl, 100% city driving with full AC). Once its stomach was full it started behaving normally.
This has happened twice in the last six months and both times it has happened when the tank was less than 1/4th full. After making the tank full, it has vanished. Not sure how to co-relate this, but could it be possible that sensing low fuel level the ECU wants to preserve the fuel as much as possible and reduces the fuel supply to the injectors resulting in undue coarseness?
AutoIndian is offline   (1) Thanks
Old 12th May 2016, 23:31   #1082
ezee's Avatar
Thanked: 214 Times
It has nothing to do with the fuel level. Have you got the latest ECU update specially available to handle this problem? Also get your Fuel Delivery Module (FDM) replaced.
ezee is offline
Old 13th May 2016, 08:44   #1083
AutoIndian's Avatar
The FDM was replaced during the first service itself and the ECU too was reflashed. Since this has occurred only twice till date and both times when the fuel level in the tank was low I am assuming some correlation between the two.
Old 13th May 2016, 10:21   #1084
Thanked: 108 Times
AutoIndian, I drive till DTE is in the 70 to 100 range every time and have never observed any difference in car behavior. As mentioned in one of my old posts, I once drove till DTE reached 19.
Suggest you visit the service center next time you face the problem. Could be an issue with FDM again.
rajpvrm is offline   (1) Thanks
Old 13th May 2016, 10:46   #1085
ezee's Avatar
Thanked: 214 Times
May be it needs replacement again, as lot of people reported repeat modulator replacements.
Service centre people will not believe in your explanations until you reproduce the problem in front of them but its next to impossible to simulate it again as it auto fixes after some time.
What I did was, I recorded a video each time that truck sound started appearing and showed them the video, uploaded to YouTube, sent to Zonal Head and then only started believing that there is some problem.
ezee is offline   (1) Thanks
Old 13th May 2016, 12:38   #1086
ToyotaFan's Avatar
Thanked: 480 Times
Originally Posted by procrj View Post
A few cars that use a 3 cylinder - mini cooper, bmw i8, Ecosport 1.0L ecoboost and many more. !
I completely agree with the TUV being a practical workhorse but comparing the mHawk with the BMW i8, mini cooper or even the engine of the year ecoboost is surely an overkill. These engines are state of the art and have been acclaimed for that. The mHawk is a lacklustre engine which goes about its duty week without being exciting or very fun to drive. Comparing it to the i8 or such cars will give wrong impression to people reading the forum hence commented. Please don't take it personally.
ToyotaFan is offline
Old 13th May 2016, 15:14   #1087
airbus's Avatar
Thanked: 3,496 Times
With the launch of new mHAWK100 engine for TUV300, do we have any option to upgrade our existing TUV300 to mHAWK100? Also, looks like second row seats are a bit better now with more under-thigh support.
airbus is offline   (5) Thanks
Old 13th May 2016, 15:57   #1088
Thanked: 108 Times
Not sure if upgrade is possible, I would love to go for it.
Yes, the second row seat has been improved and child seat mounts have been added. See below press release from Mahindra.
In the video the seat looks slightly more inclined, with better thigh support. Looks like the thickness has been increased too.
There was a speculation that the upgraded TUV300 will also get NuvoSport's touch screen. Surprisingly, that didn't happen.
Edit: Guess M&M will not offer the mHawk80 to mHawk100 upgrade officially just to make the T8 mHawk100 option more lucrative. T6 and lower variants continue to come with mHawk80 engine and they wouldn't want everyone to come and upgrade.
Mahindra TUV300 : Official Review-capture.png
rajpvrm is offline   (2) Thanks
Old 13th May 2016, 16:12   #1089
procrj's Avatar
Thanked: 5,740 Times
The engine and mechanicals are the same as the mHawk80 but in a higher state of tune, which is what the Nuvosport is running on. If you look at Nuvosport reviews, engine noise is said to be higher than the TUV running on mHawk 80.
All said and done, I am guessing that the devils (the little details) in the new mHawk 100 are yet to be sorted and hence my personal preference is to stick to the mHawk 80. Given my driving style, I am not sure how much of a difference 10Nm of additional torque and 18 BHP of power will make. M&M should have taken a little more risk and thrown in the new 1.9L 'Delhi' special into the TUV. The engine bay does seem to have enough space to fit a larger engine. Now that would have been something!
procrj is offline   (4) Thanks
Old 13th May 2016, 16:23   #1090
Thanked: 108 Times
I second that. As per M&M revised specs, the mHawk100 offers torque of 240 Nm in the range 1600-2800 rpm compared to the 230 Nm torque in the 1500-2250 rpm for mHawk80. The RPM range is on the higher side and considering that the engine is otherwise exactly same higher RPM will lead to more noise.
Old 13th May 2016, 17:05   #1091
ezee's Avatar
Thanked: 214 Times
The problem is with TUV T8 AMT owners where their engine option (mHawk80) has been discontinued (no more listed on specifications page). They knew that AMTs are causing problems with their inconsistent behaviour, so they decided to stop production and come up with mHawk100 with refined AMT working.
The increased torque and bhp in this engine might be serving as a better motor for their AMT systems. But what about those who purchase just now, mine is only 2.5 months old and now discontinued. There will be no takers of that now.
Its clearly mentioned in their PR that AMT is lot more smoother now. We have been cheated and some of us even considering option of consumer court as well. It is high time for Mahindra to come up with some sort of upgrade solution for their AMT owners.
ezee is offline   (3) Thanks
Old 13th May 2016, 18:29   #1092
Sirvoicar's Avatar
Thanked: 192 Times
The TUV300 was designed as 84bhp car. However market forces have specs listing 1500 Diesel motor giving 100 bhp (Maruti Brezza and the recent BRV). This upgrade to 100bhp is a marketing gimmick for new buyers. There is no hardware added to the earlier MHawk80, just a software tune up and a new badge(and a new price). Otherwise they would have dropped the 80bhp model altogether.
It would be prudent for existing owners to get their cars stabilised for optimum performance, rather than think of 100bhp. The new tuning may throw up some new niggles but I am certain the 100bhp tuning will drop the fuel economy further by 1.5 -2 kmpl.
Sirvoicar is offline   (1) Thanks Received Infraction
Old 14th May 2016, 13:56   #1093
Thanked: 9 Times
How does the AC fare in this? I have read it is chilling for the 1st row. But how is it for the 2nd row, and maybe whenever there are a couple of folks in the jump seats?
Would be nice to know this from owners of TUV in cities of high heat and humidity.
Also, with the new 100 bhp on offer, what will be the turnaround time for deliveries, considering that people who had booked earlier the 80, would either be offered to upgrade or would themselves opt to.
sawah is offline
Old 14th May 2016, 15:01   #1094
Thanked: 1,931 Times
If i m not mistaken, the turbo system is entirely different betweent th etwo engines. Request you to check that.
1.2TSI7DSG is offline
Old 15th May 2016, 00:46   #1095
procrj's Avatar
Please do share the source for this as almost all reviews mention that Nuvosport uses the same parts as the TUV300 and the difference is power is a result of software tuning.
procrj is offline
