Old 18th September 2014, 00:37   #7516
ampere's Avatar
Thanked: 13,628 Times
Re: All Roads to Kerala
Originally Posted by dhanushmenon View Post
Travelling with wife and kids.
Vehicle is XUV.
Starting before 0700 not feasible.
If all you need is good roads and no traffic at the cost of distance then do:
Mysore-Nanjangud-Chamarajanagar-Sathyamangalam-Annur-Avinahsi-Palladam-Pollachi-Vaddakkencherry-Trichur bypass - Angamaly - Ernakulam.
Old 18th September 2014, 07:33   #7517
dhanushmenon's Avatar
Thanked: 4,356 Times
Have you considered Mysore-Chamrajanagar-Sathyamangalam-Coimbatore-Kochi ? That may be a better option I think.
Thanks NPV and ampere.
I would take that route then.
But, why not Annur- Coimbatore- Palakkad- Kochi?
I thought that stretch was repaired.
dhanushmenon is offline
Old 18th September 2014, 07:38   #7518
NPV
NPV's Avatar
Thanked: 11,212 Times
On Coimbatore-Walayar stretch, the L&T bypass is not great, bumpy due to multiple patch works (and narrow for the kind of traffic there). Walayar work is not complete so not great. Plus there is widening work in progress between Palakkad-Alathur and even beyond I think, so if you're doing day time drives this entire stretch is best avoided.
Look up some earlier posts (recent ones) on this thread, like this.
Palladam-Pollachi-Vadakkencherry is excellent and from there you can continue on NH47 to Kochi.
NPV is offline   (1) Thanks
Old 18th September 2014, 08:16   #7519
ampere's Avatar
It will be mess I think with the rains. Anyway you know better on those stretches. Another reason Annur-Avinashi, was you avoid all portions of CBE also.
Old 18th September 2014, 10:24   #7520
coolclouds's Avatar
Thanked: 519 Times
Hey Jain,
How is Mysore to Coimbatore?
How much time would it take if I start at around 0700 hrs?
Would you suggest
1) Mysore- Gundlupet- Ooty- Coimbatore- Kochi;
2) Mysore- Gundlupet- Nilambur- Kochi; OR
3) Mysore- Gundlupet- Sulthan Bathery- Calicut- Kochi?
Vehicle is XUV.
Chamarajnagar to Coimbatore (Annur) is excellent and scenic. Mysore-Chamarajnagar also should be fine. It took 4 hours and 30 mins from Kanakpura road/NICE road section (Bangalore) to NH47 (Karumathampatti) without exceeding 100.
Since you are traveling during day time, I suggest Chamarajnagar-Annur-Karumathampatti-Pollachi-Vadakkancherry-Ernakulam as the day traffic on all other routes will be higher.
-Annur-Avinahsi-Palladam-Pollachi-.
I think we can directly go to Pollachi without touching Avinashi and Palladam via Karumathampatti. Have seen Pollachi board throughout Satyamangalam-Annur-Karumathampatti stretch.
Last edited by benbsb29 : 18th September 2014 at 11:19. Reason: Merged posts as requested.
coolclouds is offline   (1) Thanks
Old 18th September 2014, 11:17   #7521
Thanked: 639 Times
Originally Posted by sachinpk View Post
Perhaps I may try the Rayacottai, Palakkode route. Earlier plan was to travel via Chamarajanagar & Sathyamangalam, but I feel it may take much more time. Plan is to have a "run through" with minimum halts only for food and bio-breaks.
No way. With sedate driving under 100-120 kmph the time required to reach Coimbatore on the NH209 route (Between 4.5 to 5 hrs to Karumathampatti) is almost comparable to going via the 4 lane / 6 lane highway. If you're deviating through Rayacottai-Palacode etc, I'm sure it will take much longer.
You see boards for Pollachi all over NH209 is because NH209 does pass through Pollachi (The Coimbatore-Pollachi-Dindigul Road is the continuation of the NH). But for sure one wouldn't want to go through Coimbatore city because it can easily eat up 1 hour extra.
The deviation from Annur to Karumathampatti is a State Highway (SH165), and while excellent till Karumathampatti it is a little bit messy around Somanur (about 4-5 kms further south) where a railway overbridge was under construction. If that construction isn't complete yet, it can take about 10-15 minutes to clear that small town. From there till Karanampatti (where it hits the Coimbaore-Palladam highway) is fine. The SH continues further to KamanaikenPalyam where it joins to the Palladam-Pollachi road, but I've never driven that stretch, so no idea about the conditions. (But looking at the general condition of the road from Annur till Karanampatti, it should hopefully be good).
Another option is the one that deviates from NH209 at Puliampatti and goes to Avinashi via Sevur. It is 3 or 4 kms longer than the SH165 option, but may perhaps be faster because Avinashi -Palladam-Pollachi is known to be in good shape all through with the ROB at Velampalayam open now.
kala is online now
Old 18th September 2014, 14:04   #7522
Thanked: 1,518 Times
Thanks for the clarification. I had a small mental block there as well . Because I take the Chamarajnagar to goto Calicut which is a shorter journey, and assumed that if I take this route to any where else (to mid-Kerala) it would be really a long and stressful drive. I have kept the Rayacottai-Palacode as a Plan B, because it helps me to have breakfast at the Saravana Bhavan in Vaigundam, Salem.
Is this route reasonably good? I had asked the same question some time back. Because I don't want to get any where near the Karumathampatti, Coimbatore.
So will plot both the routes (Chamrajnagar) and Rayacottai->Palacode on my GPS and keep it handy.
sachinpk is offline   (1) Thanks
Old 18th September 2014, 14:25   #7523
Thanked: 639 Times
Not sure about the road conditions between Puliampatty and Avinashi via Sevur since I've never travelled that way. But considering the general state of interior roads in TN, the odds of it being good is pretty high. (And it isn't that long a stretch anyway - around 30 kms I think). May be someone who has taken that road in the recent past can clarify ?
And as for Karumathampatti - don't think there's too much to worry about that since you don't need to get on to NH47 or go towards Coimbatore. SH165 is a very good road surface and the traffic is quite sparse as well - The traffic density is much less than the Sathy-Annur section of NH209. The only issue with that route is the ROB at Somanur - hence my suggestion of going via Sevur .
kala is online now   (1) Thanks
Old 18th September 2014, 14:35   #7524
DWind's Avatar
Thanked: 238 Times
Was'nt there a small Underpass in Somanur? I seem to remember using this underpass 6 years back?
DWind is offline
Old 18th September 2014, 16:40   #7525
Thanked: 639 Times
Yes - the narrow underpass on the western side of the railway station was the one which most people used to use while the ROB construction was in progress. The roads leading to it from the SH and back to were also narrow and full of potholes then (A year or so back was when I passed that way last).
The overbridge has been under construction for quite some time, and under normal circumstances it should have been completed by now. But haven't been able to get any feedback from anyone here whether it is open or not.
kala is online now
Old 18th September 2014, 17:09   #7526
Thanked: 26 Times
Hi Friends,
Am planning a trip From Bangalore to Waynad, Calicut and back during first week of October. Hope someone with recent knowledge of the route can guide me.
Onward Route :
(Since I need to go directly to a resort near Banasura Dam)
Bangalore - Mysore-Handpost-Bavalli-Kattilkulam-Mananthavady- Peechamkode- Thiruvana-Padinjhara Thara.
Queries:
1. Is the SH33 in good condition ?
2. The deviation from Mananthavady -Kalpetta road, to Thiruvana(to save distance and time)- is it a good idea ?
Return Route
Calicut-Sultan Battery-Gundulpet-Chamarajnagar-Kollegal-Kanakpura-Blr
Queries:
1. Haven't gone thro Sultan Battery recently. Heard that the Kalpetta-S Battery road is bad in patches. Please update.
2. The last time the road around S Battery and upto Muthanga was patchy and there was a huge block at the Muthanga check post. Any updates on current situation please.
Thanks .
SAPVEN is offline
Old 18th September 2014, 17:15   #7527
mpksuhas's Avatar
Thanked: 8,408 Times
You can find the update in last two pages of this thread.
mpksuhas is offline   (1) Thanks
Old 18th September 2014, 18:09   #7528
Thanked: 639 Times
Onward Route :
Queries:
About SH33:
http://www.team-bhp.com/forum/route-...ml#post3519987
The Naalaam Mile-Tharuvana-Padinjarethara stretch may not be all that smooth, but that would still be the best option. Even if go via Kalpetta, the Kalpetta-Padinjarethara road also has its own share of rough patches (and you'd be travelling at least 15-20 kms extra)
Return Route
Queries:
Kalpetta-Bathery-Muthanga is in excellent condition. Just be careful when passing villages between the forest exit and Gundlupet - there are several trenches across the road that are invisible from a distance and uncomfortable to traverse if you're going fast.
Other than that the only rough edges you'll find are the few below average patches between Gundlupet and Chamarajnagar, the rest is a breeze.
Old 18th September 2014, 23:01   #7529
Thanked: 26 Times
About SH33:
Kalpetta-Bathery-Muthanga is in excellent condition. .
Thanks Kala.I had followed the NH 33 thread earlier , but wanted to get a fresh opinion and current update.
Rgds,
SAPVEN is offline
Old 19th September 2014, 09:49   #7530
suresh_gs's Avatar
Thanked: 1,436 Times
Hey Jain,
Would you suggest
Vehicle is XUV.
The best option from Mysore to CBE is via Dhimbham ghats (27 hair pin bends). It is a bliss to drive on this stretch. I cannot think of a better option than this.
suresh_gs is offline   (1) Thanks
