Old 5th February 2014, 00:49   #8281
el lobo 6061's Avatar
Thanked: 2,400 Times
Re: A superb Car cleaning, polishing & detailing guide
Scratch removal from my Ford Fiesta:
Recently my car acquired a few scratches which were looking quite bad given rest of car surface was fine.
Product used : Meguiars Ultimate Compound
Applicator pad : Meguiars
Microfiber : Eurow 16" X 16"
Application method : Process should be done on a cool surface under shade. Clean the surface by washing it off or use a QD(Quick Detailer) to clean. Use a pea size drop on applicator pad. Start applying it in circular motion. Repeat the same till you are satisfied with result. An applicator pad has two sides and each side can only be used for 3 application. After which it is advised to wash the pad, since rubbing compound gets filled in it and you don't get the required cutting. Wash & squeeze water out and use again. Buff of surface with microfiber.
Front bumper left side :
Before
After
Rear bumper left side :
Before
After
Originally Posted by dre@ms View Post
I am not able to get this Meguiar's Ultimate Compound anywhere except for eBay. Any other places I can source? Is this available in any of the More MegaStore or Hyper Citys ? Or any shop in Kukatpally, Hyderabad ?
Try Keystone Enterprise, Ultimate Detailerx or BringingBest Impex. It would be difficult to find any other seller selling Megs Ultimate Compound.
Originally Posted by guyfrmblr View Post
I have minor swirl marks on my car and want to get rid of them. I was planning to use Meguiars Ultimate Compound but also came across Meguiars SwirlX in some website.
I have used both Swirlx and Ultimate Compound(UC). Once you start using UC, you wouldn't like Swirlx unless you get a dual action polisher. Get Ultimate Compound, much less effort & better result compared to Swirlx.
Originally Posted by blackasta View Post
If you want to take the 2nd route, the rule is to always start with the least aggressive method.
Start with Swirlx, then to scratchx and finally to UC.
Originally Posted by shashank.nk View Post
Its always recommended to start with the least aggressive compound and progress onto those with higher cut, but when working by hand, IMHO its better to go straight to ultimate compound unless you want to buy all 3 and figure out what works best for you
Even I used to think, working with least aggressive and working up to more aggressive rubbing compound. I got Swirlx and then Ultimate Compound and found its much easier to work with Megs UC compared to Swirlx when done by hands. UC will get the required cut much before and with less efforts.
el lobo 6061 is offline   (4) Thanks
Old 5th February 2014, 12:18   #8282
shashank.nk's Avatar
Thanked: 1,067 Times
Exactly!
Which is why I recommended he go straight to UC, i've read of people using M 105 when working by hand if Megs UC doesn't give desired results. I think one can't do much damage to the surface by hand unlike with a rotary or DA.
shashank.nk is offline   (1) Thanks
Old 6th February 2014, 00:17   #8283
SunnyBoi's Avatar
Thanked: 4,461 Times
I cleaned up my front bumper after a long time! Damages were due to me going into a tyre barrier at 60-70KMPH on a track. Not all scratches gone, but none are visible now!
Before:
After
Process was wet sand with 3000 grit, Megs Cut n Finish on a 4inch Megs Spot pad.
SunnyBoi is offline   (2) Thanks
Old 9th February 2014, 11:20   #8284
premc44's Avatar
Thanked: 121 Times
Did some detailing on my Black VW Vento this morning.
Washed with ONR
Clayed
Meguiars Ultimate polish, followed by Collinite 845
premc44 is offline   (7) Thanks
Old 9th February 2014, 21:59   #8285
guyfrmblr's Avatar
Thanked: 4,824 Times
Did some interior and front grill detailing this noon:
Used Waxpol vinyl and leather polish. Had used Meguiar's natural shine before which used to give the dashboard a natural look. Waxpol gives a glossy finish. I'm happy with the Waxpol results. Need to wait and see how durable it is.
The front grill surrounding the logo has developed some small white patches due to fading. Waxpol polish has covered the patches a bit. Any suggestions to eliminate those patches?
guyfrmblr is online now   (3) Thanks
Old 10th February 2014, 17:11   #8286
AstonMartin's Avatar
Thanked: 41 Times
Bought few items from detailedclean.in.
1. Auto Finesse Sweet Shop Air Freshener - Very good.
2. Sonus Acrylic Glanz - Good as of now, will update later.
3. Bilt Hamber AutoClay Medium - Very good.
Also bought WD-40 from vicky.in.
Prices are high in both the websites. You need to pay for the shipping too if the total amount is less than some amount.
AstonMartin is offline
Old 10th February 2014, 22:54   #8287
Thanked: 533 Times
Metallic paint and hard water washing
Have recently moved to an area where the water is hard- salt content is about 800ppm. Washing my car in this water has become a nightmare. The water leaves stains and wiping these off requires a great deal of rubbing. It almost feels like scrapping off the coating on the metallic paint of the car..
What are my options here. I could always go to where the water is soft...but alas wishes are not horses that I can ride....
What do I do to keep the paintwork shiny and new?
docsr is offline
Old 11th February 2014, 09:14   #8288
dre@ms's Avatar
Thanked: 206 Times
That's some awesome results. As mentioned by you, BringingBest Impex doesnt have the stock and not able to source one from Ultimate too. Any other options?
dre@ms is offline
Old 11th February 2014, 10:27   #8289
Jaggu's Avatar
Thanked: 17,296 Times
Re: Metallic paint and hard water washing
Hope you are washing the car under proper shade? This itself will help avoid the residue mark, and cleaning one panel at a time and wiping it dry before moving to the next would also help. Ensure your car has good coat of wax on it which will make it easy to clean.
Worst case, use a can of drinking water to rinse off at the end of the wash.
Jaggu is offline
Old 11th February 2014, 18:37   #8290
Have recently moved to an area where the water is hard- salt content is about 800ppm. What do I do to keep the paintwork shiny and new?
I would suggest you to completely stop using water to wash car on daily basis. Rather do a weekly wash which would help by preventing water warks and also conservation of water.
You could use Optimum Wash & Wax as a quick detailer(QD) in ratio 1:25(ONR:Water). It will clean the surface and will also give a nice shine without inflicting any water marks. You could also use ONR for weekly car wash as well. It will serve as a multipurpose product. Once you start using it as a QD you wouldn't wish to wash car unless its very dirty.
You could purchase it from BBImpex.
You could also try Ultima Waterless Wash Plus Concentrate. Have read good reviews about it.
Thanks. I tried a few E-Shops and best I could locate is Poorboys SSR 3.0 Super Swirl Remover. Price looks okay as I paid Rs 1000 long back for Ultimate Compound. Read reviews and make an informed choice.
Autogeek
Old 11th February 2014, 20:07   #8291
Thanked: 533 Times
Jaggu, El Lobo,
Thanks for your advice and tips. Much appreciated.
El lobo, was unfamiliar with the term QD. The ONR needs to be reconstituted in the proportion you mention and sprayed onto the panels-is this correct?
Jaggu, your advice is very well taken-thank you.
docsr is offline
Old 12th February 2014, 13:14   #8292
Thanked: 17 Times
Hey guys,
I am planning to order ONR online (green one as suggested by many Team-bhpians) and need some advice on it.
1. Is it safe to use ONR solution on windshield as well or do we need to buy Meguiars Glass cleaner or something similar.
2. Would a spray can with a 1:25 solution be sufficient to clean a car as big as Terrano on a daily basis. Since I live in an apartment complex, its not possible for me to fetch a bucket everyday down to the basement to clean the car.
Thanks.
Phoenix_Nemo is offline
Old 12th February 2014, 13:49   #8293
blackasta's Avatar
Thanked: 2,928 Times
Originally Posted by Phoenix_Nemo View Post
Hey guys,
Thanks.
1. Yes it is safe. There are better glass cleaners though.
2. How is dilution ratio of a solution and size of the car related? AFAIK recommended dilution ratio for ONR as QD is 1:16. That is true for cleaning either nano or a bus.
blackasta is offline
Old 12th February 2014, 14:53   #8294
Yes, absolutely. Do use it and let us know your feedback.
ONR is safe to use on any surface; metal, plastic and even glass. Just that green ONR contains wax, so do not let it dry on panel as it would leave wax residue for which you may again need to mist the surface and buff off.
Yes absolutely. Also do get a Jopasu duster and follow the below steps to get a nice shine in less time.
Step 1: Use Jopasu duster and move it over car surface to get rid of any fine dust.
Step 2: Spray ONR QD 1:25(ONR:Water) on one panel and wipe it off using a microfiber. Do not use any ordinary cloth be it cotton.
Step 3: Admire nice shine!
Yes according to Optimum Car Care, recommended ratio is 1:16 but 1:25 works almost same and you save a lot of concentrate as well. If you would use ONR 1:64 ratio which is recommended as a clay bar lubricant, you would even find it satisfactory compared to 1:25.
I too use to do a 1:16 ratio but later on learnt from other detailers that 1:25 works better and saves you concentrate.
Old 12th February 2014, 15:22   #8295
bigben's Avatar
Thanked: 290 Times
Hi All,
I have a discount coupon for detailedclean.in should you plan to buy something. The code is-
cards-15
It is only valid till the 15th of this month...so hurry up!
bigben is offline
