Old 5th April 2010, 14:42   #316
ankitahuja's Avatar
Thanked: 94 Times
History: Last monsoons when I was driving back from work, I went through big puddles and water logged roads. Ever since then, I started getting a not-so-nice-sound from under the hood, it was like a belt running hard, or metal grinding. I thought the belts would dry up and be ok, but then it was sheer ignorance since the sound was negligible.
Night before yesterday, my OHC suddenly gave out a constant screeching belt noise (cheeeee) and I could smell hot rubber from the A/C duct (Air con was on).
Then the car lost RPM and stalled.. I waited a few seconds since we could smell burning rubber smell and possible visual smoke from under the hood and tried to crank, it didn't. Waited another moment and cranked, it started but with a dead RPM and same screeching and died. I opened the hood to smell rubber; lots of friction and saw light smoke from the area marked in the picture.
Since I was stuck on the road (and wife was along) I decided to drive the car back home if it started since it was about 500 m from there. The car drove ok except for the smell and smoke and sound.
When I parked, there was a lot of smoke from under the hood, opened it and let is cool off. I suspect the alternator belt, what could be the problem? And can I drive it to the workstation, which is about 5-6 kms away.
1st Gen Honda City Owners - Problems Areas, Fuel Efficiency and more-ohc-rubber-jam.jpg
Last edited by Rehaan : 13th April 2010 at 11:25. Reason: Merging pic into original post.
ankitahuja is offline
Old 6th April 2010, 08:09   #317
honda3938's Avatar
I think it must be water which came into contact with hot engine and turned into steam.
honda3938 is offline
Old 6th April 2010, 12:03   #318
ankitahuja's Avatar
Thanked: 94 Times
Dude that was last year.
When the burning smell and sound started few days back, there was no contact with water.
Can anyone help?
Old 6th April 2010, 12:30   #319
Shan2nu's Avatar
Thanked: 125 Times
This is the first time im hearing of such an issue on the OHC. Your best bet is to take the car to a Honda dealership and get it checked.
I've seen cars with slipping belts but smoke coming out might mean something a bit more serious. Maybe some rotating part has just given up/got jammed causing excessive friction between it and the belt.
Shan2nu
Shan2nu is offline
Old 6th April 2010, 13:17   #320
honda3938's Avatar
Can anyone help?
sorry for the mistake. But it could be an issue with alternator or compressor jamming .
I had a similar issue with my m800 few year ago .while driving i noticed smoke under bonnet.there was a malfunction with cooling system and coolant was spilling out from the coolant box and which came into contact with engine and produced steam.
Old 10th April 2010, 09:34   #321
ankitahuja's Avatar
Thanked: 94 Times
Shan2nu
Thanks guys, it's indeed a jamming issue.
The A/C idle pulley was stuck, the belt was moving on top of it causing the sound and smoke.
Have sent for replacement!
Old 12th April 2010, 17:54   #322
narayan's Avatar
Thanked: 2,373 Times
Guys
im sure a few of you would have had drive shaft issues and gone for replacements. i am having similar issues and looking ahead for drive shaft replacement.
the khat khat sound is quite heavy these days and my left CV boot has also started leaking grease big time
can you guys give me approx indication for cost involved for this work ?
thanks
narayan is offline
Old 13th April 2010, 00:29   #323
johnda's Avatar
Thanked: 19 Times
Originally Posted by narayan View Post
...the khat khat sound is quite heavy these days and my left CV boot has also started leaking grease big time
..can you guys give me approx indication for cost involved for this work ?
The replacement for drive shaft is anything between Rs 7500 - 9000/-
which is the whole unit.
I did both mine and it came to 17K.
johnda is offline
Old 13th April 2010, 01:22   #324
ankitahuja's Avatar
Thanked: 94 Times
Guys
thanks
Got mine for 4400. Labor was 1k I guess. Brilliant, tried and tested by others in different cars too.
1st Gen Honda City Owners - Problems Areas, Fuel Efficiency and more-axle-lr-large.jpg
Old 13th April 2010, 10:39   #325
narayan's Avatar
Johnda, Ankit - thanks
got similar quotes.
Ankit - the one you mentioned is not the OE brand i suppose. will need to decide in the next few days..
narayan is offline
Old 14th April 2010, 11:21   #326
ankitahuja's Avatar
Thanked: 94 Times
got similar quotes.
Yes, it's not OE but a well reputed aftermarket brand "MB". The manufacturer is knows to us as well, so no issues with quality.
Old 14th April 2010, 16:22   #327
johnda's Avatar
Thanked: 19 Times
..the one you mentioned is not the OE brand i suppose..
The OEM now is GKN. i think it used to be Delphi.
johnda is offline
Old 16th April 2010, 09:02   #328
honda3938's Avatar
rpm query
hi friends
I have a question what is rpm range at 100km/h. As i think my speedo meter is not showing correct reading.
Old 16th April 2010, 13:17   #329
pranavt's Avatar
Thanked: 722 Times
100 km/h in which gear?
pranavt is offline
Old 16th April 2010, 13:22   #330
Shan2nu's Avatar
Thanked: 125 Times
You can't hit 100kmph in the first 2 gears.
1st redlines at 58kmph and 2nd at 98kmph.
100 comes in at :
4500-4600rpm in 3rd.
3400-3500rpm in 4th
2700-2800 in 5th.
Shan2nu
Shan2nu is offline
