Old 30th April 2025, 15:38   #466
Thanked: 144 Times
Re: Ford Ecosport : Tyre & wheel upgrade thread
I have been using 205/65/16 Continental UC6 for about 2 years now. They have significantly enhanced the ride and handling. They also seem robust and I’ve had way fewer punctures with them than the stock tyres. I can see Continental CCAX6 available now, which I would opt for bad roads.
I sincerely recommend the continentals for the ecosport.
BRZRKR is offline   (2) Thanks
Old 1st May 2025, 08:20   #467
foadbear's Avatar
Thanked: 36 Times
I think you are referring to the 16 inch alloy wheels here. I have a 17 inch one and hence have encountered problems with the tyres before. Apparently it has to do with the decreased width of the sidewall in the 17 inch ones.
I will surely read up on the Continental tyres.
foadbear is offline
Old 10th May 2025, 18:53   #468
Thanked: 39 Times
Originally Posted by blueshift View Post
I am also looking for a (SUV kinda) tyres and shortlisted below tyres. My analysis so far:
Back in September, I had posted about replacing the tyres on my Ford EcoSport, which had then run 40,000 km. After another 10,000 km, I’ve decided it’s time to replace them.
I checked with my regular tyre shop for Goodyear MaxGuard, and they offered Dec 2024 make at ₹7,500 per tyre including GST and Wheel balancing/Alignment. The tyres look new overall—rubber hairs are intact, no signs of wear, and the condition appears fresh with a little dust inside out which I think is normal.
However, I noticed the tyres didn’t have the usual colored tread lines typically seen on new tyres like this:
Ford Ecosport : Tyre & wheel upgrade thread-images-42.jpeg
A few quick questions for the community:
1. Is the absence of colored lines on new tyres normal now?
2. Is ₹7,500 a fair price for 6 month old MaxGuard?
3. Any other things to check or should I go for new manufactured tyres. They are available at 700₹ more per tyre.
Appreciate your insights!
blueshift is offline
