Old 2nd May 2007, 19:38   #5821
Sam Kapasi's Avatar
Thanked: 2,479 Times
Mosfats have been around for a while.
You also have Metal Oxide Semiconductor transistors having internal nanoconductors. Or Mosthins.
Sam Kapasi is offline
Old 2nd May 2007, 19:46   #5822
hydrashok's Avatar
Thanked: 18 Times
Hmmm... if you guys carry on like this, I'll go Mos Def
hydrashok is offline
Old 3rd May 2007, 10:49   #5823
Harshavarthan's Avatar
Thanked: 154 Times
I recently bought a new santro XL. as an offer from hyundai, i got a Pioneer HU DEH-2950MP and front speakers TS-G1011R. Now planning to have a good rear speakers.
My problem is i cannot go for a bigger speakers as im also planning to install a LPG Gas Conversion Kit and so the gas tank will occupy the whole boot. i feel its better to have 5 1/4 inch speakers in the place which is allotted for speakers by the car manufacturers.
can anybody suggest me a good 5 1/4 inch speakers? my budget is around Rs 5000. it doesnt matter even if it costs a little higher but my priority is good sound quality and size of the speakers.
Harshavarthan is offline
Old 3rd May 2007, 12:32   #5824
navin's Avatar
Thanked: 9,957 Times
For 5K you can get some very nice speakers from JBL, Blau, etc.. the only limitation of these speakers will be that they will be bass shy.
navin is offline
Old 3rd May 2007, 13:36   #5825
determinus's Avatar
Thanked: 16 Times
Mosfats have been around for a while. You also have Metal Oxide Semiconductor transistors having internal nanoconductors. Or Mosthins.
Are you playing along or are you playing along? Some folks here will get taller overnight, out of tension.
determinus is offline
Old 3rd May 2007, 15:49   #5826
Technocrat's Avatar
Thanked: 2,705 Times
Looking for a economy 2 channel amp
Car:Alto
HU: Pio 5750
Rear: Pio 6X9
Sub: Sony 12"
Amp: Sony 554(powering sub & rear speakers)
Front: Sony 130w
Recently EVO looked at my system & found am running too many EQs After running flat the SQ has increased but what has also happened is that for same listening levels I have to pump up the volume on HU more.
I fear that while listening to slightly higher volumes (for getting better front sound stage I have faders favouring slightly to front) the front speakers might start clipping.
I belive putting a small amp for front should solve this problem & also improve the SQ.
So I am trying to looks out for a not so expensive 2 channel amp for my fronts
They have following rating:
Peak Power: 130W
rated input power: 30w
I have Sony 2 channel amp XM-552ZR in mind. Any other options available. I dont want anything expensive as I dont think the speakers are worth it.
Technocrat is offline
Old 3rd May 2007, 16:01   #5827
Thanked: 154 Times
i did a search in the web. and found these speakers suit me.
JBL - P552, GTO527
Pioneer - TS_E1396, TS-E1376,
But im not sure if these speakers are available in india and how much they cost. and can i use these speakers without amp?
please advise.
Old 3rd May 2007, 16:05   #5828
Vid6639's Avatar
Thanked: 44,136 Times
no use techno the front 4" are way too weak. I have pio 4" fronts and they will still sound bad with an amp. not worth the effort of the amp. better suggestion is to get better 4" speakers like infinity or maybe even JBL 427.
Vid6639 is offline
Old 3rd May 2007, 16:05   #5829
mobike008's Avatar
Thanked: 17,113 Times
you can even get the sony 554 ( 4 channel) for about 5K or less. If you can stretch your budget go for Pio 6200 which is about 7K
mobike008 is offline
Old 3rd May 2007, 16:09   #5830
Technocrat's Avatar
@mobike: I already have a 554. Need something only for my fronts
@vid: I know man but wont the new speakers clip as well? Dont have moolah right now for new speakers+amp
Old 3rd May 2007, 16:22   #5831
mobike008's Avatar
Ok,then go for the 552, it should take care of your need. Personally i am not a big fan of Sony's for ICE
Old 3rd May 2007, 16:34   #5832
Technocrat's Avatar
Neither am I but for the car & my budget they are doing a decent job.
Btw read my post I already have 552 in my mind also read vid's reply
Old 3rd May 2007, 17:07   #5833
mobike008's Avatar
Yup saw that and thats why said go for it.
Old 3rd May 2007, 17:21   #5834
Technocrat's Avatar
Hmm do you think it would have a positive impact i.e. using 552 power the fronts thats I have?
Old 3rd May 2007, 17:34   #5835
mobike008's Avatar
Ofcourse, it would be much much better than powering your comps from the HU.
