Old 4th July 2013, 08:35   #6796
diyguy's Avatar
Thanked: 588 Times
Originally Posted by Raccoon View Post
Insurance based? Does that cover component failure/manufacturing defects, etc?
Covers everything. Comprehensive coverage. You gotta have it fixed by the official provider and claim the amount at Croma. This is what I was told.
diyguy is offline
Old 4th July 2013, 09:22   #6797
Thanked: 53 Times
Best 32" LCD for Least Price
I would like to buy a 32" LCD for my weekend getaway home. The current use would not be much hence would like to spend as little as possible. I have a Panasonic TH-L32-C4D which is serving me very well but its not currently available in market and has been phased out.
Any pointers to the best LCD I could get for the least price? I know LCD is dying but I do not want to spend anything above it currently as I would like to invest in good AV only after couple of years with better technology than current.
mrohit17 is offline
Old 4th July 2013, 10:07   #6798
k2max6's Avatar
Thanked: 183 Times
Originally Posted by mrohit17 View Post
As far as I know LCD's are not available now. LED's are available at similar pricing. You can get a 32" Samsung LED for around 25k. Toshiba for around 20k. Panasonic should also be in similar price range. Sony slightly expensive.
k2max6 is offline
Old 4th July 2013, 10:26   #6799
Thanked: 311 Times
re: The TV Thread - LCD, Plasma, LED etc.
Originally Posted by k2max6 View Post
As far as I know LCD's are not available now. LED's are available at similar pricing. ....
All the current TVs are LCD.
These are LCD panels with back-lighting that is provided by LEDs, instead of the older fluorescent lamps.
anupmathur is offline
Old 11th July 2013, 00:21   #6800
diyguy's Avatar
Thanked: 588 Times
Guys I have 3 flat screen TVs- 46 Sony LCD, 37 lg led, 32 Sony LCD
Need to understand why these wide screen TVs still lose portions of telecast on the sides? Pretty irritating to think that we spend so much and still can't read the whole text or part of the scene. Am I doing something wrong with my STBS settings? Have 2 HD STBs and one SD. Got to check on my projector if I can see the whole picture..,
diyguy is offline
Old 11th July 2013, 00:49   #6801
khoj's Avatar
Thanked: 1,288 Times
It seems you have the user setting in your STB set for displaying pictures in the 4:3 format, this is suitable for CRTs. For the FPDs this ratio should be set to 16:9
In case this is already 16:9 on the STB (which seems unlikely as all of your panels are having the issue) then check the aspect ration on the panel itself.
Certain panels give you a choice of 16:9; 14:9; 4:3, Just; 4:3 Full & then Zoom levels. Here again the ratio should be set to 16:9.
khoj is offline
Old 11th July 2013, 11:37   #6802
diyguy's Avatar
Thanked: 588 Times
My Tv is set to wide full. My STB is set to 16:9.
See the missing alphabets below. This is on my 46 Sony.
diyguy is offline
Old 11th July 2013, 11:46   #6803
Styler's Avatar
Thanked: 807 Times
I own a Panasonic P42UT50D and a really like this TV.
I was looking for a TV for my mom's room. It is a small 12 X 10 ft room so max size I want is 40 / 42" . Since 42" Plasma TVs are not available I have narrowed down to a 2013 Samsung LED TV Model 40F6400 . This is a great TV and is available in the Grey Market for 47,500.
How does this look. Does anybody have this TV ?
Styler
Styler is offline
Old 11th July 2013, 11:47   #6804
Styler's Avatar
Thanked: 807 Times
You have some incorrect settings which are causing this. You could have enabled zoom in the TV or something. I own a few Flat Panel TVs with Tata Sky HD and never had this problem.
Styler
Styler is offline
Old 11th July 2013, 11:58   #6805
diyguy's Avatar
Thanked: 588 Times
Styler
When you have the time can you check the channel RT, if you are getting it?
I have not enabled zoom.
diyguy is offline
Old 11th July 2013, 12:01   #6806
S_U_N's Avatar
Thanked: 418 Times
^Can you post a screenshot/ photo of the Aspect ratios available on the TV?
There should be an Aspect button on the remote.
Edit: Change aspect ration to 4:3 and then check if show the full content (compared to SD box on the other TV?)
S_U_N is offline
Old 11th July 2013, 13:50   #6807
diyguy's Avatar
Thanked: 588 Times
Ok solved it. There is a setting called Display Area. It was set to Normal. There was an option Full Pixel. On using that the picture is now full!
Thanks for the input guys.
diyguy is offline
Old 11th July 2013, 22:51   #6808
diyguy's Avatar
Thanked: 588 Times
Replying from phone and have no way to edit this post, but I wasn't able to solve this on my 32 Sony LCD or my 37 LG LED. Tried the options on display area but doesn't solve the issue...
diyguy is offline
Old 16th July 2013, 12:13   #6809
Styler's Avatar
Thanked: 807 Times
Styler
Does anybody have any feedback of the Samsung 2013 Model 40F6400 ?
Styler is offline
Old 16th July 2013, 12:38   #6810
dre@ms's Avatar
Thanked: 206 Times
What is the Energy Saving setting everybody uses on their Samsung LCD TV. I have the 40" and set it to High. Someone said that the power consumption would be less in this setting.
Is that true?
But the whole purpose of HD clarity is defeated IMHO
dre@ms is offline
