Old 12th August 2007, 13:01   #91
rsjaurr's Avatar
Thanked: 28 Times
Adapter's output is 12VDC 1000mA.That should be the input of router's voltage?
rsjaurr is offline
Old 13th August 2007, 16:34   #92
rsjaurr's Avatar
Thanked: 28 Times
Hi Tanvir
Thanx a ton for guiding me.
Finally i am able to connect wireless with router. Right now i am typing sitting in other room.Signal strenght is excellent acc to windows.
I feel settings a right password(in pic no 4) did the job which probably was set something else on computer though i am not sure.
Security & encryption type is WPA2-PERSONAL/AES res'ly.
anything else u have to say to improve it?
BTW i got the adapter whcih is outputing 12VDC 1000mA(1W).It seems to be fine as it is working now!!
rsjaurr is offline
Old 13th August 2007, 22:09   #93
tsk1979's Avatar
Thanked: 23,489 Times
Great doc, glad to be of help.
The adapter will do fine.
As for security, what you have will do well.
If you want more then there is an option in the router where you can give in a MAC address. So go to your laptop wireless properties, read out the MAC address(It will be like AC CF 45 8D). Enter that in your router.
That way only your laptop will be able to connect. This ads an additional layer of security.
Of course there is nothing like 100%, but this should make your wifi network fairly secure.
tsk1979 is offline
Old 11th June 2008, 22:45   #94
msdivy's Avatar
Thanked: 3,072 Times
Need info: Which is a good router, which can work across floors? I mean I want to have the router on 1st floor and connect devices both in ground floor & 2nd floor.
What is the difference between Wireless Access Point & Wireless Router? I have BSNL ADSL modem with ethernet out. Which one should I buy?
msdivy is offline
Old 6th August 2008, 02:01   #95
rsjaurr's Avatar
Thanked: 28 Times
Well..due to some reasons i had to re-install whole OS with recovery dvd after formatting "C" drive.So obviously my laptop's internet settings are gone and i am back to square one.
I have tried everything i can in the last few days but no luck so far.
My BSNL supplied ADSL modem works fine and right now i am using wired connection through this modem only.
When i use linksys software cd and follow the instructions,i dont go beyond 3rd picture (capture1).
I dont remember how i did all this with Tanveer's help.Need again urgent help ASAP.
rsjaurr is offline
Old 6th August 2008, 09:03   #96
tsk1979's Avatar
Doc, when you connect your laptop to the BSNL modem, do you "dial in" from your PC to connect to the internet, or do you just switch on modem and you are "online"?
tsk1979 is offline
Old 6th August 2008, 11:26   #97
DerAlte's Avatar
Thanked: 2,920 Times
Your first pic shows "Access: Local only"! This should mean you have told the router not to connect to the Internet.
Unless you are trying to connect on-demand ONLY, Internet access should be achieved by simply setting the Gateway setting of the computer (under IP settings) to the IP address of the Linksys box, usually "192.168.0.1" or "192.168.1.1".
Are you able to see the admin page of the router in the browser (not via the program that runs off the CD)?
DerAlte is offline
Old 6th August 2008, 11:30   #98
Thanked: 4,910 Times
a bit OT : you bought a WRT54GL and you're running it on stock Firmware
greenhorn is offline
Old 6th August 2008, 11:32   #99
tsk1979's Avatar
derAlte, the computer connects to router, but router is not connecting to ADSL modem
tsk1979 is offline
Old 6th August 2008, 12:26   #100
DerAlte's Avatar
Oops, I thought they were the same box!
The wireless router should be now transparent in the whole scheme, i.e. it should just be a router / access point sending packets back and forth, and not bother about who is sending packets where and whether / which packets are bound for Internet.
* Set DHCP ON in the ADSL box
* Reset the Linksys box and switch off any DHCP on it
* Point all computers to the ADSL box as DHCP server and the Gateway ("192.168.0.1" or "192.168.1.1")
* Implement WEP on the Linksys box for security
I have a similar setup at home: A Huawei ADSL box, connected to a 3Com LAN switch (for the wired LAN connections), and then to a D-Link Wireless router. I connect via wired LAN or WiFi.
DerAlte is offline
Old 6th August 2008, 12:38   #101
spadival's Avatar
Thanked: 29 Times
Have you hardreset the Wireless router? 2 things I can think of:
1. If authentication is via ppoe thingy, Check if the broadband user /password is saved correctly on the router.
2. If BSNL allows connection only from a particular MAC address, you will have to "copy" the MAC address of your PC/laptop network card to the wireless router.
Your wireless router config screen should have the option for setting up both the above things.
spadival is offline
Old 6th August 2008, 12:42   #102
Rodeo's Avatar
Thanked: 28 Times
I have been facing an issue with my BSNL (UTStarCom) router. It works fine when I connect using my office laptop running on XP. But when I use home laptop running on vista, it does not get IP and I have to assign an IP address.
I recently got a new HTC Diamond and wifi performance is very very bad. It works only in 3 mtrs range. First I thought it was phone issue but when I sit in balcony I get signals from neighbours and wifi performance is not bad. My laptop works from more than 3 mtrs range.
I looked in UTStar site but cannot find firmware upgrade for my router, is there anywhere else I should look for?
Rodeo is offline
Old 6th August 2008, 15:21   #103
ph03n!x's Avatar
Thanked: 6,165 Times
If your modem gives out 192.168.1.x, and if your router is a Linksys (which is also 192.168.1.x) then there may be a problem in routing. Have one of them changed to, say, 192.168.123.x, and that should work. Better still, enable bridge mode in the modem, and let the router do the routing. (The first scenario is what we call as double NATing).
ph03n!x is offline
Old 6th August 2008, 15:29   #104
DerAlte's Avatar
Originally Posted by Rodeo View Post
... It works fine when I connect using my office laptop running on XP. But when I use home laptop running on vista, it does not get IP and I have to assign an IP address.
If it works on XP, it will work on Vista - no difference for Network. Please check the Network settings under Vista once again.
I recently got a new HTC Diamond and wifi performance is very very bad. It works only in 3 mtrs range. ...
Must be to do with the Diamond's antenna, not the router's. My N82 works across a couple of floors.
Don't bother looking for the UTStarCom firmware upgrade - the problems have nothing to do with the firmware.
DerAlte is offline
Old 6th August 2008, 16:00   #105
Rodeo's Avatar
Thanked: 28 Times
My Vista works fine when I try to access other wifi network around but when I use my own router, it does not get an IP.
And it works differently between Vista and XP, I found a fix for it but does not work for me. Windows Vista cannot obtain an IP address from certain routers or from certain non-Microsoft DHCP servers.
Again it cannot be Diamond's problem as I can use my neighbours wifi connection.
Thoughts?
Rodeo is offline
