Old 3rd February 2009, 12:02   #241
Thanked: 571 Times
Originally Posted by carboy View Post
Looking to buy a hand vacuum cleaner. Something like this - 800W Vacuum Cleaner with 6 Attachments gifts in india at rediff shopping.
Anyone know which brand is good (has good suction) & reliable & how much it costs.
The posting does not mention anything about the make of the vacuum. It might most probably be come run of the mill chinese make and based on your luck, you either get something that might just run really well, or die the next day! I would say, get something branded.
And with Rediff shopping, I would be extra careful.
Originally Posted by madbullram View Post
Bought Eureka hand vaccum for 1800 or something and I am very happy with it. Works good for both house and car
Yeah, something like this, were you have a actual user experience will help.
Have a higher end Panasonic Microwave Oven. Of late, it needs more time to do the heating - even half a glass of water needs a full minute on high power.
Any ideas ? Have cleaned the cabin, but no avail.
How old is it? Does it have a internal stabilizer or do you use an external one?
HappyWheels is offline
Old 3rd February 2009, 12:29   #242
condor's Avatar
Thanked: 16,902 Times
HappyWheels : How old is it? Does it have a internal stabilizer or do you use an external one?
2 yrs. No internal / external stabilizer.
Would also like to know what do I do now - if it is a result of power fluctuations.
condor is offline
Old 3rd February 2009, 13:10   #243
Thanked: 1,911 Times
I assume this comes with a charger & battery - i.e. you can operate it
without being plugged to a power source, right?
Also does this come with any attachments?
carboy is offline
Old 3rd February 2009, 13:54   #244
Thanked: 571 Times
Had the same issue to the one that my parents were using. It was caused due to power fluctuation. Survived in my home town for just 4 months.
Old 3rd February 2009, 19:44   #245
Thad E Ginathom's Avatar
Thanked: 30,126 Times
I sometimes also experienced poor heating from my microwave, a Panasonic that came from my ex-home in UK. It was always down to low input voltage. I started to use a stabiliser, and have not had a problem since.
The oven can draw a lot of power; I think my stabiliser is rated 3kw.
Thad E Ginathom is online now
Old 3rd February 2009, 20:53   #246
condor's Avatar
@Thad, thanks. Need a full minute even at a 240V input. The oven is rated at 5.9A / 220V (m.w) & 6.9A /220V (heater).
If it helps - the model is 784MF.
condor is offline
Old 4th February 2009, 15:17   #247
madbullram's Avatar
Thanked: 272 Times
Nope. It does not come with Battery, you need to plug it and use it. It has all attachment of a handy vacuum. I use it in car by plugging to a A/C outlet
madbullram is offline
Old 4th February 2009, 20:43   #248
Wow - a portable device which doesn't come with a chargeable battery.
That has to be one of the most braindead designs ever.
What next? A cellphone which has to be always plugged in.
carboy is offline
Old 5th February 2009, 02:27   #249
kb100's Avatar
Thanked: 23 Times
We are having the same problem! We have an IFB 23SC1 3-in-1 microwave . The damn thingy is taking endlessly long to do anything. Defrosting any quantity over 1kg is a task, and no matter what water just does not come to a boil (esp if the quantity is over 700ml)
Voltage at home is between 220-240 volts... more or less constant.
kb100 is offline
Old 5th February 2009, 02:51   #250
If the voltage is good, it must be a faulty unit.
I have known microwave ovens that just plain did not work.
Old 5th February 2009, 13:50   #251
madbullram's Avatar
Thanked: 272 Times
Its called Handy Vacuum or something not portable vacuum i think. This was launched as a replacement of house hold big vacuum so i dont think Eureka made the mistake you are pointing at . I use it for my car and jeep bcos I find it convenient!
Where is ti mentioned as portable, if i may know.
Old 24th February 2009, 16:10   #252
sammyboy's Avatar
Thanked: 526 Times
With the temperatures rising in Bangy I guess its time to look for an AC. I am looking at a 1.5 T split AC. WHich ones are good? I have a couple of Voltas back home and they are working fine. Any suggestions guys with approx prices if possible.
sammyboy is offline
Old 24th February 2009, 16:17   #253
Eddy's Avatar
Thanked: 14,586 Times
Here you go sammyboy !!!
http://www.team-bhp.com/forum/gadget...ioner-buy.html
Eddy is offline
Old 24th February 2009, 16:28   #254
sammyboy's Avatar
Thanked: 526 Times
Originally Posted by Eddy View Post
Thanks a zillion Ed, i tried to search but nothing came up so used this thread
sammyboy is offline
Old 24th February 2009, 16:48   #255
condor's Avatar
Magnetron Problem ? Hope not !
@KB, any luck with your microwave ?
Check this :
Slow Heating - FixYa
If your line voltage is correct and it is slow to heat, then almost certainly your magnetron is failing
Does any one in BLR have the contact number of a Panasonic service engineer ?
I have the numbers of the service Center. The guy who had come had offered to help check any out-of-wty Panasonic equiment. (Not able to find the number he had given me.)
condor is offline
