Old 12th April 2022, 11:44   #7096
rkv_2401's Avatar
Thanked: 884 Times
Re: The home / office air-conditioner thread
If anyone's in the market for a new AC, Samsung offers extended warranty + service every 4 months as a paid add-on. It costs 10k for 4 years of additional warranty - and it applies to everything : the dodgy PCBs that keep failing nowadays, the regular gas leaks - even your remote can be replaced free of cost if there's a fault! (The compressor already has a 10 year warranty IIRC and the condensor/indoor unit has a 5 year one).
This was useful for us as prior to this current set of ACs, as we seemed to be changing 3 out of 4 of them every 2-3 years. The add-on warranty needs to be purchased within 1 year of purchase - and has already paid for itself after the PCB of a Samsung inverter AC we bought in Aug 2020 failed recently. However, they'll forget about the free service if you don't push them for it.
This is such an insanely good tip, thanks guys! Started keeping the ceiling fan on low speed with the AC and it greatly, greatly helps in a uniform spread. I'm extremely sensitive to temperature changes & found this to be the best combination.
I've always kept the fan on with the AC, and yes, it is really nice. However, AC service technicians always recommend not running the fan and the AC at the same time because dust accumulates much faster - I never listen to them :P just wanted to give a heads up to clean the filters more often if you use the fan and AC together.
rkv_2401 is offline
Old 12th April 2022, 11:50   #7097
Thanked: 158 Times
Originally Posted by earthian View Post
Bought 10 Mitsubishi Inverter a/cs for the new house. Most of them (except the 1 T capacity) are 5*. Included is two years AMC . Warranty- 10 years for compressor and 5 years for PCB. Installation costs extra.
Very good on behalf of Mitsubishi to give 5 years warranty on PCB. PCB on inverter ACs (2 of them I guess) cost a bomb to replace. And PCBs can go kaput, especially in areas prone to voltage fluctuations without stabilizers. The whole reason I went for Panasonic inverter over LG and Daikin where the extended warranty on PCB.
kiranknair is offline   (1) Thanks
Old 12th April 2022, 12:12   #7098
Thanked: 516 Times
Been sleeping like a log since a couple of days. Good sleep for 7 - 8 hours = feel like I'm on top of the world.
All these years have been using the celling fan. I had already pointed out earlier in the thread
If you use it
  • The AC will accumulate lot of dust, including the tubes
  • If you have any sinus allergies, they get amplified with the fan
Tried it for some time without fan, but couldn't sleep due to the absolute silence.
Arun_S is offline   (1) Thanks
Old 12th April 2022, 14:04   #7099
Thanked: 2,080 Times
I get my inverter AC thoroughly cleaned every 6 months. I have this AC guy, who comes and dismantles the entire Indoor unit and spray cleans it, shampoos the plastic parts etc. You wouldn't believe the amount of dust that comes out. From black color evaporator to the original coil color is the transformation. He washes the outdoor unit too and chares up the gas if needed. So the performance for Kerala weather is satisfactory. I feel inverter ACs are especially susceptible to clogging and its a good practice ( if you are using regularly) to strip clean it once every 6 months.
I have a Panasonic Window AC also. This is another story, no maintenance at all, extremely powerful ( can keep the adjacent room also quite comfortable). Only drawback is it is really noisy compared to inverter ACs.
Nanolover is online now   (3) Thanks
Old 12th April 2022, 14:20   #7100
dragonfire's Avatar
Thanked: 1,830 Times
Hi Folks
Need a split AC to replace my Carrier Superia 4i and Flipkart is running some promotions. I came across a pretty cheap Whirlpool 5 star AC.
https://www.flipkart.com/whirlpool-4...18e43c8967819?
Power consumption figures looks good, but am a bit skeptical about Whirlpool as a brand. I have had two Whirlpool water purifiers in the past and they always gave me trouble.
Any other brands I should be looking at?
dragonfire is offline
Old 12th April 2022, 14:41   #7101
sagarpadaki's Avatar
Thanked: 6,863 Times
The LG split(non inverter) is behaving weird. It is not respecting the set temperature and is cooling beyond the set temperature by a big margin. I set the temperature at 29 and the compressor stops once the room is cooled to 24 degrees(As read by the bed side thermometer). It kicks back in when the temperature rises to 28. This is causing lot of discomfort late in the night when the compressor kicks in and we are frozen to the bone!
I understand the cooling is not linear and the hysteresis is involved. But I was expecting the difference to be around 2 degrees. Not 5 degrees!
Any suggestions on how to fix this problem. Thanks in advance
sagarpadaki is offline
Old 12th April 2022, 15:43   #7102
Thanked: 251 Times
Originally Posted by dragonfire View Post
Hi Folks
Please AVOID Whirlpool. We've had a washing machine and refrigerator from this brand in the past, and it was nothing but agony, having to repair both multiple times.
For ACs, Daikin is really good. If your usage is moderate, simply go for a simple, non-inverter model. It will last you many years, and is virtually maintenance free except for periodic filter cleaning.
vijaysrk is offline   (2) Thanks
Old 12th April 2022, 16:58   #7103
Thanked: 219 Times
Can you remove the air filter, operate the aircon and let us know if the smell persists? Some of these carbon activated or electrostatic filters can cause this.
The problem you report is difficult to diagnose. If it were a refrigerant leak, then you won't have any cooling. If it is cooling, there is refrigerant in the system. Refrigerant is technically odorless, however, they do add odor for the purpose of identifying a potential system leak.
If the technician is threatening, you need to report this to LG. Such behavior is unacceptable.
Thanks sandeepmohan for the suggestion! I ran the AC without the filter, but the smell was still there. I will now write to LG and hope they resolve the issue ASAP. Will temperature rising each day, it is frustrating to watch the AC as a show piece.
MBond007 is offline   (1) Thanks
Old 12th April 2022, 17:02   #7104
Thanked: 219 Times
Originally Posted by Arun_S View Post
Please check your Stabilizer, whether the power output is coming as normal.
Last month just after cleaning was facing a burning smell, turned out to be Stabilizer, which had some parts which was melting due to short circuit.
Its not a burning smell. But still I went ahead and changed the plug and the switch (there is no stabilizer). The smell is still there.
MBond007 is offline
Old 12th April 2022, 17:21   #7105
Thanked: 3,259 Times
It looks like your temperature sensor has either gone bad or calibration has gone bad that it reports wrong temperature for compressor control.
Since 29degC is at the higher end of control band, did you try changing the temperature setting to different values across the range from 18degC to 26degC? This can help whether it is due to calibration setting or sensor gone kaput.
Or please get the temperature sensor checked by a technician directly.
@MBond007 - Please raise the issue with LG for compressor oil check as I requested earlier. They have to take the AC with them to check as it is not easy to detect oil left in coils. Synthetic oils though non toxic but prolonged exposure is not good for health due to carcinogenic claims.
thanixravindran is offline   (1) Thanks
Old 12th April 2022, 17:32   #7106
Do you mean, I set different temperatures and see how much is the actual temperature before the temperature cuts off?
Old 12th April 2022, 17:43   #7107
Yes, just the same way you measured the temperature at 29degC.
Old 12th April 2022, 19:10   #7108
Thanked: 331 Times
Right time for this thread. Want to buy a new AC for my home and friends suggested me to go for a SOLAR Air Conditioner to avoid most of the above mentioned problems. Googled and found below companies.
Onyx, Sharada Inventions, SuryaShakti, Arka Technologies etc.
Any thoughts from the forum and any experience on which brand is the best?
wheeledwanderer is offline
Old 12th April 2022, 21:12   #7109
Mortis's Avatar
Thanked: 1,683 Times
Originally Posted by Rodie09 View Post
Does your ac come with a mode called Chaos logic or something similar. That's an LG term, can be different for you depending on brand. It is programmed to give that natural uneven gusts of air. Do check out the manual or the remote for such mode.
Nope, no mode like that. Today I did only a thorough bleach treatment and no other cleaning. Let's see if the sound stops tonight and how long it last. This could help in providing or eliminating one source.
Mortis is offline
Old 12th April 2022, 21:39   #7110
I get this wind blowing noise only when the filters are clogged in my AC (rarely if I miss my regular cleaning) and after regular cleaning, this goes away. Does this happen on all the modes? You mentioned it is not in blower but what is blower mode - Is it the fan mode you are referring or something else?
Not related to the problem, but curious what bleach you are using and how do you do the bleach wash? Can we do it ourselves or is it by AC service person?
