Old 21st January 2014, 18:04   #17461
Figopian's Avatar
Thanked: 141 Times
Proximity sensor issue. If you have a screw behind the proximity sensor (on the back of the phone) which can be adjusted a bit, then you may try doing so. You will need a small screw driver which the repair shops have.
I am not sure if you phone can be fixed that way, but on my Defy, I did that and never had issues again.
Don't see any screw directly behind the proximity sensor (Looks like its kind of integrated into the 3.5 mm jack unit), but maybe I can try tighting up the main screw on right side corner. Thanks!!
Figopian is offline
Old 22nd January 2014, 12:16   #17462
S_U_N's Avatar
Thanked: 418 Times
Moto G launch delayed. Now we will get to know more on 5th Feb.
So, something has gone wrong.
S_U_N is offline
Old 22nd January 2014, 14:09   #17463
dmplog's Avatar
Thanked: 426 Times
Got my hands on my own Moto G on Sunday. Brilliant display and solid to handle!! Fast processor too. Currently giving me 24 hrs battery life 24 Hrs of internet (mobile data or WiFi), display on for more than 5 hrs, Battery Saver mode put to OFF and Apps such as Facebook, Emails, Maps, WhatsApp and Flipboard on all the time.
dmplog is offline
Old 22nd January 2014, 14:15   #17464
naveenroy's Avatar
Thanked: 1,318 Times
That's very nice battery life! Did you get it from the US?
naveenroy is offline
Old 22nd January 2014, 16:10   #17465
S_U_N's Avatar
Thanked: 418 Times
Good to hear that. Try a more realistic scenario with Wifi ON around 12 hours a day and 3G for 1 hour. No games, no maps, no facebook. Voice calls: 1 hours and screen ON: 4 hours. I hope it lasts 48 hours.
S_U_N is offline
Old 22nd January 2014, 16:26   #17466
Maverick79's Avatar
Thanked: 610 Times
Pals,
My Sony Xeperia M is getting disconnected very often from Net.
I need to switch off and then on back to get the connection restored.
Is this a regular feature of M or some settings have to be done?
Thanks for Help in advance.
regards,
Maverick79.
Maverick79 is offline
Old 22nd January 2014, 16:43   #17467
Thanked: 1,377 Times
Originally Posted by Maverick79 View Post
Pals,
regards,
Maverick79.
This is an issue with these Android versions from a number of different manufactuers, especially Sony. You'll have to toggle between Airplane mode and Normal mode to get your net working. Bear in mind that you'll have to allow a few seconds for the toggle to actually take effect and then switch back. Hope this helps.
Mudhalaipatti is offline
Old 22nd January 2014, 18:10   #17468
Maverick79's Avatar
Thanked: 610 Times
Thank you Mudhalaipatti. Now I can relax as this is a universal problem.
I didn't try the Airplane mode till now. May be, I can save some battery this way, than switching on and off to get connected.
Will try and keep posted.
Its okay today as of now.
I face this atleast once in two or three days.
Old 22nd January 2014, 19:46   #17469
Desmosedici's Avatar
Thanked: 628 Times
I also face the issue of network cutoff whenever i get inside an elevator or go to the basement where the network is not available and when i come out the network at times does not get restored automatically. I also do the Airplane Mode toggle for a few seconds and everything is back online. Mine is a stock Gnex.
Desmosedici is offline
Old 22nd January 2014, 21:06   #17470
14000rpm's Avatar
Thanked: 7,814 Times
updated my Samsung S3 to Android 4.3 a few weeks ago.
Dissappointed.
battery life has reduced drastically.
Camera drains battery excessively. scary at times. add google maps+navigation too.
stock email app doesn't refresh emails immediately.
I have a few more grouses..maybe I've started to live with it.
But overall, I was better off with 4.1
14000rpm is offline
Old 23rd January 2014, 00:24   #17471
Thanked: 24 Times
Dissappointed.
Even i faced battery issues. I had a windows live account configured for push mail using the builtin email app. Turned out it was the exchange service causing wake locks and excessive battery usage. Have deleted that, and now i use k-9 for email. All is fine now. Maybe you have the same issue? In any case try a factory reset to see if things improve
djkher is offline
Old 23rd January 2014, 08:42   #17472
Dissappointed.
This is most likely to be a exchange server issue. If not, then try to switch off sync (everything) and see how it fares. Don't let this situation continue for long, as the battery will eventually die down and you would end up replacing the battery.
Old 23rd January 2014, 09:38   #17473
Maverick79's Avatar
Thanked: 610 Times
Tried the Airplane mode changing trick today morning and it worked. Thank you once again.
Battery draining also is less compared to switching Off & on method.
Old 23rd January 2014, 10:33   #17474
dmplog's Avatar
Thanked: 426 Times
I am sure it will give much more than 24 hrs as it's still early days of my shiny new phone and I keep looking at the beautiful screen every few minutes! And moreover app downloads, Account configurations, trying out Google Now and Moto Assist!!
dmplog is offline
Old 23rd January 2014, 11:05   #17475
arnabchak's Avatar
Thanked: 1,165 Times
Moto G launch date is tentatively confirmed for 5th Feb.
The Google owned Motorola's new budget full feature handset was to be launched in the first week of Jan, postponed to the last week of Jan and now is likely to be launched on 5th Feb.
Moto G is an important product for Motorola and is likely to be available only through the online portals(Flipkart).
Physical mobile disctribution with Redington and Ingram Micro have fallen through and hence Moto will have to limit through the online purchase mode only.
It retails ar $179 for the 8 GB and $ 199 for the 16 GB models.
No expandable memory slots for the 4.5 inch smartphone.
arnabchak is offline
