Old 14th May 2007, 16:45   #376
tsk1979's Avatar
Thanked: 23,484 Times
Proxima, you have 4 bulbs in the old safari i.e. 2 pairs.
One Pair is for low beam
Other pair is for high beam.
When you are in low beam mode 2 bulbs light up
In high beam mode all 4 light up.
That said old safari had pretty good lights, I suspect the reflector. Get the reflector and headlight glass cleaned and the headlights aimed.
Also from your service book post what are the bulbs in a safari
For example on pair may be H3 the other pair may be H7.
tsk1979 is offline
Old 14th May 2007, 17:20   #377
Proxima's Avatar
Thanked: 384 Times
Thanks TSK. I will check allignment and the reflector, if I am still not satisfied, will get back to you on what bulb to replace the OE with.
Proxima is offline
Old 14th May 2007, 17:23   #378
panky12345's Avatar
Thanked: 172 Times
I got my stocks changed to Osram 100/80W yesterday, with relay!
Awesome results!
panky12345 is offline
Old 14th May 2007, 17:28   #379
tsk1979's Avatar
Where did you get them from panky. Cost/model etc.,?
tsk1979 is offline
Old 14th May 2007, 18:40   #380
panky12345's Avatar
Thanked: 172 Times
hi tanveer, i dont remember the exact model # it was OSRAM 100/80W for sure & it costed me 300 rs a pair for bulbs and app 600 for the relay.
i bought it from authorised dealer in west delhi, pawan motors. the guy's name is atul and his # is 9891200240.
Old 14th May 2007, 19:01   #381
Thanked: 58 Times
try getting a philips 130 /110 with a cutout . You could probably buy ceramic bulb holders from roots and a cutout . Everything should cost around 700 rs for the upgrade . You will feel that the money is worth spent .
Cutout is used as these bulbs draw a heavy ampereage and for switching ,the stock contacts can switch so much of amps and the oe wiring cannot handle the amperes . Thats the reason for a cutout .
Incase someone has replied before ,kindly ignore as i didnt have the patience to go through the whole set of replies .
greatmana2000 is offline
Old 14th May 2007, 22:21   #382
Originally Posted by shazikon View Post
Has any one used this?? Is this available in india??
Gosh!!! Such lovely headlamps. 200 pounds one set.. and postage wud be another 200 pounds (cos ireland itself 50 pounds) and customs another 200 pounds.. equal to 600 pounds. o m g! but its so lovely!! so sad that stock is empty.
OT: Those fiesta zetec engines rock, and also the ovrm's present in this ford fiesta zetec have the mirrors of the indian escort which is much better than the present ikon's ovrm's.
-Absar
Absar is offline
Old 19th May 2007, 20:42   #383
Thanked: 58 Times
my headlight bulbs have failed once again ..
my 130/110 bulbs have again failed . the high beams have gone and I got to replace the bulbs again . I am toying with the idea of getting some industrial grade relays , and also planning to limit the current by adding a diode inbetween the bulbs . I know for sure there would be a voltage drop when the diode is connected in series , but , I would like to know if there are any other protection methods to save those filaments from burning out .
I have also had issues with the "electronic" relays ,and thats the reason why i am planning to get an industrial or militiary grade , high ampere relay for each bulb .
Anyone out there has tried with these mods ?
Old 19th May 2007, 21:56   #384
drifter's Avatar
Thanked: 75 Times
Have u tried ceramic holders? If not, then thats the most likely culprit. Good relay with good quality wiring and ceramic holders will mean your 130/110 bulbs will always shine.
Drifter
drifter is offline
Old 19th May 2007, 22:26   #385
gigy's Avatar
Thanked: 47 Times
I think your bulbs are failing because of heat. In city traffic using such high power bulbs will heat them up to a point it will fail sooner. along with this if you are using dipper then it is sure reason for failure. hope you are using ceramic bulb holders. other ones will melt off and when you want to change the bulbs you will see everything is a molten mass and might turn into a major problem. you can end up damaging the headlight assy itself.
industrial grade relays dont make a difference here. if you are using bosch relays(30amps) it is good enough. Diode doesnt limit current. you reduce current then you are reducing power output, then why put this bulb. go for xenons or lower power to 90/100
gigy is offline
Old 20th May 2007, 14:11   #386
tsk1979's Avatar
With ceramic holders 130/110W relay and thick wiring nothing will fail.
Also make sure you don't do high low beam together.
tsk1979 is offline
Old 22nd May 2007, 19:57   #387
speedfreak7116's Avatar
Thanked: 23 Times
Can anybody help me out with details on underbody neons.. Aprox cost and size of the tubes...
speedfreak7116 is offline
Old 24th May 2007, 12:09   #388
BUSA's Avatar
Thanked: 23 Times
I want to go in for light upgrade on my Optra and Swift.
The Optra has 4 bulbs for the headlamps and 2 for the fogs.
The Swift has 2 bulbs for the headlamps and 2 for the fogs.
Not taking into account the parking lamps.
My driving is 50% highway 50% City.
I want really good lamps. Looking to go in for 100/90 with Bosch relay. Now i have a few questions, lightning experts like tsk and tyre dealers with lightning knowledge like irags please put your inputs :-
  1. Osram Silverstar, how good are they, Are they white in colour as i have heard White light disperses easily and gets mixed in the background. Yellow light is better seen in a car on the road.
  2. Which lights to go in for foglights and what wattage.
  3. Swift & Optra lamps/fogs use which bulbs, h1, h7, etc
BUSA is offline
Old 24th May 2007, 12:14   #389
horsepower's Avatar
hi! Guys, Need your help. Booked swift vdi and I would like to know what all option I have when it comes to upgrade headlights?
I understand I can go for higher wattage bulbs. Will they void warranty if fitted? Does anyone know what wattage bulbs are fitted as standard in swift?
horsepower is offline
Old 24th May 2007, 12:26   #390
tsk1979's Avatar
Yes yellow right is better for foggy conditions. In normal circumstances, white light(not yellow light made white by blue glass as is the case of bluevision) will do great. Osram does not have very white light. Just slightly whiter. They are a safe option if you don't want to increase wattage
  1. Which lights to go in for foglights and what wattage.
  2. Swift & Optra lamps/fogs use which bulbs, h1, h7, etc
Swift has H4 in headlamps. As for others, see your owners manual, or take out the bulb and read whats written. Wattage is usually 50W but may vary 5W here or there. Putting more powerful lights in fogs wont help much as that light mostly falls right in front of you. It will help to get something more powerful for the main beam,
Swift has 60/55W H4.
As for warranty on using 100/90 you never know. I used 130/110 also in my indica, but no warranty issues. Now its out of warranty anyways. But if your dealer says that your alternator failed due to overload, you cannot argue. Its purely your call. A good option will be to get relay and 100/90 fitted from a MASS. TASS guys do it, don't know about maruti.
tsk1979 is offline
