Old 28th June 2015, 16:37   #1426
sunnyman_46's Avatar
Thanked: 11 Times
Re: Honda Brio : Test Drive & Review
Originally Posted by sunnyman_46 View Post
Hi Friends,
Of recently I have felt a kind of missing in log gears, mainly 1st which comes very rarely. Say in a traffic signal where the accelerator pedal simply goes down without making the rpm high or moving the car forward. Anybody have any clue on this?
SUNNY
Anybody facing this problem? Please help
sunnyman_46 is offline
Old 29th June 2015, 09:30   #1427
sgiitk's Avatar
Thanked: 4,809 Times
Originally Posted by rokindotnish View Post
@sgiitk Yes Sir, I totally understand... I try not to push her to high revs yet since the engine is running in (1600 kms) . But I can feel the power.
You do not have to pussy foot the engine these days, so I have a feeling going to say 5000 rpm is kosher even in the so called running in. Just do not cane it!
sgiitk is offline
Old 29th June 2015, 10:05   #1428
Thanked: 11 Times
Thank you Sir, I up gears when tacho crosses 2k and try keeping it under 3k ... The max speed I have gone till is below 75kmph...
I was following the tbhp running in thread...
So it is OK to rev her up till 5?
And how long will we have to wait take till we can push her to limits?
rokindotnish is offline
Old 29th June 2015, 10:51   #1429
gpa
gpa's Avatar
Thanked: 366 Times
Of recently I have felt a kind of missing in low gears, mainly 1st which comes very rarely. Say in a traffic signal where the accelerator pedal simply goes down without making the rpm high or moving the car forward. Anybody have any clue on this?
I've never faced such an issue in the three plus years I've owned the Brio. It appears to be a problem with the drive-by-wire throttle module located near the accelerator pedal. Ask your H.A.S.S to run an OBD scan which should point out the problem. If you have one of those Bluetooth OBD diagnostics port readers, you can even check this yourself and then approach H.A.S.S for a replacement under warranty.
gpa is offline   (1) Thanks
Old 29th June 2015, 11:18   #1430
tarunchoudhary's Avatar
I have completed 30 months and 36000 kms on my Brio VMT. Kind of agree with most pros and cons listed above. On FE, I get about 15 kmpl without AC and about 12.5-13.0 kmpl with AC. Driven in normal city traffic in Delhi.
tarunchoudhary is offline
Old 29th June 2015, 13:32   #1431
Thanked: 815 Times
Offlate I am noticing a rattling noise from tail gate glass. Looks like the bushes need replacement. Has anyone faced this issue?
MaxTorque is offline
Old 29th June 2015, 18:13   #1432
sgiitk's Avatar
Say 5,000km max. Also, modern Japanese engines are made to very fine tolerances. The running in thread, I saw it ages ago, but used my common sense. One trick I learnt, on the highways, lift off for few seconds every few minutes, to allow proper oil circulation,
sgiitk is offline   (1) Thanks
Old 29th June 2015, 21:37   #1433
Thanked: 11 Times
Thank you for the advice Sir.
I would also like to ask your opinion about one observation I made. The company advised tyre pressure for Brio is 29 for Front and 26 for rear wheels. However, before a long journey I checked the tyre pressure (after 3 weeks of car delivery) and asked the air guy to fill in 29 on all tyres. To my amazement, when he put the air pump to the tyre, it showed current tyre pressure as 31or 33! However, I made it 29 on all tyres. After which, I feel some lack of pull on the car.
Do you suggest I go back to 33 ?
Old 29th June 2015, 22:28   #1434
Thanked: 301 Times
The company advised tyre pressure for Brio is 29 for Front and 26 for rear wheels.\To my amazement, when he put the air pump to the tyre, it showed current tyre pressure as 31or 33! However, I made it 29 on all tyres. After which, I feel some lack of pull on the car.
Actually this lack of pull makes perfect sense.
The company recommended pressures are "COLD" pressures. What happens to the air in the tyres after you drive the car / bike for a couple of kms.? It heats up.
The thumbrule is that after heating up, the pressure goes up by 2 or 3 psi. So when you tyres showed 33 , it must have been correctly inflated. Now after your reduced pressure, it must be closer to 25 cold air pressure.
john doe is offline
Old 29th June 2015, 23:42   #1435
abhi29's Avatar
Thanked: 87 Times
Hi Friends,
SUNNY
I experienced exactly the same thing a couple of days back. It was at a traffic signal when the car simply refused to move on first gear. Amidst some crazy honking, I took a good 10 seconds to realise whats happening, turned off the ignition, restarted and it just picked up as if nothing had happened. It was the first and last hiccup, not sure what the reason was.
Do share if you happen to find something about this. I hope its nothing serious.
abhi29 is offline
Old 30th June 2015, 08:09   #1436
sgiitk's Avatar
I also found all my Hondas overinflated at delivery. Some discreet snooping turned up, that in order to prevent shipping damage cars are overinflated when loaded onto the trailers. Often they do not bother to disinflate correctly.
I stick to 29/26 Cold in my Brio. I have a battery powered pump, so am doing the checking cold.
sgiitk is offline
Old 2nd July 2015, 20:25   #1437
Thanked: 181 Times
Test drove the Brio yesterday. Was really impressed with the compact size and inside space of the vehicle. Much better than the Bolt which i also had a test drive. Whole family is satisfied with the value that offers. We wanted to buy the E mt model as we are tight on budget , and its mainly for town use( i am from a small town that doesn't have even a single traffic signal) and i got Xuv for long journey .
BUT the dealer says that honda has stopped E and Ex model and he can only provide me S or V model. Is it true guys ? Can somebody confirm that ? This is from TVS sundaram motors .
undead is offline   (1) Thanks
Old 2nd July 2015, 20:28   #1438
frankmehta's Avatar
Thanked: 3,669 Times
My e mt. Ready for delivery. Gone for registration. It's a June 2015 model. These photos were taken when the car was just off the trailer. ☺️
frankmehta is offline
Old 3rd July 2015, 01:14   #1439
Hello! Can you guys share your FE figures of AT Brio?
I have Brio VAT now completed 2 years & 17000KM. Mostly in city. And I am getting consistently 8-9 kmpl in the city & 13-13.5kmpl on highway with AC in both the cases.
Aniruddha C.H. is offline
Old 3rd July 2015, 09:59   #1440
Thanked: 11 Times
Originally Posted by undead View Post
Test drove the Brio yesterday. Was really impressed with the compact size and inside space of the vehicle. Much better than the Bolt which i Can somebody confirm that ? This is from TVS sundaram motors .
Probably the dealer has unsold cars left in their yard, and want to sell them off to you rather than your preferred one...
Insist that you want E, or that you will quit buying it...
-Cheers!
