Old 9th January 2025, 23:30   #2266
Turbanator's Avatar
Thanked: 32,002 Times
Re: Mahindra Thar Roxx Review
Originally Posted by shivamk11 View Post
if I want to go for spacers on my stock AX7L tyres and alloys then is Proman a safe and reliable choice?
If you are doing this purely from aesthetics, Yes. It’s a good brand and you can go ahead. Probably 30 mm should be enough unless you want these to come out even more. Speak to the person and talk what exactly you are looking for. I will personally not add anything on stock wheels though. But it’s only for looks, so it’s highly personal. No right or wrong
Originally Posted by SteeringWheel View Post
One thing to consider when using 10mm or similar spacers is that you are loosing thread thread engagement by that much.
Not just thread but existing bolts will foul. Also producing so thin is not possible. The lowest possible seems to be around 22 mm which is barely enough on front hubs if retain OEM bolts and on rear we must go 30mm. Pics from my past post are explanatory. I think fellow member is having troubles due to vibrations.
Turbanator is offline   (2) Thanks
Old 9th January 2025, 23:48   #2267
Thanked: 79 Times
Originally Posted by 84.monsoon View Post
Has anyone tried fitting the original AX5L/AX7L Headlamps with the C-Shaped DRLs on the MX3? The below YouTube video from a Karol Bagh shop owner claims that this headlamp is a direct plug and play on the lower MX1/MX3 variants using the same coupler. Even if this is the case, how does one control the DRL using the driving stalk controls provided on the MX3? Would turning it on also turn on standard flat DRLs on the side edges of the car? So then one drives around with 4 DRLs (2 C-shaped and 2 flat?)
Currently the problem with MX3 DRLs (flat ones on sides of the car) is that they need to be switched on by moving the headlight control one step to the parking lamp position. Once you do that, the ICE screen automatically switches to dark (night) mode, which is distracting and not very good for navigation maps etc. in the daytime.
https://Youtu.be/4Tv6urHdGdk?feature=shared
Mahindra may or may not bring this feature to control DRL on lower variants, but this can be done through an after market Canbus Module. These modules have programmed software code that superimposes vehicle's stock software and add software features that were not available originally.
I am using a Canbus module on obd port of my Mercedes E-250 to get moving guidelines on reverse parking camera.
And such Canbus Modules do exist for Mahindra 3xO for Fog Lamp Switch unlock, for Scorpio N for rear camera unlock and one latest for Thar Roxx too for getting Front Camera and Parking sensors to work on lowet variants. Check the attached video.
This opens up many possibilities for the future!
lk_gunner is offline   (6) Thanks
Old 10th January 2025, 00:42   #2268
Thanked: 55 Times
Thanks, and you are happy with your set up from a performance perspective, right? With no vibrations, or pull or any other issue?
Jayhawker is offline
Old 10th January 2025, 05:18   #2269
Turbanator's Avatar
I haven't got chance to drive much as I came overseas. Once back I plan to do a trip to NE and will update.
Turbanator is offline   (1) Thanks
Old 10th January 2025, 11:22   #2270
CU23's Avatar
Thanked: 33 Times
ProMan guys should be able to ship to you directly with or without charge - You can reach out to them at 9310273922. 30 mm costs Rs 14900. You can use 20 mm in front but at the rear 30 mm is a must as I have described earlier. Alternatively, most tyre shop sellers can get you at similar rates. They do good quality and I won't look elsewhere.
I spoke to the guy he says the minimum is 25mm. Will these suit for Roxx front?
Or should I go for 30mm for both front and rear, will be running stock tyres 19” initially..!
CU23 is offline
Old 10th January 2025, 14:22   #2271
Turbanator's Avatar
You cannot be wrong with either. Very personal choice as it's purely for aesthetic reasons in your case. I went with the smallest as I wanted to be close to stock and would not have even added but for the rubbing on my after-market alloys.
Old 10th January 2025, 17:46   #2272
ashesh's Avatar
Thanked: 365 Times
Originally Posted by ashesh View Post
First service of Thar Roxx is a mixed bag for me. I booked the service for 9th Jan 2025 11:00 AM through the app. I got many reminders from the service center to confirm my visit which was reassuring.
UPDATE: Today morning(10th Jan) the service executive called to send the replacement. The Roof console was replaced by the evening. All's well that ends well
Glad to see Mahindra taking the right steps for customer service.
ashesh is offline
Old 10th January 2025, 17:51   #2273
Thanked: 39 Times
Hi Sir, Can you share a picture of the part that has been replaced? I have an AX5L and I want to understand what the Roof Console looks like. Is it the part which houses the cabin LED lights, the MIC, sunglass holder? My sunglass keeps rattling whenever I encounter a bump. I have clocked 1K kms and I wish to be mindful of this replacement when I go for the first service at 2k kms.
lawyeronwheels is offline   (1) Thanks
Old 10th January 2025, 21:00   #2274
ashesh's Avatar
Thanked: 365 Times
Name:  Screenshot 20250110 205833.png
Yes, it's this one.
ashesh is offline   (1) Thanks
Old 11th January 2025, 02:09   #2275
Thanked: 1,337 Times
Hi Sir, can you recommend a good detailing studio for Ceramic Coating in Delhi/Noida. Is Carzspa reliable? I want to go for a 5 year plan.
I got mine done from Lords of Detailing in Wazirabad, Gurgaon. The owners Minny and Binny work out of this flagship studio.
https://maps.app.goo.gl/NZDk6EJ4Lzdz...s.preview.copy
You should tell them you found them on team bhp. I think I have added photo and video of my Thar in an earlier post.
Does anyone had any experience regarding this type of DRL installation in existing headlights?
I think this Red DRL on my black Thar would look wonderful.
Starts at 2:35
Last edited by Chetan_Rao : 11th January 2025 at 12:34. Reason: Merged consecutive posts.
vellatechie is offline   (1) Thanks
Old 11th January 2025, 09:58   #2276
Thanked: 186 Times
Can anyone confirm this for Thar Roxx 4*4, I plan to get negative offset alloys with 20" alloys with size 5*114.3*12J * -44mm.
1) Will this require cutting of bumper or any other part. If yes then what is the next best option?
2) Will tyre size 285/50/20 fit, if yes what will least noisy tyre options.
Puneet0051 is offline
Old 11th January 2025, 14:18   #2277
Thanked: 535 Times
Am double minded about Roxx and initials euphoria has died down with logic coming in like better to Leverage this amount elsewhere. What is Cancellation duration and charges
iskandariya is offline
Old 11th January 2025, 14:59   #2278
Thanked: 1,271 Times
I cancelled both my Thar Roxx bookings in December as there was no response from dealer, SA and sales manager. I escalated to Mahindra support to get delivery timelines, but by the time support team came back I was fed up and did not want to give my money to unethical dealer, even if they gave me a car.
It takes about 3 weeks to get the refund back to the original payment mode used to book online.
I would suggest you take a snapshot of each screen presented to you in the cancellation process on https://auto.mahindra.com. This is to make sure you have details available if for any reason the booking suddenly disappears.
Cancellation process:
  1. If you booked online, then cancel from online booking portal
  2. Save snapshots of your cancellation
  3. Send email to bookingsupport@mahindra.com with cancellation details
  4. Wait for 1-2 weeks to get response from support
  5. The dealer will call you about 3-5 days after you initiate cancellation to send copy of cancelled cheque and bank details to issue refund.
  6. These are not needed as I got refund back to my original payment source even after sending my bank details to one dealer.
kgt.v8 is offline   (1) Thanks
Old 11th January 2025, 19:18   #2279
SLK
SLK's Avatar
Thanked: 1,431 Times
I think i read somewhere that no cancelation charges till December, not sure though. I cancelled on 31st Dec and got refund by 6th Jan.
SLK is online now   (2) Thanks
Old 12th January 2025, 01:59   #2280
Thanked: 79 Times
Starts at 2:35
https://Youtu.be/ASXChh_HKoo?si=Z6WTh6C4LXkqfesb
Yes, I have got it done for Rs 4500.
Single colour only. But the colour is little bluish. The upper variants DRL is warmer. The shop guy said that within a month same colour DRL is coming in the market.
I have done the wiring such that DRL is always on with ignition (not with park lights). The silicon re-seal of lights has been done pretty well and in multiple layers, but only time will tell if it withstand the test of water and heat of Indian summer.
