Old 20th September 2008, 09:37   #361
kpzen's Avatar
Thanked: 1,882 Times
Nisarg86: 205/50-15 is a wrong upsize for Swift and there will be substantial decrease in GC.
Get 205/55-15 or 195/60-15.
kpzen is offline
Old 20th September 2008, 10:15   #362
nisarg86's Avatar
Thanked: 13 Times
Thanx s0uljah & kpzen. I will go with 205/55-15. I m thinking to change the tyres on the day1 itself. so i can the maximum buyback offer. Tyre dealer quoted me 1700 Rs for OEM tyre. is it a wise thing to do ?
nisarg86 is offline
Old 20th September 2008, 10:54   #363
pjbiju's Avatar
Thanked: 1,134 Times
Originally Posted by rippergeo View Post
thats what I've been using on the VDi. so far, its all good. thats the stock size for the zxi anyway.
The rim sizes are different for VXi and ZXi. The manual says 14x5½ JJ for 185 and 14x5J for 165 tyres. But then may be 5J can take the 185 size.
pjbiju is offline
Old 20th September 2008, 12:25   #364
DieselFan's Avatar
Thanked: 260 Times
Rippergeo ZXI has alloy wheels of different width. Are you using 185/70 on stock steel wheels?
DieselFan is offline
Old 20th September 2008, 18:27   #365
rippergeo
Posts: n/a
yes on stock steel rims thats the largest(185/70) I can use.
if I had the Zxi alloys, I'd be using 195s.
Old 26th September 2008, 21:36   #366
right tire pressure
hello guys
i have just upsized my tires to 205 55 15 for my swift vdi.is it right upsize and bad for suspension on long run?the road conditions here are pretty bad .i drive s for arpund 40 km daily with me and my dad.
can anyone please tell me ideal pressure for good comfort and mileage pls help i am confused.
prince is offline
Old 27th September 2008, 02:13   #367
ghostrider's Avatar
Thanked: 506 Times
Prince, 205/55 R15 is fine, it won't foul with the arches.
You're decreasing the overall diamater (OD) by 1.3%, which is well within permissible limits.
But... if you're really driving on bad roads, then maybe the same rim (15") with a slightly narrower Tyre (195) and a slightly taller profile (60) would have been the better choice. In fact, 195/60 R15 is actually the best upsize for the car since it's only a difference of 0.81% to the overall diameter of the rim of the VXi, and is the same OD as the ZXi.
Avoid deep ruts and potholes like the plague, and you should be fine. Your PSI should be between 28 and 30. Get a good tyre pressure gauge and choose a setting within 28 and 30 that works for you.
Btw... the fatter rubber is going to reduce your fuel economy.
Originally Posted by prince View Post
hello guys
ghostrider is offline
Old 29th September 2008, 21:20   #368
anshurao's Avatar
Thanked: 85 Times
hello guys
Hey, it's not just the tyre size, you'll need to take into consideration the offset of your 15" mags. wrong offset can have adverse effects on your suspension. I too am running my Swift on 205/55-R15, Mileage has dropped by about 1Kmpl No problems otherwise.
anshurao is offline
Old 1st October 2008, 08:47   #369
upsizing wheels and tyres for my swift
hi guys , i m goin to upsize my swift vdi with 15 inch alloy . Also planning for 195/60/R 15 tyres from YOKOHAMA or MICHELIN ENERGY MXV8 or PILOR preceda .. which of these tyres will be good and what is the approximate cost of these tyres .
jakky88 is offline
Old 1st October 2008, 17:08   #370
14" 195/65r14
15" 185/65r15,195/60/15
17" 205/45/17,235,40,17
Originally Posted by hemlock View Post
Hi Guys,
what do you think are the best tyre upgrade options for the swift, i'm planning to go for a Swift Vxi ABS and i was told that they come with 165/80 R 14 Tubeless tyres, with normal rims.
It would be great if someone could walk me through the possible options and also the approx pricing. I'm looking to upgrade to 185/70 R 14's.
hchawla is offline
Old 1st October 2008, 21:30   #371
kpzen's Avatar
Originally Posted by hchawla View Post
14" 195/65r14
Chawla ji
u have replied to a 3 year old post.
Please check the dates before posting.
kpzen is offline
Old 1st October 2008, 21:57   #372
anshurao's Avatar
Thanked: 85 Times
The gurus say that Michelin MXV-8 is a great tyre.
Michelin MXV-8 should cost you 4400/tyre
Yokohama ES100 should be around 3500
anshurao is offline
Old 3rd October 2008, 13:38   #373
ghostrider's Avatar
Thanked: 506 Times
Jakky,
Go for the Yokohama A-Drives. I just had these fitted to my new Swift two weeks ago with 15" rims.
The Michelin MXV8s are great, but a little pricier than the Yokohamas for no major benefits. Don't get the Pilot Precedas, because quite a few people on this board (including a couple of tyre gurus) have had problems with bulges and tears.
The Yokohamas are great, they're very comfortable, and I get virtually no road noise. You'll really like the experience.
I paid 3900 per tyre, and got 1,000 back for my stock tyres (which were brand new), so I paid a net of 2900 per tyre.
Old 4th October 2008, 16:36   #374
thanx a lot .. Am looking for Hijoin alloys 15inch... which one would be good.. Send ur pics
jakky88 is offline
Old 4th October 2008, 19:54   #375
ghostrider's Avatar
Thanked: 506 Times
No problem. Here's the link to the post with the pics.
LINK.
