Old 21st October 2011, 19:17   #2506
Thanked: 315 Times
re: Honda Civic : Maintenance, Service Costs and Must dos
Originally Posted by dip27in View Post
Dear gurus,
My civic has a problem with the Air Conditioning. It seems, after 30/40 mins of driving with the AC ON, it stops working. I can only hear sound of Air gushing out but the volume of air is reduced almost to 10-15% of what it should be! If I stop the AC for sometime, say after 5/10 minutes, it once again becomes the same old chilling experience!
I have not yet taken the car to service centre. I have noticed and have been able to replicate this problem couple of times also.
It is the compressor relay. It is failing. So when you use the AC it overheats after some time and fails to function. Once it cools down, it works again. It needs to be replaced. Cost me about Rs. 1,100/-.
sandeep108 is offline   (1) Thanks
Old 21st October 2011, 21:09   #2507
jatinpatel's Avatar
Thanked: 196 Times
Guys
got a problem,
whenever i drive enthusiastically with AC on, after 3.5k RPM the ac compressor cuts off and chilled air stops coming out of the air vents.
But if i drive between 900-3500 rpm it keeps on throwing chilled air.
Car is 07 V A/T done 46k kms
Can someone help ?
recently AC gas was topped up, Honda and also my mechanic said that AC service was not required only gas top up was required.
jatinpatel is offline
Old 21st October 2011, 23:28   #2508
Thanked: 568 Times
@Sandeep108 does it come under warranty replacement? My car is still under extended warranty.
dip27in is offline
Old 22nd October 2011, 16:41   #2509
jatinpatel's Avatar
Thanked: 196 Times
Guys please can anyone help me out?
today while going to my native place in gujrat my dad was driving and i was not there, the ac stopped cooling intermittently and after a while no cooling. and after sometime it started working again but not in a constant and required manner but in a ON-OFF manner and hence not cooling the car.
can anyone help?
Old 22nd October 2011, 17:47   #2510
Thanked: 76 Times
Originally Posted by ramanak View Post
She gave me a staggering 26.9 KMPL (Oil was changed recently) today (day time run) without A/C and 2 people + lots of luggage.The figure is as per the trip meter over 150 KM distance.How reliable is the reading from Trip meter? I will also check and post the mileage after filling up the tank.
But I must admit that it was a super boring feat driving at those speeds for a long time.
Cheers.
Uploading photo.The photo with 26.9 kmpl was not very clear.So uploaded this one.
Cheers.
Honda Civic : Maintenance, Service Costs and Must dos-civic-mileage-run-picture.jpg
ramanak is offline   (2) Thanks
Old 22nd October 2011, 17:52   #2511
Thanked: 315 Times
In my view it should be under extended warranty.
can anyone help?
See my post about the compressor relay. It's life is over. When it overheats, it fails, so it does not function when required. When cold, it works fine but after a few minutes it overheats and fails. It needs to be replaced.
Old 22nd October 2011, 19:51   #2512
dot
dot's Avatar
Thanked: 734 Times
When the relay starts to overheat, does it also makes more noise than usual?
dot is offline
Old 22nd October 2011, 20:22   #2513
Thanked: 315 Times
Not that I noticed. It simply does not work, so the compressor does not switch on. Maybe when it tries again and again there may be some noise.
Old 22nd October 2011, 22:59   #2514
jatinpatel's Avatar
Thanked: 196 Times
@sandeep
How and who traced your problem ?
Local mechanic or Honda A.S.S
If Honda A.s.s what did you tell them specifically to check?
where is the relay located?
and the cost you have mentioned above is it a Honda Price?
Old 23rd October 2011, 04:28   #2515
Thanked: 72 Times
Hey guys, need your help! I had gone to my vendor to get the final element of my ICE installed ( a Focal monobloack amp)! everything was going as per plan and the amp was successfully installed when suddenly out of nowhere the dash shows an "engine check" light! A few unofficial calls to the Honda people convinced me to drive it back home (I was told it's a minor thing and will be rectified through a scan on Monday)! However, barely 5 minutes of drive later, the car throttle became unresponsive and completely died within 10 mins! Had to call the road side assistance and had the vehicle towed over to Arya service! What could have possibly gone wrong?? the car is 2 years old with insurance and extended warranty! This is the first ever such case with this car and i really cant figure out what could have possibly gone wrong!
rohan.xj is offline
Old 23rd October 2011, 16:24   #2516
Thanked: 568 Times
Check for the loose battery terminal or loose earth earthing of the amp. Did they cut any OEM wiring harness ?
dip27in is offline
Old 23rd October 2011, 19:18   #2517
dot
dot's Avatar
Thanked: 734 Times
I agree with dip27in here. It is possible that the ground or one of the battery cables is cut/loose. Maybe some other wiring harness like the MAF is left open. I doubt that the installers could have cut any other cable or wiring harness. Do let us know what had happened and what code was logged in the OBD.
dot is offline
Old 23rd October 2011, 21:15   #2518
Thanked: 315 Times
@sandeep
Honda A.s.s. Relay located in fuse /relay box.
Old 23rd October 2011, 21:20   #2519
Thanked: 72 Times
The installer checked the entire wiring but no loose connections! No OEM wiring harness was touched!
Will let you know the code and remedies!
Still can't understand what could possibly affect the throttle control??
rohan.xj is offline   (1) Thanks
Old 26th October 2011, 00:05   #2520
jatinpatel's Avatar
Thanked: 196 Times
@rohan
probably a busted throttle pedal position sensor, as this is the sensor which communicates ur throttle pedal position to ecm which inturn controls the amount of actuation of the throttle valve.
