Old 28th April 2017, 15:08   #1456
harsh79's Avatar
Thanked: 798 Times
Re: The Dashcam / Car Video Recorder (DVR) Thread
Originally Posted by techcoze View Post
Does anyone know where I can buy polarizer filter for A118C? Lot of dash reflections in video recording, planning to buy polarizer filter (if not very expensive)
VIOFO makes one for the A118C V2 (same one that fits the A119 and A119S) but it won't fit the V1 A118C.
This is how I DIY'd one - http://www.team-bhp.com/forum/car-en...ml#post4008188
There's a drastic drop in night quality, I'd suggest you take it off post evening if going this route.
Check out the difference for yourself
Without CPL
With CPL
Without CPL
With CPL
harsh79 is offline
Old 28th April 2017, 16:00   #1457
techcoze's Avatar
Thanked: 241 Times
Thanks for the review. Night time quality drop is serious, it won't be always feasible to remove CPL in evening, and re-attach in morning. Dashcam should be kind of fit and forget system.
Now i think I should be better off from CPL
techcoze is offline
Old 28th April 2017, 16:17   #1458
harsh79's Avatar
Thanked: 798 Times
The 'fit and forget' IMO applies only to installing one and once set up not needing to press any buttons or fiddle around. Certainly need to keep an eye on the recording indicator and periodically check the SD card for errors.
The SD card and power supply are the weakest links.
harsh79 is offline
Old 28th April 2017, 16:23   #1459
techcoze's Avatar
Thanked: 241 Times
Absolutely! That's what I meant by 'fit and forget'. Agree about SD card possible corruption. Windshield mount location makes it exposed to a lot of heat and premature SD card corruption should not be surprising.
techcoze is offline
Old 29th April 2017, 05:50   #1460
treadmark's Avatar
Thanked: 337 Times
I'm getting VIOFO A119 from US. Where can I get hardwire kit here in Bangalore? Also had anyone hardwired their dashcams in Bangalore, if yes please suggest the place and contact.
Also I saw that many sellers are selling the dashcam with 32 GB Transcend High Endurance memory card, is it worth to buy or should I stick with normal SD card?
Cheers!
treadmark is offline
Old 30th April 2017, 19:08   #1461
simonkayar's Avatar
Thanked: 91 Times
Received my A119 from Aliexpress (straight 2 weeks). Cost was 5750 with GPS mount and CPS filter. Installed in my XUV and pretty good results. Impressive !!
Some points on the dash cam
+ Excellent video quality
+ Night time quality is very much usable (tested in basement)
+ Value for money
+ Design is barely noticeable from outside and is well hidden inside
- Pulling out micro SD card was not easy
- The camera attaching to the GPS mount is not very firm, it seems slightly loose or wobbly
As per reviews, it seems Transcend/Lexar endurance cards are the best. If not available or looking for cheaper option please take a look at 633X Lexar. For a quick option (short time) Samsung Evo/Evo+ seems to work fine (I am using this but planning to replace within a month or so)
simonkayar is offline   (1) Thanks
Old 30th April 2017, 20:27   #1462
Happysmiles's Avatar
Thanked: 280 Times
+ Value for money
- The camera attaching to the GPS mount is not very firm, it seems slightly loose or wobbly.......
I too, am looking for ordering from aliexpress. Any specific reason for choosing the A119 over the newer A119s.
Which seller? Please post the link.
Also waiting for picture and video reviews.
Happysmiles is offline
Old 30th April 2017, 22:14   #1463
Thanked: 1,788 Times
The link is just a page or two behind.
abhi7013 is offline
Old 1st May 2017, 09:03   #1464
simonkayar's Avatar
Thanked: 91 Times
Originally Posted by abhi7013 View Post
This is the link that Abhi and I used.
Main reason : At least 20$ lesser in price
Link comparing both: https://www.carcamcentral.com/review/viofo-a119-review
Other reasons that I told myself :-)
* A119 is probably tested well compared to newer A119S
* A119 has wider view angle
* Has higher resolution video compared to just 1080p of A119S
* Sideways adjustment of camera
Old 4th May 2017, 13:31   #1465
ankan.m.blr's Avatar
Thanked: 997 Times
Team BHPians, need your suggestion for my first dashcam.
Requirements:
1. inexpensive (Chinese unbranded ones are fine ). HD is not mandatory.
2. USB powered (from 12V socket)
3. Will be placed on a non-slip mat on the dashboard; suction mount not required
4. should delete old video and continue recording once memory is full
5. Preferably 4 hrs+ recording capacity
6. Size as slim as possible. Even a dashcam without display is fine. As long as I can connect it to my smartphone and playback the videos.
This will be my first dashcam, so need an inexpensive one. Going by the experience, I may acquire a Transcend Drivepro and attach it on the front windscreen. The old one will be relegated to the rear windscreen.
ankan.m.blr is offline
Old 4th May 2017, 14:13   #1466
Thanked: 7,691 Times
Requirements:
You will invariably upgrade in no time.
Go for a good one, from get-go rather than spending money on a not-so-good product now and upgrading later.
I am concerned about keeping the cam on dashboard. It will not give you good coverage. Due to the wipers and dash curves, even the vehicle dead in front of you might not be visible. You can decide on the placement once the camera is with you.
Dry Ice is offline   (1) Thanks
Old 4th May 2017, 14:23   #1467
treadmark's Avatar
Thanked: 337 Times
Recently updated A119 is selling for INR 7500 to 8000 (including GPS mount and CPS filter). They are not available for 5K even on mobile APP.
Did you went for hard wiring or with USB?
Heard the GPS mount issue is fixed with new models, which one of the below did you received?
The Dashcam / Car Video Recorder (DVR) Thread-a119.jpg
Old 4th May 2017, 14:27   #1468
Thanked: 988 Times
Requirements:
Quoting my own post -
Originally Posted by shifu View Post
For a first timer on a budget of Rs 4k or so (including the fuse tap and the hard wire kit), is this good enough?
Link - Amazon
This doesn't have a screen, doesn't come with a suction mount(but I was planning on putting it behind the rear view mirror. Not sure if dashboard is appropriate). The power is probably not USB though.
Check it out...
Disclaimer - I didn't buy this but was seriously considering buying this. Ended up buying its expensive cousin...
shifu is offline   (1) Thanks
Old 5th May 2017, 09:41   #1469
simonkayar's Avatar
Thanked: 91 Times
Recently updated A119 is selling for INR 7500 to 8000 (including GPS mount and CPS filter). They are not available for 5K even on mobile APP. Heard the GPS mount issue is fixed with new models, which one of the below did you received?
Mine is old type according to your post, but I am able to pull GPS data without issues. I got the USB socket version with both GPS and CPS filter.
I thought the update to A119 was A119S (with Sony sensor). Anyway, pretty happy with the purchase.
Old 5th May 2017, 11:06   #1470
treadmark's Avatar
Thanked: 337 Times
I should have mentioned it clearly, the one in picture was not a comparison between A119 and A119S but is between A119 and A119 Version 2 (the newly launched one)
More details can be found HERE and HERE
The new one comes with EVA Foam for more stability with or without GPS logger
Cheers!
