Old 1st February 2008, 19:15   #7576
nitinralli's Avatar
Thanked: 1,122 Times
Well i have a woofer in sealed box in the boot. so if i change the rear parcel, i should go for a hole between the rear speakers? do u think its a good idea to get the woofer inside as in in the rear parcel tray, will that be better or a woofer in sealed box in boot?
nitinralli is offline
Old 1st February 2008, 20:52   #7577
Thanked: 311 Times
Well it depends entirely on where the intended audience is!
anupmathur is offline
Old 1st February 2008, 22:05   #7578
nitinralli's Avatar
In Front. Most of the time i drive alone.
Old 3rd February 2008, 00:48   #7579
razor4077's Avatar
Thanked: 300 Times
Quick question regd amps. Can an amp make a set of speakers sound "brighter" than another amp with similar settings?
Was running my Illusion compos off a Soundstream amp (dunno the model) for a while and have now switched to my JBL 75.4. The treble is definitely much higher now... having to set the treble to negative on the HU to enjoy the sound.
razor4077 is offline
Old 3rd February 2008, 00:52   #7580
gunbir's Avatar
Thanked: 33 Times
Yes Razor, amps influence the sound...
gunbir is offline
Old 3rd February 2008, 01:09   #7581
ramie2400's Avatar
Thanked: 66 Times
Gurus how do you wire 2 x DVC Subwoofers to 1 x 1 or 2ohm Mono Block???I have not tried this ever but in a couple of months planning to get a Mono Block installed.. Thankyou.
Ramie
ramie2400 is offline
Old 3rd February 2008, 14:40   #7582
Thanked: 306 Times
Ramie
You have a 4 ohms dvc sub. so you can wire the two at 4ohms or 1 ohms. What final impedance you need to have ?
low_bass_makker is offline
Old 3rd February 2008, 15:21   #7583
razor4077's Avatar
Thanked: 300 Times
Ok.
Now is it possible to tweak the settings on the amp (frequency, input level, hpf/lpf/flat) to make the front compos sound a little less bright? I am happy with the way the sub sounds, but the front is a little too "treble-y" for me!!
Old 3rd February 2008, 16:19   #7584
navin's Avatar
Thanked: 9,999 Times
Ok.
Not really few amps have HF controls. Your HU will have though and try dropping the treble down 1-2db.
navin is offline
Old 3rd February 2008, 18:32   #7585
Bass&Trouble's Avatar
Thanked: 137 Times
Strange. A change of amp should not cause such a huge increase in treble.
Use the jumper in the crossover to attenuate the tweeter by 3dB. Instructions are in the manual. If you dont have it, I could give you a soft copy.
Bass&Trouble is offline
Old 3rd February 2008, 20:35   #7586
Thanked: 306 Times
There can be a change that I agree but that great is strange to hear that. I have listen to a similar setup with Illusion Electra fronts with 75.4 and kenwood HU it was sound sweet.
Try adjusting the tweeter level from the cross over.
Old 3rd February 2008, 21:06   #7587
razor4077's Avatar
Thanked: 300 Times
That's what I am doing currently... was wondering if this could be tacked at the amp level itself.
This confused me as well. Maybe I've gotten used to the more sober output caused by the Soundstream amp (suits my taste to be honest). Will have to play around with the amp & HU settings more to find the sweet spot.
Could you mail me a soft copy? Will have to do some hunting around for the manual otherwise! Thanks Ajay!
Old 3rd February 2008, 23:12   #7588
navin's Avatar
for the brave, the best place to attack this would be at the crosoover.
navin is offline
Old 4th February 2008, 00:33   #7589
razor4077's Avatar
Thanked: 300 Times
Lol... now I'm wary! Will proceed with extreme caution!
Old 4th February 2008, 07:55   #7590
moralfibre's Avatar
Thanked: 14,525 Times
Quite simple there Razor, open the front plexiglass of your XO. On the lower left of the XO you'll see a total of 6 pins out of which 2 are jumped using a jumper. Try all three and see which suits you best. IIRC lowest is 0 DB, 2nd is -3DB and the topmost is +3DB. Try the -3 DB jump.
moralfibre is offline
