Old 23rd November 2015, 14:38   #541
Thanked: 477 Times
Re: Tyre pressure gauge and portable inflator pump / foot pump
Tyre pressure gauge and portable inflator pump / foot pump-image.jpeg
I bought a basic gauge locally. It can be attached to your keychain. Readings are in PSI and Kg.
Costed about Rs. 45 in Singapore.
I hope the attached images give an idea of what it's like.
Accurate? To some extent. You won't get the 2 nd decimal accuracy.
Tyre pressure gauge and portable inflator pump / foot pump-image.jpg
hangover is offline
Old 23rd November 2015, 16:59   #542
Thanked: 43 Times
Originally Posted by deepv View Post
Which model was that? And how much it came to be?
It's MN-4205 and bought it for 1800.
msiva75 is offline
Old 24th November 2015, 19:50   #543
Leoshashi's Avatar
Thanked: 42,424 Times
My Maruti Genuine Accessories(MGA) branded Tyre maintenance kit.
It includes
1. MGA Tyre inflator-Part No. 990J0M999W0-020 MRP Rs 1,990/-
2. MGA Tyre Pressure Gauge-Part No. 990J0M999W0-040 MRP Rs.490/-
3. MGA Tubeless Tyre Repair Kit-Part No. 990J0M999W0-070 MRP-Rs.399/-
I have been using the inflator and gauge for the past 5 months or so, and am fully satisfied with the product. The tyre repair kit is the new addition.
Tyre pressure gauge and portable inflator pump / foot pump-20151124_170326.jpg
Tyre pressure gauge and portable inflator pump / foot pump-20151124_170425.jpg
Shashi
Leoshashi is offline   (6) Thanks
Old 24th November 2015, 21:03   #544
Thanked: 21,411 Times
What a coincidence!
I have been having an eyeing since long to get the Tubeless repair kit, and i did get was going to post the same and you beat me to it!
If you can, please post some clear pictures of the inflator, repair kit and gauge?!
Old 28th November 2015, 20:12   #545
Leoshashi's Avatar
What a coincidence!
Extremely sorry for replying so late. Posting the pics which I have in my laptop right now. Will post better pics tomorrow morning.
The MGA Inflator. It also comes in its own handy bag and also has extennsions for different applications like football, cycles etc
Tyre pressure gauge and portable inflator pump / foot pump-20150701_154057.jpg
Specs of the inflator. Sorry about the hazy picture.
Tyre pressure gauge and portable inflator pump / foot pump-20150701_170714.jpg
The MGA Tubeless Tyre repair Kit- It comes in a neat little bag.
Tyre pressure gauge and portable inflator pump / foot pump-20151124_170127.jpg
The contents of the repair kit- 2 Drivers, a tube of rubber cement, a cutter, and 6 sticky strips.
Tyre pressure gauge and portable inflator pump / foot pump-20151124_170139.jpg
MGA Tyre pressure gauge
Tyre pressure gauge and portable inflator pump / foot pump-img20151114wa0019.jpeg
Tyre pressure gauge and portable inflator pump / foot pump-img20151114wa0021.jpeg
Tyre pressure gauge and portable inflator pump / foot pump-img20151117wa0011.jpg
Shashi
Leoshashi is offline   (10) Thanks
Old 28th November 2015, 20:28   #546
Shivanshu's Avatar
Thanked: 336 Times
Leoshashi that looks good can you tell me where did you purchase it from, and did MGA did you any sort of warranty in inflator and pressure guage?
Shivanshu is offline
Old 28th November 2015, 20:39   #547
Crazy_Bean's Avatar
Thanked: 266 Times
I have been using the ResQtech portable pump for almost 4 months now and it has worked very well. It is dependable but the PSI readings are always slightly off (by 3-4 PSi)
Crazy_Bean is offline
Old 28th November 2015, 20:39   #548
Leoshashi's Avatar
I purchased it from my Maruti dealer. No talks about warranty, though they did replace my inflator once when it malfuctioned. It was entirely my own fault as it fell off from my hands. I admitted to them and asked if anything could be done-They inspected it for any "visible" damage, and gave me a new one after taking a photocopy of my bill. However, there isn't any mention of any sort of warranty anywhere.
I must say that this inflator work brilliantly. My FNG has one of these MGA inflators since past one year, and its still working, which is a surprise considering how badly they use it and the number of cars they work upon. Seeing this, I took the plunge and it hasn't disappointed me.
There is another model in MGA for about Rs.1,500 with analogue display and is fancier to look at. However that makes a loud racket when used and doesn't look well built.
No such problems with the MGA one. I did notice that while unscrewing, some amount of air comes out. So I fill 3 PSI more, unscrew the pump's nozzle, and then using the gauge, I get it to the exact desired pressure.
Shashi
Old 30th November 2015, 12:37   #549
Leoshashi's Avatar
As promised, lots of clear pictures of the MGA Inflator, Gauge and Repair kit.
1. Bag Contents
Tyre pressure gauge and portable inflator pump / foot pump-20151130_114758.jpg
2. Size comparison with a scientific calculator. Also visible is the digital display, Backlight button and the Unit change button. It toggles between BARS, KGF/cm2, PSI and KPA
Tyre pressure gauge and portable inflator pump / foot pump-20151130_115209.jpg
3. Inflator Specifications
Tyre pressure gauge and portable inflator pump / foot pump-20151130_115231.jpg
4. Thick rubber pads to arrest vibrations
Tyre pressure gauge and portable inflator pump / foot pump-20151130_115255.jpg
5. The ON/OFF Switch on the Inflator
Tyre pressure gauge and portable inflator pump / foot pump-20151130_115317.jpg
6. Another view
Tyre pressure gauge and portable inflator pump / foot pump-20151130_115444.jpg
7. Tyre pressure gauge
Tyre pressure gauge and portable inflator pump / foot pump-20151130_115635.jpg
Tyre pressure gauge and portable inflator pump / foot pump-20151130_115701.jpg
8. Other attachments
Tyre pressure gauge and portable inflator pump / foot pump-20151130_115809.jpg
9. Contents of repair kit
Tyre pressure gauge and portable inflator pump / foot pump-20151130_115938.jpg
10. This is how everything fits inside the big bag.
Tyre pressure gauge and portable inflator pump / foot pump-20151130_120135.jpg
Shashi
Leoshashi is offline   (16) Thanks
Old 2nd February 2016, 19:57   #550
Thanked: 423 Times
Tried picking up the MGA tyre pressure gauge from a Garuda workshop in Bangalore, and was directed to their showroom on Lalbaug road.
My dad travels from front of the showroom on weekdays, so he picked it up for me. Unlike the pictures above, it did not come with a box or manual or anything. The dealer told my dad that these come in lose packing. The LCD display is quite scratched, and am not sure if a used piece has been handed over to my dad. We have been billed 450 bucks for it.
While i have not yet tested it, not sure if it is worth the hassle of returning the same.
Ajay
Tyre pressure gauge and portable inflator pump / foot pump-optr0216012.jpeg
ajayclicks is offline   (1) Thanks
Old 20th February 2016, 13:03   #551
IndigoXLGrandDi's Avatar
Thanked: 570 Times
I want to buy 35L/Min Tyre Inflator. My budget is 1600-1700/-. If with warranty, better.
Previously I bought one from Snapdeal in Mar 2014, but it got worn out (started emitting smoke from 12V Socket) after one year of usage.
Then I had bought Resqtech Tyre Inflator, but it is useful mostly for two wheelers. For Cars, the speed feels to be less.
I want such 35L/Min Inflator that will prevent me from going to Puncture Walas and Petrol Pumps for filling air.
Please suggest a good reliable one.
IndigoXLGrandDi is offline   (1) Thanks
Old 26th March 2016, 19:58   #552
sidhu_hs's Avatar
Thanked: 265 Times
Viair 85P
Just had a Viair 85P (and a mechanical gauge) delivered about a week and a half ago. Newspaper background to give perspective about size.
Tyre pressure gauge and portable inflator pump / foot pump-viair-85p.jpg
One of the primary reason for going the Viair way was that a lot of forum members went this way after exploring all others!
Another reason was that none of the forum members who had bought Viair on this thread have reported any problems so far.
Copy pasting the order summary from amazon:
Order Summary
Item(s) Subtotal: INR 3,966.49
Shipping & Handling: INR 1,514.02
Total before tax: INR 7,173.12
Estimated tax to be collected: INR 0.00
Import Fees Deposit INR 1,692.61
Grand Total: INR 7,173.12
that is quite a princely sum for a compressor! And prevailing exchange rate doesn't help either.
Ordered on March 7, 2016
Delivered March 15, 2016
sidhu_hs is offline   (1) Thanks
Old 2nd April 2016, 18:38   #553
Thanked: 2,909 Times
I have had ResQTech inflator in my boot for a while now. I've had a chance to used it only once before when I had a flat tyre. I've kept it as a backup for emergencies and I believe its a handy device.
Today when the air was being filled in to a flat tyre, the rotatable plastic knob that screws on to the tyre valve came off loose.
I've written to the product support and they asked me to send the pic of the detached knob.
Tyre pressure gauge and portable inflator pump / foot pump-resq-tech-detached-knob.jpg
for_cars1 is offline
Old 7th April 2016, 12:19   #554
Originally Posted by for_cars1 View Post
I've written to the product support ....
I got a prompt replacement of the inflator. Good after sales service from ResQ-Tech
Old 7th April 2016, 13:31   #555
sagarpadaki's Avatar
Thanked: 5,882 Times
Is there an air compressor that can run off a 220V supply and is still portable? Would be useful for filling the air when at home without having to visit the tyre wala
sagarpadaki is offline
