Old 18th January 2007, 11:56   #136
condor's Avatar
Thanked: 16,889 Times
Tanveer, thanks .. the option to upgrade to 100/90 later, or when driving on high-ways is one of the things I was thinking about.
Going for a full 100/90 setup for the Sumo. Prerana guys are suggesting Mico or Minda. But they say it's better to change the relay also if I want to go for the 75/70.
condor is offline
Old 18th January 2007, 11:58   #137
tsk1979's Avatar
Thanked: 23,484 Times
Mico, minda etc., are good companies for relay. Make sure you get the whole wiring kit and not just the relay.
tsk1979 is offline
Old 19th January 2007, 16:04   #138
functional non show lighting requirements:
I am new member, posting this message for the first time. I have Maruti 800( 97 Model) car. I would like to upgrade headlamps. Can I fit ALto's Halogen 12V 60/55W bulb to my car? Let me know your thoughts.
Thanks.
Geekay
geekay is offline
Old 19th January 2007, 17:02   #139
tsk1979's Avatar
Your car already has 60/55W halogens.
Alto does not come with any special lamps, these are standard mico/philips etc., bulbs which are there in all cars with H4 bulbs which include the M800,indica, wagonR. santro etc., too
tsk1979 is offline
Old 20th January 2007, 11:56   #140
jas_mirage's Avatar
Thanked: 22 Times
Originally Posted by speedzak View Post
Get Philips rally bulbs of 100/90 ratings. they are tend to be illegal but will help a lot and won't cause too much of a trouble to opposite vehicles if the focussing is done correctly. Don't put in anything brighter.
You can get these from any reputed automotive spare shop or accessories shops.
If you have the stock wiring for the Headlamps, it will have to be replaced with a more higher capacity headlamp wiring kit. This can be done from any service workshops or accessories shops.
If you have some spare time, visit Emperor @ Palarivattom, Car shoppe @ Palarivattom, General motor accessories @ Mamangalam or any nearest shop in Cochin.
Wanna know more? Come for our proposed meet. Read about it here: http://www.team-bhp.com/forum/team-b...-2006-a-8.html
P.S. Next time, type properly to avoid warnings.
hey zak, thanks man.. did the checking out bit in those shops.. they were pretty good and helpful..
sad i couldn't be there for the kerala meet.. was very busy.. and sheesh.. i myself am logging in after a couple of days.. hopefully the typing is done correctly this time around.. sorry about the typing errors in the earlier post..
jas_mirage is offline
Old 22nd January 2007, 17:57   #141
condor's Avatar
Guys, need help here: Got a 200W relay and swapped the 60/55W bulbs with 100/90W. But dont seem to find much difference. One thing is I got Mico / Bosch H4's rated at 2600 & 1700 lumens, IIRC. Are the bulbs the culprit? Or is it something else?
condor is offline
Old 22nd January 2007, 18:23   #142
tsk1979's Avatar
The best way to find is to fit one old bulb and one new and then park against a wall. You will find out whether output is different.
Do the Bosch H4's say "30% more light" on their packing?
You could also compare with Philips Bluevision, Hella Gold etc., and choose what you like best.
tsk1979 is offline
Old 22nd January 2007, 20:00   #143
condor's Avatar
Tanveer, thanks. The package doesnt say 30% more light. Are there special / different bulbs from Bosch with such packaging ?
But the brightness did look better on the way back today. I will check out the ones you have mentioned. But mean-while, ensuring correct focussing should help.
I also asked the Bosch dealer regarding the 75/70W's mentioned on the Bosch web-site. The dealer didnt seem aware of these. Atleast, it looks like those are not regularly moving products.
condor is offline
Old 22nd January 2007, 20:16   #144
rahul_intlad's Avatar
Do the Bosch 100/90 W also come with 30% more light feature ,similar to philips vision plus.
Ps:
Power Bulbs
rahul_intlad is offline
Old 25th January 2007, 15:12   #145
NikN's Avatar
Palio Bulb Type
Just a quick question on what kind of bulbs the palio uses on the low and high beam ? H7s on both ? any idea ?
NikN is offline
Old 25th January 2007, 17:00   #146
tsk1979's Avatar
AFAIK its a H7. Your service manual will have the details.
tsk1979 is offline
Old 25th January 2007, 17:21   #147
hydrashok's Avatar
Thanked: 18 Times
I guess Palios will need 4 bulbs in total? Because Palios have separate low beam lamps & high beam lamps? I was actually going to ask the same question here today :-)
hydrashok is offline
Old 25th January 2007, 17:55   #148
tsk1979's Avatar
Yes, 4 bulbs if you going for an upgrade.
If you want to upgrade the fogs too, then its like 6 bulbs.
To save costs you can just upgrade the high beams as low beams are pretty adequate on most cars, its the long throw which is an issue.
Make sure you fit in the bulb before buying and observe the throw. Different bulbs have different geometries, so a bulb which does great in a corolla may not be the same in a Palio.
tsk1979 is offline
Old 25th January 2007, 19:06   #149
hydrashok's Avatar
Thanked: 18 Times
Thanks, TSK1979! I guess I'll stick to just the high beams. And I will fit and try before I buy.
Old 29th January 2007, 12:06   #150
NikN's Avatar
Awesome , H7s it is then !, thanks guys
NikN is offline
