Old 7th April 2014, 22:29   #8446
guyfrmblr's Avatar
Thanked: 4,824 Times
Re: A superb Car cleaning, polishing & detailing guide
Originally Posted by MaxTorque View Post
Guys need a help, I have been using a Jopasu duster for the last few months. The dust picking capacity of the duster has been come down now. Is there any method to improve the performance of the duster??
You can try washing it with water (or a very mild soap solution) and dry it in shade. It should improve the performance a bit.
guyfrmblr is offline   (2) Thanks
Old 9th April 2014, 16:36   #8447
devious.mojave's Avatar
Thanked: 11 Times
Originally Posted by NOTORIOUS View Post
Please Post Some Pictures Of The Same So we Can Better Understand The Situation !
Hey. I was out of town for sometime and so couldn't get back to the thread.
Here are some pics.
devious.mojave is offline
Old 9th April 2014, 20:38   #8448
NOTORIOUS's Avatar
Thanked: 124 Times
Here are some pics.
Thanks , did you try washing down the car ?? If its a dried off wax , it will easily get washed away.
NOTORIOUS is offline
Old 9th April 2014, 23:07   #8449
Thanked: 11 Times
I did actually. But the marks have remained the same. They really look scruffy. My first service is due so maybe they will be able to shed some light on it.
Old 10th April 2014, 15:09   #8450
Thanked: 624 Times
Latest aquisition from UK
This just arrived today so I am super excited to try it
http://www.oglecarwax.com/
Pedaltothefloor is offline
Old 10th April 2014, 18:53   #8451
Thanked: 20 Times
Originally Posted by guyfrmblr View Post
I used Megs quick detailer. But I felt its a bit expensive to use as a clay lube. You can follow Sanjay's suggestion or if you have ONR or any other rinseless wash, you can dilute with water and make a lube out of it. Sanjay sells just clay pieces. So you might have to get QD separately if planning to use it.
I found Rs.759/- for Megs clay bar too steep. Would like to know if it lasts that long to be worth spending as much? Have you tried Bilt Hamber? Isnt that a better bargain? I intend to use either of them with ONR as clay lube.
prancinstallion is offline
Old 10th April 2014, 19:20   #8452
guyfrmblr's Avatar
I used half of the clay bar i.e, 25 gm and it could cover the whole car. The clay has still some clean surfaces and can use it for some more panels during my next clay session. I have planned to clay thrice in a year and this way the 50 gm should suffice for 3 sessions i.e, for 1 year.
I haven't tried Bilt Hamber but have seen good reviews about it. Now the latest trend is the sponge type clay bar alternative which can be reused even though it falls off from hand. You can give it a try. I have never used it though.
guyfrmblr is offline   (1) Thanks
Old 10th April 2014, 19:43   #8453
Thanked: 20 Times
Not enough testimonials on Nanoskin Autoscrub sponge. Its rather expensive for 'thrice a year' treatment. I was badly hoping for a Rs.500 Megs clay but Sanjay had different thoughts. I was almost convinced by his reply to me justifying the price point. My quest to source a decent clay bar continues...
I would be happy to split share Bilt Hamber with folks in Hyd. Drop a message if anybody has same thoughts.
Old 12th April 2014, 21:37   #8454
ank.nsit's Avatar
Thanked: 326 Times
Hi Guys,
I am planning to buy Meguiar's ultimate polish.
Is this polish suitable for manual polishing?
ank.nsit is offline
Old 13th April 2014, 09:15   #8455
sagarpadaki's Avatar
Thanked: 6,804 Times
Originally Posted by ank.nsit View Post
Hi Guys,
Yes it is suitable for manual polishing. One of the better polishes designed to be applied by hand using a foam pad
sagarpadaki is online now   (1) Thanks
Old 13th April 2014, 15:45   #8456
Thanked: 99 Times
Hi fellas
I would first gladly like to tel that I acquired my complete detailing kit that includes Meguiar's Wash, ONR, Meg QD, Meg clay bar, Fourstar UP and collinite 845 with couple of applicator pads and MF clothes.
I had scheduled 10th Apr (Delhi polling day) for the sessions.
So starting early straight away casted my vote had breakfast and headed to the parking with the arsenal.
First a good wash with meg, dried the car. Then claying using MEg's and ONR lubricant dilution. Not much came onto but yes few things did.
Then applied FS-UP onto the surface and let it dry for 30 mins. In excitement I had applied thin layer as few places as opposed to what is recommended. By the time it dried I was around 4.30 and I was little tired. Mistake of over application costed in extra labor while cleaning the dried surface. BOY it just made my smile as I moved on clearing the surfaces. It was kind of having little pain in shoulder and at the same time my happiness was growing so was the smile on my face.
By the time I cleared it all It was already 5.30.
Now it's been 4 days to that session and I want to do another layer of FS-UP. SO can I still do another layer? or Shall I go for collinite 845 now?
Honda Monk is offline
Old 14th April 2014, 01:25   #8457
el lobo 6061's Avatar
Thanked: 2,400 Times
Yes you can add another layer but I feel it won't be worth it. It would be better if you did apply another layer or do above same process every 2 months. Your car will look all good.
Applying wax over a sealant, I don't see any logic behind it. Due to slick surface I believe Collinite 845 be having problem adhering to surface. Either do wax or sealant, doing both won't give any benefit. In our environmental condition sealant are better as they last long. Rest you can apply on one panel and see the difference if its worth to apply 845.
el lobo 6061 is online now
Old 14th April 2014, 11:58   #8458
mkh
Thanked: 135 Times
How many months and have you washed it once?
These are scuffs, the sort that happen when someone with a ring etc runs their hands, it is usually seen on the foot board when the driver or passenger when getting out of the car, runs the shoe against it. Can be removed with some simple and safe rubbing most likely.
mkh is offline
Old 14th April 2014, 12:13   #8459
Thanked: 815 Times
My duster is one year old and I am yet to wash it.
MaxTorque is offline
Old 14th April 2014, 12:53   #8460
mkh
Thanked: 135 Times
One year is quite a lot, duster may lose its utility based on the usage, ideally it must be changed, or as suggested try to wash and see.
mkh is offline
