Old 24th June 2021, 21:39   #5851
W.A.G.7's Avatar
Thanked: 2,343 Times
Re: The Bicycles thread
I have been riding a Frog Snow Leopard 29T for quite some time now (since Sept 2020) and I am totally satisfied with it, so far. I am based in Pune, so some questions that I have as a newbie ...
  1. Which bicycle shop (somewhere in Deccan/Kothrud/Prabhat Road) is good enough to get a basic service done on the bicycle? I am not tech-savvy and I don't have the tools to do it myself at home, so I need to go to a shop.
  2. I want to upgrade the saddle to something better than the stock one. Where can I actually try a good saddle before I buy it? Although the saddle fit is very personalized, still; do the experts here have any suggestions about a good saddle? I normally ride 20-25 km on weekdays and try to do approx. 40-50 km on Saturday/Sunday.
  3. Lastly, the Shimano Tourney drivetrain is working well, no issues observed so far. Despite the fact that Tourney is a very entry-level component, yet it works very smoothly on my bike and is sufficient for my kind of usage. But the itch to upgrade remains. Will it be worthwhile to spend upwards of 20k to change over to a Shimano Deore 1x9 or 1x10 setup? One of the shops (Ozone Ventures) advised me that it will be easier to switch over to Shimano Acera 8 speed at the rear and keep the Front derailleur as it is (Tourney 3 speed). But they also offered to change over to a Shimano Deore 1x or 2x setup (with the cost varying depending on what I choose).
EDIT: The other crazy thing is - I am totally fixated by the Scolarian fixie - https://www.scolarian.com/zanskar-custom. Now I know that a fixie is a totally different world as compared to a normal cycle and might not be a practical option as a primary bike. Would it be really worthwhile to keep my existing MTB as is; and get (basically spend money) the bike in the URL mentioned? (GAS - gear acquisition syndrome!)
W.A.G.7 is offline
Old 25th June 2021, 11:09   #5852
giri1.8's Avatar
Thanked: 4,766 Times
Got my Decathlon Triban RC 100 flatbar last week. They did miss sending me the frame bag which I ordered, but thankfully after couple of mails it's on the way. Overall satisfied with their delivery. Have added side stand and gel seat, as this will do grocery runs too.
Did just a couple of 5+km rides, taking it slow as I have been off the saddle for almost 15 years. Once I am ready for longer rides, will just remove the gel seat and go for padded shorts.
Short impression :
*Looks minimalistic.
* Fit and finish is good, even the welds look neat (at least to my eyes).
*Light and easy to pedal
*gear ratios are nice, could use first even on slight slopes.
*Tyres are good for pavement and asphalt, slight gravel at low speed is manageable.
*Expected bone jarring ride, but it's better than I expected.
* Brakes could have been better, considering the fact that one could easily hit 30kmph+
giri1.8 is offline   (8) Thanks
Old 25th June 2021, 12:54   #5853
Thanked: 103 Times
I have been visiting one Mr. Sanjay Satpute for getting my hybrid bicycle serviced since a couple of years. Though his shop is in Pimple Saudagar area, he stays close to Karve road (right behind Sonal Hall) and has a full servicing setup at his home too. He charges like 1K INR for a full service and does an excellent job. Unrelated to the point but he is a veteran national-level cyclist and knows his stuff. HTH.
RishikeshK is offline   (1) Thanks
Old 25th June 2021, 13:35   #5854
superguy282's Avatar
Thanked: 827 Times
You could try :-
Cyclelogissts
Cykler
Pro Sports and Bikes
Been to all of them but have experience only at Cykler which was good. The others are well known so it shouldn't be a problem, they know their stuff.
superguy282 is offline   (1) Thanks
Old 25th June 2021, 14:29   #5855
Red Liner's Avatar
Thanked: 19,185 Times
Bike fit advice please?
Ignore my micro mini shorts.
Pedal at approx. 6 o clock
Pedal at 3 o clock
Should i bring the seat a tad higher? Are my arms alright on the hood? How does my back look?
Is it normal to have a little bit of shoulder blade pain? Its not pain, just fatigue.
I have learned to loosen my arms as well. Day 1 i was gripping the bars tight. Day 2, i talked myself into loosening my arms and tightening my core. This helped.
My running shoes dont feel right in the bike. What are my options? I was suggested cycling shoes which cost an eye watering 5k. Not interested in clipping them on.
Red Liner is offline
Old 25th June 2021, 15:11   #5856
Red Liner's Avatar
Example of cycling shoes which might fit my needs? https://unitedbycycling.com/products...o-44-dark-blue
Old 25th June 2021, 15:46   #5857
Thanked: 3,648 Times
To me your position looks okay. Any pain/discomfort should settle within a fortnight tops. If it persists only then I guess we need to find a solution.
A fairly loose wrist, elbow and dropped shoulders is the way to go, with a complete but not tight grip of the handlebar - same as you would have as on a motorcycle.
There may be an opportunity to set the seat a tad higher, but wait on that for a fortnight.
I am inclined to suggest that you ride with whatever sneakers you have for now, and once you are comfortable with the bike fit and handling of the bike, move up to Cleats. That's money really worth spending.
roy_libran is online now   (1) Thanks
Old 25th June 2021, 15:49   #5858
ebonho's Avatar
Thanked: 11,177 Times
Position looks good.
These are my cycling shoes. I liked them so much that after the first pair wore out, I'm on my second pair now.
Sparx. Around 1000-1400 bucks. The sole tread pattern gives great grip on alloy platform pedals (toothed), and are thick and flat and stiff. Perfect.
The whole game is in the sole. The wrong sole will make for a miserable ride. Especially in the wet.
Cheers, Doc
ebonho is offline   (5) Thanks
Old 25th June 2021, 15:53   #5859
Red Liner's Avatar
Thanks man. This is great news for me then lol.
I have some badminton shoes which should do for now. The soles on those were fairly rigid. Will pull them out.
Attachment 2170990
Attachment 2170991
Attachment 2170992
Cheers, Doc
Sparx sm 119. I will look them up in shoe stores close by for a fit out. What an awesome price.
You guys are superb
Old 25th June 2021, 15:56   #5860
graaja's Avatar
Thanked: 25,621 Times
You should be driving the pedals using the ball of your feet (in the picture you have your toes driving the pedals). With the ball of the feet rested on the pedals, you should have a slight bend in the knees at the bottom most position of the pedal. I remember the bike fit person telling it should be around 15 degrees. In your case, without measuring it with a protractor, it does looks fine to me.
The hood is slanting a little towards the ground. Make it parallel. With this position, you need to see how you feel the extension of your arms is. Ideally, you should be loading your core so that you are able to rest the arms on the hood without any load on the palm. If this is not the case, then as first step, you could flip the stem so that it is pointing away from the ground. This will bring the handle bar a little towards you and will help the core with a slightly straighter posture.
The main difference between a hybrid and road bike is the front lean of the body which needs good core engagement. This will take some time to develop. You will have to consciously remind yourself to engage the core and take the weight off your palms. You will observe that once you lose this consciousness, your body will resort to shifting the weight on the palms. As you keep consciously training the core to engage and removing the load off the palms, you will see that over time, you will be able to ride long distances with this aggressive posture without any issues.
graaja is offline   (6) Thanks
Old 25th June 2021, 15:57   #5861
ebonho's Avatar
You guys are superb
There are a couple of friends who bought them on Amazon looking at mine. Very happy.
I mean, these were my sneakers at the time I bought the ACT. I just like them a lot. And have done thousands of miles in them. Am sure there might be better shoes around. Just giving you what's been working for me. I tend not to be adventurous and change something that works.
Around 23-27 degrees as I recall.
Yes the hood is sloping a bit, and the stem is flipped (I likes!), but his wrist "looks" comfortable and his elbows too have a bit of a bend.
Cheers, Doc
ebonho is offline   (2) Thanks
Old 25th June 2021, 16:21   #5862
Red Liner's Avatar
Got it. Those slippers
I will use the bike in this position for a week and see how i do. Right now my cycling is so miniscule, it doesn't even bother mention here. Just pedalling around the apartment. I need to get those cycling shorts and hit the road close by with some open straight free lanes.
Red Liner is offline   (1) Thanks
Old 26th June 2021, 17:41   #5863
Jedi.Knight's Avatar
Thanked: 37 Times
I got the Kalenji HRM belt from Decathlon yesterday and started using with Strava.
Is there any other Android app with which I can pair this during my non-Strava activities? Purpose is just to track the heart rate without attaching it to any activity.
I tried Google Fit, however, I am not getting the option to add any heart rate monitors.
Jedi.Knight is offline
Old 26th June 2021, 17:44   #5864
Thanked: 900 Times
I've successfully connected it with the following apps -
1) a Training Tracker
2) Wahoo Fitness tracker
3) Decat Coach (Decathlon's own app)
rdst_1 is offline   (2) Thanks
Old 26th June 2021, 18:06   #5865
ebonho's Avatar
Wahoo.
In fact I capture my rides on Wahoo primarily.
And it auto uploads on to Strava.
Cheers, Doc
ebonho is offline   (1) Thanks
