Old 24th August 2008, 07:49   #196
spadival's Avatar
Thanked: 29 Times
Looks good! Where is the CPU location? Under the seat?
The touchscreen is a good fit on the 2DIN slot.
spadival is offline
Old 24th August 2008, 12:48   #197
gigy's Avatar
Thanked: 47 Times
Cpu is kept below seat as of now with the stock amd cpu heatsink. once i change over to 4850e plan to locate it behind screen with jetway heat sink.
Any idea how is headrest monitor installed. then can separate the entertainment from navigation. i intend to fix the old screen into headrest. i have all its fittings but cant make out. do we have to cut the slot into headrest?
gigy is offline
Old 25th August 2008, 16:56   #198
spadival's Avatar
Thanked: 29 Times
You get a headrest shroud which is embedded into the headrest. I have no idea how they embed it though. Check with Sheldon or any of the ICE installers on the forum.
The CarPC / Carputer Thread-p1010019.jpg
spadival is offline
Old 30th August 2008, 16:54   #199
gigy's Avatar
Thanked: 47 Times
Today decided to go ahead with installation of the headrest monitor i was using earlier in dashboard. It was a hours job in fixing into the headrest. Markings were done first. then cover was cut cross, foam removed to a depth of an inch.Used six tie wraps to fix the monitor casing. Have not connected it to the cpu but installed it in car.
I am using 4 creative speakers now connected to amplifier along with the rockford subwoofer. its actually sounding better than previous sony 6x9s + pioneer 2ways. this is primarily because all four were connected to the same stereo output and the subwoofer audio was not coming out of trunk. the two 6x9 holes are giving nice bass effect. Atleas till i upgrade to a pair of components set this will stay.
The CarPC / Carputer Thread-005.jpg
The CarPC / Carputer Thread-006.jpg
gigy is offline
Old 2nd September 2008, 18:57   #200
gigy's Avatar
Thanked: 47 Times
I blew up the headrest lcd today by interchanging power wires. it was momentary but it was enough to blow up something inside it. a pop sound and the fuse also blew off second latter. all this because i used a pair of wires which were both black.
An other problem:
the DVI to VGA converter is not working with the touchscreen monitor. there is no video signal.
gigy is offline
Old 23rd September 2008, 10:29   #201
gigy's Avatar
Thanked: 47 Times
Got the 4850e cpu for Rs4100 and installed it with the low profile heat sink. till now its operating fine. running at default 2.5Ghz. i am waiting for new cabinet which will accommodate the cpu and lcd into a double din case to make it as stock replacement type set up.
gigy is offline
Old 8th October 2008, 12:29   #202
gigy's Avatar
Thanked: 47 Times
After a long wait got hold of a PCI riser card(had to pay Rs1000) and the tv tuner card is in now.so got FM back into car after a long time just before my Ahmedabad trip today
The CarPC / Carputer Thread-07102008.jpg
gigy is offline
Old 8th October 2008, 13:53   #203
badboyscad's Avatar
Thanked: 483 Times
@gigy: my carputer is almost over but im stuck at the display part. currently im havin a necvox 7.5" headrest lcd and the vga to pal converter that i bought has some problem, so it is not converting.
Please suggest a Desktop LCD monitor( 14" or 15" with VGA input) which works on 12 volt DC. i mean to say a LCD monitor which comes with a power adapter( 220V to 12v dc), so that i can keep the adapter aside and directly connect the monitor to the car.
PS: im not keen on spending 11K or greater on puny little touchscreen and im sure that i can take care of mounting the desktop lcd on the roof.
badboyscad is offline
Old 8th October 2008, 14:59   #204
Thanked: 42 Times
koooll setup,
where did you get PCI rasier card from ?
monty9991 is offline
Old 8th October 2008, 15:55   #205
gigy's Avatar
Thanked: 47 Times
Badboyscad,
Did you check the switch setting on the converter? is video enabled or is it in vga ? did you check power in the usb cable? Get the converter replaced if possible.
from my experience it is always better to go for touch screen. If you are not driving then a mini keyboard is required.DealExtreme: $44.80 Mini 78+19 Keys USB 2.4GHz RF Wireless Programmable Multimedia Keyboard with Trackball Mouse
if you find something like this in chennai let me also know.
There are lcd of 7''(display) & 9''(case) with vga display for about 4k. i have seen them in alfa store mumbai. Do you have a suitable location for a 14'' on roof? It might be too heavy to support and block rear view completely.
Monty9991,
Got it imported from linux itx site. LinITX.com - Riser Cards
gigy is offline
Old 8th October 2008, 17:01   #206
badboyscad's Avatar
Thanked: 483 Times
@gigy: yes,i checked all the switch settings and usb power cable, but no use. i checked with a similar converter(my friend's) and it worked perfectly. guess i have to get it replaced. can you please tell me more(brand, model num) about the 7" display( with vga input)?
And yes, i ll surely let you know if i find something similar to that keyboard, here.
Old 10th October 2008, 13:26   #207
nc1bad's Avatar
Thanked: 17 Times
regarding compact keyboards u guys can check out this :
[COLOR=#0066cc]http://www.engadget.com/2008/10/03/brandos-tiny-keyboard-now-in-wireless-multimedia-flavor/[/COLOR]
Its a bit expensive but is wireless and compact with trackball !
The CarPC / Carputer Thread-brandowirelesstinymutimediakeyboard2.jpg
nc1bad is offline
Old 21st October 2008, 17:38   #208
gigy's Avatar
Thanked: 47 Times
Today i tried integrating the display into the dashboard. The results are ok I think for a diy. whats your inputs? tried to do this because older setup was very much inviting to theives and without any security system in car now i wanted to tone down the looks
The CarPC / Carputer Thread-21102008.jpg
The CarPC / Carputer Thread-21102008002.jpg
The CarPC / Carputer Thread-21102008003.jpg
The CarPC / Carputer Thread-21102008004.jpg
gigy is offline
Old 23rd October 2008, 21:45   #209
Thanked: 42 Times
nice fabrication.. gigy
it looks like theres a difference in color of screen and your dash panel. i'd suggest you get it painted in MATT BLACK color the whole thing ( screen panel and dash panel together).
Old 23rd October 2008, 22:49   #210
gigy's Avatar
Thanked: 47 Times
I have painted it all matt black including the trim around the speedometer gauges. now car has gone back to stock colour.
gigy is offline
