Old 12th June 2011, 12:32   #2041
Thad E Ginathom's Avatar
Thanked: 30,154 Times
re: The home / office air-conditioner thread
Originally Posted by khoj View Post
The dealer is correct, Daikin machines do not have a piping kit bundled along with the unit
If someone is spending that much, a few metres of copper pipe isn't much to add.
Thad E Ginathom is offline
Old 12th June 2011, 21:19   #2042
Thanked: 3,034 Times
Except that they charge a lot for piping. On an average installation it will be to the tune of 2K extra!
Aroy is offline
Old 13th June 2011, 00:01   #2043
Oh!
Sorry... I was thinking hundreds <Blush>
Now I know why the left-over tube from our three installations was worth steeling.
Old 13th June 2011, 06:59   #2044
Thanked: 311 Times
'Steeling' as in steel coating?
Or 'steeling' as in stealing?
anupmathur is offline
Old 13th June 2011, 10:21   #2045
sgiitk's Avatar
Thanked: 4,809 Times
I doubt whether the left over piping will have sufficient length in a single run. Now Copper is expensive so cost is bound to be high. I remember Carrier charging Rs.2200 in 1999 for shifting a unit!
sgiitk is offline
Old 13th June 2011, 12:44   #2046
khoj's Avatar
Thanked: 1,288 Times
Mathur Saheb,
Angrez ko Angrezi sikha rahe ho
@ T E G
No offence meant Thad but pun definitely intended
khoj is offline
Old 13th June 2011, 13:29   #2047
Akshay1234's Avatar
Thanked: 12,920 Times
Anyone, comments on the prices for Daikin posted by me? Need to confirm today, thats why. What is H series? I don't remember reading about it on the Daikin site.
Akshay1234 is offline
Old 13th June 2011, 13:47   #2048
steeling. I must have been thinking about breaks when I said that, not to mention tyres.
The spelling of my own language often baffles me! <Blush>
Old 13th June 2011, 14:55   #2049
khoj's Avatar
Originally Posted by akshay1234 View Post
Guys how are these prices?
Daikin FT50 G 1.5t 5* - 37k
Daikin FT60 G 1.8t 4* - 43k
Daikin FT60 H 1.8t 5* - 45k
Does it make sense to go for the H over the G for the living room? We need 2 of these, and the piping length is quite long, about 70ft+. The a.c guy said the G series is designed for longer piping than the E series.
The room is about 450 sq ft give or take, and they think 2x2t Daikins will be enough.
Between the G and the E for 1.5 ton and above the G series can have a maximum piping length of 30 Mts. for E this can be 20Mts. Further with the G series you can have a height difference between the two units of up to 15Mts and for the E series this figure is 10Mts. I have no idea regarding the H series.
As for the prices you would be better off reading through the previous few pages as to what is being offered to other members or take a quote from a competing dealer. Here is the link to locate dealers in Bombay
:: Welcome to Daikin Air Conditioning India Pvt. Ltd. ::
You could also contact the Western India sales head Mr. Neeraj Shukla to know the correct pricing and maybe verify whether your dealer is actually authorised. nshukla@daikinindia.com
khoj is offline
Old 13th June 2011, 17:11   #2050
Go for one large 4-6T inverter type AC (or VRF - variable flow refrigerant) unit. Though slightly higher in initial cost, it will last longer.
Another option is to go for 3x1.5T 2-3* units. That is if the AC is required for less than 2-3 hours a day. In such case the higher electricity consumption does not pinch due to low utilization.
Aroy is offline
Old 13th June 2011, 18:40   #2051
Akshay1234's Avatar
Oh the 1.5t was for one of the bedrooms. Decided on the 3* E series for the bedroom since the 5* costs 8k more, dosen't seem worth it though this ac will be used everday.
For the living room according to my architect and the ac person, 2 2t ACs will be enough for now. The piping is done for a 3rd unit if we ever need one. Decided on the G series for this, since the piping is quite long.
All the other ACs in the new house will be the existing ones which we have now.
Old 13th June 2011, 20:02   #2052
Budget- 25-30K
Capacity- 1.0 ton
Prefer efficient model- maximum power saving possible within budget.
Models shortlisted-
Daikin FT35GV1G6
(No inverter, R22, COP= 3.38, 4.9A, 1095W, ... )
Panasonic CS-PS12MKY
(Econ Inverter- Silver: Intelligent Inverter, R410A, COP=3.3, 4.8A, 1020W, ... )
http://www.panasonic.co.in/wps/porta...lver/CSPS12MKY
Have been hearing good things about Panasonic installation/service. No idea on Daikin.
What about quality of compressor, condenser, need for stabiliser, etc.
Please advise.
BIKeINSTEIN is offline
Old 13th June 2011, 21:44   #2053
bluevolt's Avatar
Thanked: 3,479 Times
My Voltas 1.5 ton split AC's indoor unit is leaking water (after 20-30 mins of operation) since yesterday. I checked the drain pipe and it is OK. Please help me, what to do now.
bluevolt is offline
Old 13th June 2011, 22:56   #2054
Thanked: 24 Times
Hello Team,
Today when I was searching something in my parents room, I smelled a very bad smell and to my surprise AC was on.Dad told me that its a daily thing and when we starts it it gives very bad smell.Can somebody help me out?
Is it due to the gas leakage or some bacteria issue in the AC ?
Its a 1.5 ton LG ac 5.5 years old and the gas was re-filled previous year only.
Lalit Tyagi
T Y A G I is offline
Old 14th June 2011, 01:55   #2055
khoj's Avatar
Please advise.
Please read the last dozen or so pages, all of your queries on Daikin are already answered there.
If there is water coming in from the IDU then your drain pipe is certainly not OK. Check more thoroughly. At the outset feel around the drain pan in the IDU it's mouth may be choked, clean it out. If that is not the case then blow in to the drain pipe from the far end and you should get air bubbles or rather water in the IDU's drain pan should gurgle. This will tell you whether the drain is clear or not and also dislodge the blockage. It also tells you that the drain is in good shape. If you are not getting anything that would tell you that either the drain is blocked, kinked or pinched somewhere or it has been dislodged from the outlet at the IDU end(very rare).
Originally Posted by T Y A G I View Post
Hello Team,
Lalit Tyagi
Check the electric plug socket. This is usually the smell of burning plastic and is similar to the smell of rotting flesh. Sockets/plug's plastic will burn on account of the excess heat generated due to loose connections. Refer my post in previous pages on ac upkeep to read more about how to avoid this.
khoj is offline   (1) Thanks
