Old 27th July 2014, 17:03   #18646
Thanked: 7,691 Times
Originally Posted by 5hadow View Post
I got my Xiami Mi3 yesterday and I am trying to move app settings and other important data like contacts, etc to it from a Moto Defy running CM GB.
I would like to know from fellow Mi3 owners, did they try to access the Mi3 through computer and notice a ReadMe(.rtf and .html) and a setup.exe? All of them are in Chinese. I tried my hand with Google translate on the Readme and all I could get was that the setup will install drivers. Are they even required?
Any help with this or porting data to new phone is welcome.
What exactly are you trying to port?
Contacts/Calender/Wifi-APN settings are all backed up to your gmail account. You just need to add the account on your new phone and everything will be synced to it.
For SMS/Call logs you can use SMS/Call log backup apps by Ritesh Sahu - it can also take schedules backups and sync to cloud.
Dry Ice is offline
Old 27th July 2014, 18:14   #18647
Thanked: 15 Times
Originally Posted by AbhiJ View Post
3. Enables administrator rights selecting first ROOT and then where it says Enable administrator permissions.
Sorry, but I can't seem to find how to do this.
5hadow is offline
Old 27th July 2014, 18:31   #18648
kri$hna's Avatar
Thanked: 31 Times
Something I found online... owners please confirm.
Rooting steps for Xiaomi MI3
Directions
Usually, Xiaomi are already rooted from the top, so the process would be to activate it.
1. Click Security Center, on the desktop of your smartphone.
2. In Security Center, click the Permissions icon.
4. Download any application requiring root activation and accept that ROOT permissions, so you can check it out.
The steps are correct. You don't need any other special steps to enable root on this device. I have been using developer ROM since January this year and there was never much of an issue except minor bugs which get fixed in every weekly update!
But the steps mentioned above can get you rooted provided you install developer ROM. I doubt if this option is available in stable ROM. Btw, there is also clockworkmod recovery available for this device, i prefer this for nandroid backup
kri$hna is offline
Old 27th July 2014, 20:41   #18649
chinmaybaikar's Avatar
Thanked: 74 Times
'One plus' considering India launch of their phone 'One' soon. A lot of new brands pouring in. Hope the best for them.
http://m.tech.firstpost.com/news-ana...od-228034.html
chinmaybaikar is offline
Old 27th July 2014, 21:07   #18650
Ravi Yadav's Avatar
Thanked: 12 Times
Xiaomi ,Oppo, OnePlusOne are the few phones which come rooted out of the box. Informative information for rooting Xiaomi and installing the CWM recovery is available on this thread.
http://forum.xda-developers.com/show....php?t=2667717
Ravi Yadav is offline
Old 27th July 2014, 22:12   #18651
dipdawiz's Avatar
Thanked: 1,087 Times
For Phone manager (that gets install through setup.exe), you get English translated files which you need to replace. Check this forum (official MiUI India forum) http://forum.miui.co.in/viewtopic.php?t=883&p=5855
dipdawiz is offline
Old 28th July 2014, 09:29   #18652
akshay380's Avatar
Thanked: 1,296 Times
Anyone facing low signal strength issue with Mi3? Below are my results comparing CanvasHD and Mi3 at same time/sim
Edge signal strength on Micromax CanvasHD: -85dbm
HSPA signal strength on CanvasHD: -92dbm
Edge signal strength on Mi3: -89dbm
HSPA signal strength on Mi3: -113dbm
akshay380 is offline
Old 28th July 2014, 10:37   #18653
phamilyman's Avatar
Thanked: 4,673 Times
EDGE is 2G which is always stronger invariably. compare both in 2G/3G and then post!
phamilyman is offline
Old 28th July 2014, 10:55   #18654
drmohitg's Avatar
Thanked: 7,573 Times
Has anyone here used the Moto E? Its in stock on flipkart. Need a basic smartphone with very basic usage comprising mostly of calls and whatsapp and occasional internet browsing. The dual sim option and the compact dimensions is an added advantage. Or should I go for the Moto G since budget is flexible.
drmohitg is offline
Old 28th July 2014, 10:57   #18655
Thanked: 716 Times
most of these mobile sites do not report lag in most androids, or just make passing mentions. .
Originally Posted by driving_smartly View Post
I have a 2 half years old Samsung Omnia W running on windows 7.8, zilch lag till datel
Well may be reviewers are paid but part of the blame lies in lightning fast evolution of Android , For example 2GB of System partition was considered sufficient when Note ( original note) was released today the device is upgraded to 4.3 and now the System partition often runs short of space.
FYI , S3 which Phamilyman compares with was 6 full months before the Note. So may be when it was reviewed at that time compared to what was available in same time frame it was good enough.
So in my observation same device with original software was fast enough but with all the load of latest updates ( OS + Applications) I see flicker on screen and general slowdown after 3 years of usage.
Compared to this there were very little changes in software of Omnia.
@phamilyman : About your other question on an application which can measure and compared signal strength of all operators on handset , I doubt if you can get this.
On handsets the measurement is restricted to neighbouring cells of same PLMN ( operator). Network directs the handsets in System Information blocks which are sent on broadcast channels about what to measure and modem chipset restricts itself to only these measurements.
Only when you select network once more then full band search and measurements are done.
amitk26 is offline
Old 28th July 2014, 11:10   #18656
akshay380's Avatar
Didnt I do that exact same thing?
Both using BSNL sim back to back tests.
Old 28th July 2014, 11:16   #18657
F150's Avatar
Thanked: 926 Times
OK. So Mi3 is getting weaker signal at the same location. It may be related to the baseband of the phone or with the antenna of the device itself.
F150 is offline
Old 28th July 2014, 11:30   #18658
Mr.Beat's Avatar
Thanked: 292 Times
If the budget is flexible then Moto g does make more sense indeed. However, at almost the same price you may consider the Mi 3 with much better hardware.
Mr.Beat is offline
Old 28th July 2014, 12:19   #18659
JLS
JLS's Avatar
Thanked: 183 Times
I had ordered Moto E for my wife, and she is using it for a month or so.
For 7K it is no brainer, good battery life, smooth operation, latest android, good reception and call quality to name a few positives.
Only negative is camera without autofocus and a flash light.
If budget is not an issue, go for Moto G, but I don't think almost double price is justified for Moto G. Moto E fits perfactly in a basic phone definition.
JLS
JLS is offline
Old 28th July 2014, 12:40   #18660
phamilyman's Avatar
check out the zenfone. supposedly better value esp the ZF5 at 10k INR. check with any actual users who may have seen both handsets in person.
