Old 16th October 2008, 22:23   #2206
Hashim's Avatar
Thanked: 49 Times
From this thread I conclude that 100/90 are good bulbs. But I have Halonix 100/90 xenon fitted in my esteem (with realy and thinker wires), yet I don't get good illumination. I had once hit those big dustbin kept on side of roads on rainy day. What should I do? upgrade to clear headlamp assembly or any other bulb suggested? I'll post a pic tomorow how road looks to me at night.
Hashim is offline
Old 17th October 2008, 11:46   #2207
jithudigitised's Avatar
Thanked: 141 Times
Originally Posted by ankitahuja View Post
The Roots kit + Relay is around Rs 600+ IIRC.
You will require a Roots wiring kit (holders included) and a dual Relay.
Rally 100/130 - Rs 360/pair in Delhi (3 month old price). Very difficult to source genuine 100/130 Philips Rally.
So while during the installation of the bulbs and relay,do i need to tell the mechanic to break a circuit and get the power or have to directly get it from battery. Please specify this as the maruti mechanic told me its not good to break circuit and get the power,if i do so i will end up shorting all my vehicle circuits.Is it correct?
jithudigitised is offline
Old 17th October 2008, 16:19   #2208
ultimatechamp's Avatar
Thanked: 161 Times
Rally 130/100 - Rs 360/pair in Delhi (3 month old price). Very difficult to source genuine 100/130 Philips Rally.
Its easily available in kolkata and the MRP is Rs 200 per bulb ! But as ankitahuja has pointed out,get best piece of wiring you can lay your hands on badboyscad,plus separate relays for each bulb plus bakelite holders.The improvement in illumination would be something which I can assure you would bring genuine smile to your face !!
ultimatechamp is offline
Old 18th October 2008, 19:59   #2209
Hashim's Avatar
Thanked: 49 Times
Auto Lighting thread : Post all queries about automobile lighting here-1018_193128.jpg
This is how road looks to me at night These are 100/90 Halonix with relay.
Hashim is offline
Old 19th October 2008, 05:46   #2210
anantnehru's Avatar
My 50w 4300k Bixenon High beams (SX4)
Auto Lighting thread : Post all queries about automobile lighting here-sx4-4300k-high-beam.jpg
anantnehru is offline
Old 19th October 2008, 09:41   #2211
Thanked: 161 Times
Attachment 61509
Thats pretty neat illumination anantnehru.Can you please post pictures of your low beam too?
Old 19th October 2008, 13:31   #2212
ankitahuja's Avatar
Thanked: 94 Times
I remember my electrician never asked me such a question. There was no cutting required and the power was not taken directly from the battery. I believe the HL wiring harness starts from a point, all you need is to hook up the new wiring from that point as well (The old wiring + holder remain in the bay but useless).
I will post a detailed description later.
Originally Posted by Hashim View Post
Attachment 61462
My personal experience with Halonix +60 100/90W bulbs has not been good. I also feel your HL requires aim settings. And read ultimatechamp's post #2210. What is the condition of your HL Assembly/reflectors? You might want to replace those.
Attachment 61509
Very good lighting Anant! Mind sharing the Brand and Cost?
Also, your signature says "White LED Mirror Lights" - Please post pictures (Day/Night)
ankitahuja is offline
Old 19th October 2008, 13:45   #2213
greenhorn's Avatar
Thanked: 4,417 Times
Finally found out the size of the indica fogs. ( had to have a crash to find out )
they're H11. Are they hard to get hold of ?
greenhorn is offline
Old 19th October 2008, 15:51   #2214
anantnehru's Avatar
Brand is Chinese, and cost well, I import these so I dontknow if I'm allowed to put the cost here. But there is a years warranty, and am planning to get some for the fogs as well.
LED Mirror Lights are down below:
Auto Lighting thread : Post all queries about automobile lighting here-img_0896.jpg
Dont have one taken in the day will post it in a little while.
I also have an LED strip on the headlights, but taking a pic from the front resulted in alot of glare, trying to figure that one out. This is what I have as of now. (This is the LED strip with parking lights on)
Auto Lighting thread : Post all queries about automobile lighting here-img_0955edit.jpg
And finally, my low beam picture; slightly blurry, but you can still see how far the beam goes.
Auto Lighting thread : Post all queries about automobile lighting here-sx4-4300k-low-beam.jpg
Im going to take one up front with LED strip on the headlights and the mirror lights as well, when I figure out how to take the pic properly. Also planning on taking out the parking light bulb.
Old 19th October 2008, 15:58   #2215
Hashim's Avatar
Thanked: 49 Times
I just figured out from yellow light from my bulbs that they are not getting enough voltage. Just now what I did is connected a multimeter to car battery terminal and started the car and kept RPM little higher than idle. Voltage increased to 13.2v from 12.5v, now as soon as I switched on headlight, battery voltage started dropping and reached 11.6v Battery is not even a year old and quite well charged as I drive car daily.
Switching to lower wattage bulb like 55w something will solve this problem or there is something wrong with the car electrical ?
Hashim is offline
Old 19th October 2008, 16:34   #2216
greenhorn's Avatar
anant, can we have snaps of what they look like in the daytime ?
Old 19th October 2008, 16:42   #2217
anantnehru's Avatar
Sure, but which ones? The mirror lights or the headlight LEDs?
Old 19th October 2008, 17:41   #2218
ImmortalZ's Avatar
Thanked: 489 Times
Voltage will drop if the circuit isn't getting the current it needs for the load connected to it. You need to put your lamps on a different circuit (read : relay) and use some fat cables to do so. Do remember that the highest current capacity of a circuit is the capacity of the lowest capacity cable in the circuit. So make sure there are no bottlenecks in your electric system.
12.5V is fine for the battery. I suspect your cabling.
ImmortalZ is offline
Old 20th October 2008, 11:03   #2219
Thanked: 161 Times
Same with me as Ankit pointed out.My electrician happily did it for me and it takes a little over an hour. But best available things are required so that car electricals are not fouled up in any way.
The mirror LEDs look cool Anant and the headlight ones too.I guess like greenhorn,we all want to see both in daytime shots to check out how they are actually.The low beam headlight picture needs to be better though.
By the way,have anybody from our board seen or used the new CELIS technology in automotive lighting from Hella ? Did a search on CELIS but did not found anything here on the board.
Here are the links:
Drivers | Hella Australia Pty Ltd
Parts4vws.com and Parts4Audis.com - <strong>NLA</strong> Golf III Hella Celis Headlight Kit
Old 20th October 2008, 14:52   #2220
anantnehru's Avatar
All right guys.
Here you go, head on shots as well from the side.
Let me know what say you.
Auto Lighting thread : Post all queries about automobile lighting here-img_0988edit.jpg
Auto Lighting thread : Post all queries about automobile lighting here-img_0989edit.jpg
Auto Lighting thread : Post all queries about automobile lighting here-img_0990edit.jpg
Auto Lighting thread : Post all queries about automobile lighting here-img_0991edit.jpg
The wiring for the mirrors can be done alot more neatly, but I didnt have patience the day I had it installed so have to go back and get it rectified. But you cant really see them at night.
