Old 28th November 2014, 10:11   #8626
Thanked: 21,233 Times
Originally Posted by SunnyBoi View Post
Fair point. However vehicles with DC systems can cope up with a higher wattage headlight since they are powered by the battery. The battery might get drained a bit by prolonged usage in the night, however it will get compensated by riding during the day.
Small changes like swapping brake/parking bulb and pilot lights to LEDs can also conserve power. Along with switching off lamps when stationary in traffic.
On my ZMA, I changed the rear (21W+5W) x 2 brake bulbs into (1W+2W) LEDs plus 5W x 2 pilots to 0.1W?? LED. That itself has compensated for the bigger 60/55W headlight. I'm still running this setup on a 5 year old battery and it easily copes with long rides in the night (2-3 hours) even with a monster Megasonic horn blaring
In your case, the ZMA has full DC Electricals. Hence worst case your battery may drain. That also can be sorted out by using a higher power battery.
But in the case of the Access, etc its mixed AC DC. The headlamp is totally isolated from the battery and is only powered directly by alternator. Hence, the alternator will be under excess load to drive a higher power bulb and can lead to failure too. That's the concern. Battery drain doesn't come into question in this case.
audioholic is offline
Old 28th November 2014, 11:22   #8627
S_U_N's Avatar
Thanked: 418 Times
I am not sure if the alternator of a scoot like Access, Dio can support a higher wattage headlight. Bigger engine bikes do have better charging systems that can support increased wattage and having DC Electricals is an added advantage in some bikes. However in scooters, I doubt increasing wattage would be a good thing to do. Even I have been looking towards better bulbs for my Dio but the current options and my usage aren't commanding a swap.
I did some more research on this topic.
Basically the H4 bulb seems to come with higher wattage only (50W and above).
That is where the problem is for scooters like Access.
We have to change many more bulbs to compensate for the increased load (like SunnyBoi has mentioned).
In the end the cheaper cost of H4 is offset by the other changes.
So, it makes more sense to get the more expensive HS1 directly (around Rs. 1000 if imported from ebay UK.)
S_U_N is offline
Old 28th November 2014, 17:12   #8628
the13thtee's Avatar
Thanked: 59 Times
Hello friends,
I'm looking forward to upgrade the headlamps of my Yamaha Fazer as I'm suffering problems when it gets dark at the time of oncoming traffic. I don't mean to blind anyone I drive on low beam most of the time. Please suggest a reliable solution (HIDs projectors or h4 halogens)? Budget = less than 5k.
the13thtee is offline
Old 28th November 2014, 22:58   #8629
Well I did some calculations too. There are two bulbs in the speedometer console each 5W which is a 10W load. Next, the parking bulb is again 5W, and the rear brake light is 5W(continuous, 21W when braking).
Hence, totally that is 25W of load. Suppose I replace all these with LEDs, I can bring down the consumption to negligible values. That will spare 60W for the headlamp
Time to search or make LED lamps for the above applications
Old 29th November 2014, 06:11   #8630
SunnyBoi's Avatar
Thanked: 4,461 Times
You'll need T5 bulbs for the meter console, T10 for the parking bulb and 1156 for the brake/parking bulb.
Since you're in Bengaluru, lemme know if you want few bulbs, I have a few spare bulbs in my collection.
LED bulbs look wicked in clear lens tail lamps though
Auto Lighting thread : Post all queries about automobile lighting here-img_20141128_113902001.jpg
Originally Posted by the13thtee View Post
Hello friends,
I suggest you get a pair of LED auxiliary lights. You can switch them on when needed and they put far more light than halogens for the same wattage.
Below are a couple of Cree LED aux lamps I bought from eBay. 15$ for the 10W spot lamp. These pics were taken in daylight
Auto Lighting thread : Post all queries about automobile lighting here-img_20141121_135020001.jpg
20$ for the 15W spread lamp.
Auto Lighting thread : Post all queries about automobile lighting here-img_20141121_135131001.jpg
SunnyBoi is offline   (1) Thanks
Old 29th November 2014, 07:44   #8631
the13thtee's Avatar
Thanked: 59 Times
Thanks SunnyBoi, you are a real expert at this I guess. Further to my query, are these auxiliary LEDS fitted into the headlamps replacing the H4 halogen bulbs or do they need to be conected somewhere outside keeping the H4 halogens at their place? In the later case, will the battery be able to fetch power for both H4 halogens and auxiliary LEDs? Any suggestions for LED Tail lights? Any custom tail light setup for fz/fazer you heard of?
Old 29th November 2014, 10:21   #8632
SunnyBoi's Avatar
hehe I'm no expert. I'm just experimenting on LEDs since I find them quite fascinating
These aux lamps are not mounted in the headlight, rather they can be mounted on the crash guard or beside the headlight using simple clamps.
Any mechanic will be able to wire them with a switch so that you can turn them on or off depending on your need. They wont sap much power, you can easily compensate for this by swapping the pilot and brake bulbs to LEDs.
For LED tail lights, get 1157 LED tail lamp bulbs with dual filament. Search on eBay.com or aliexpress for a plethora of options.
SunnyBoi is offline   (2) Thanks
Old 29th November 2014, 11:22   #8633
Reinhard's Avatar
Thanked: 18,120 Times
While at it, you might also want to check out the bulbs above the rear number plate (if present in your car). The hidden little buggers will also be taking 5ish watts I think.
Reinhard is offline
Old 29th November 2014, 19:27   #8634
S_U_N's Avatar
Thanked: 418 Times
@sunnyboi: Can you please post some pictures of the completed setup on the scooter?
Mounting on clamps has its own issues - vibration, water leakage etc.
Also, in the process of downgrading all the auxiliary lights, do we need to change or cut any stock wiring?
Edit: What is the 'parking light'? I hope we are talking about scooters at the moment.
S_U_N is offline
Old 30th November 2014, 08:10   #8635
SunnyBoi's Avatar
I dont have a scooter but a bike is somewhat similar I believe. This is how the spot lamp looks when mounted. Pretty discreet for me Right now its aimed at the sky; bike repairs went till ~10.30pm last night and didn't get a chance to aim it right. Will do so today!
Parking light is the LED bulb located beneath the headlight in the pic. Some vehicles have it and some don't.
Auto Lighting thread : Post all queries about automobile lighting here-img_20141130_075709001.jpg
SunnyBoi is offline
Old 30th November 2014, 20:42   #8636
SunnyBoi's Avatar
Did some testing on the LED on a field this evening.
I have Philips Xtremevision 60/55 bulb on Full DC system, which means headlight in the pics are at 100%.
All off
Auto Lighting thread : Post all queries about automobile lighting here-1.jpg
LED only
Auto Lighting thread : Post all queries about automobile lighting here-2.jpg
Low beam
Auto Lighting thread : Post all queries about automobile lighting here-3.jpg
Low beam + LED
Auto Lighting thread : Post all queries about automobile lighting here-4.jpg
High beam
Auto Lighting thread : Post all queries about automobile lighting here-5.jpg
High beam + LED
Auto Lighting thread : Post all queries about automobile lighting here-6.jpg
It is not so apparent but the halogen is totally outclassed by the LED
As of this moment I have ordered a second one to be mounted on the left side
SunnyBoi is offline   (3) Thanks
Old 1st December 2014, 12:05   #8637
the13thtee's Avatar
Thanked: 59 Times
Have the above pictures been taken with just one LED lamp? Can you share a link of the same? as there are so many types of the cree leds online. Also I'll need to dis-assemble the speedo console to check and replace the bulbs on my Fazer. And yes the halogen are nothing compared to the LEDs.
Old 1st December 2014, 16:32   #8638
S_U_N's Avatar
Thanked: 418 Times
@SunnyBoi: Thank you for the pictures.
I see no easy option for those with scooters to mount such an LED.
Also, from the picture, the LED output is clearly that of a spotlight, which means we need at least two LED's to have some sort of 'spread'. Now, this means more wattage and more strain on the electronics.
Isn't it better to buy one of those LED strips available in the market?
S_U_N is offline
Old 1st December 2014, 16:53   #8639
SunnyBoi's Avatar
This id the spot light which I've bought :
http://www.ebay.com/itm/201158612638
There are LEDs for spread as well. Like the other variety I mentioned few posts ago.
Link for Spread LED : http://www.ebay.com/itm/191172687983
LED Strips don't give anywhere close to the light given by these lights.
BTW, this is H4 bulb on a HS1 beam.
Auto Lighting thread : Post all queries about automobile lighting here-img_20141130_145605.jpg
SunnyBoi is offline
Old 1st December 2014, 17:25   #8640
tsk1979's Avatar
Thanked: 23,484 Times
Sunny, it says 30W
I am quite surprised. Cree 30W array is expensive. Is it really 30W? Can you check the current draw? That will give us a fair idea.
tsk1979 is offline
