▲ Go to Top ▼ Bottom
Old 27th September 2016, 14:27   #1876
dhruvwali's Avatar
Thanked: 269 Times
Re: Hyundai Elite i20 : Official Review
Originally Posted by balachandran View Post
Osram NBU is a good bulb, actually in my vehicle it's H4 but not projector. The vision is very good. High beams you will really love it in highways . Stock bulb can't be compared with this one but life is very less. Don't forget to slide your light lever to off from auto.
Cheers.
When you say less life, how less are you talking about?
Also why turn it off from auto? so that it saves the number of hours it is on?
dhruvwali is offline
Old 28th September 2016, 18:58   #1877
Maverick1977's Avatar
Thanked: 929 Times
The front grill on my i20 looks quite dirty thanks to all the dust & fantastic road conditions in Mumbai. It in fact looks aged in the evening compared to what it looks in the morning after the wash. I tried all tricks in the book including some stuff which the 3M team applied. The effect hardly lasted for 2 days and I felt that it became a dirt magnet even more after that.
I was trying to find solutions and have 3 in my mind:
1. Remove the grill & get it painted. Problem is if the paint starts chipping off then it will make it look even more terrible.
2. Get a wrap. The issue here is 3M guys who are just not confident if the wrap would stay in place as the grill is a plastic product and will come off within a short time.
3, Replace the grill with a chrome one. I feel this is the better solution but I have a problem. Whilst this grill looks fab on a Red, Blue, White car it looks utterly boring on a silver car. Unfortunately my car is a Silver one and hence I am a bit confused on this front.
Is there any other solution that you guys can think of? Has any one put a wrap on the grill or installed a chrome one?
Hyundai Elite i20 : Official Review-chrome.jpg
Maverick1977 is offline
Old 28th September 2016, 21:25   #1878
hakunabatata's Avatar
Thanked: 86 Times
There will be no contrast if you put a silver grill on a silver car. I have found the stock grill to be the most visually appealing. Although that's just my personal taste.
You could alternatively get the grill powder coated to the color of your choice. This will be more durable than regular paint and probably wont chip that easily.
hakunabatata is offline
Old 28th September 2016, 22:43   #1879
Midas's Avatar
Thanked: 160 Times
Agree! Stock grills looks much better, especially for silver car.
If you still have the ones which you removed, fix it back if possible.
Midas is offline
Old 29th September 2016, 10:38   #1880
udainxs's Avatar
Thanked: 130 Times
I have seen aftermarket bumpers with mesh in them, rally style. Seeing the shape, I feel it may be possible to retrofit it on the stock bumper as well
udainxs is offline   (1) Thanks
Old 29th September 2016, 13:01   #1881
Thanked: 3,201 Times
Get the chrome grill, paint it black and it would look good
Karthik Chandra is offline   (2) Thanks
Old 29th September 2016, 15:07   #1882
Thanked: 929 Times
I completely agree with you on the contrast bit. The Black grill gives a very good appeal to the Silver car. My only issue is maintaining the grill. It looks so dirty especially in the rains.
I have not changed the grill. Doubt if I will be putting the chrome any time either.
The chrome grill is actually made of plastic, painting it is out of question. If I want to paint I will stick with the original.
Is there any other way to keep the grill clean? Some one suggested I apply tyre polish to it. What do you gents suggest?
Old 29th September 2016, 16:33   #1883
Thanked: 86 Times
The mesh pattern makes the grill difficult to clean indeed. I can understand your frustration as I've spent countless hours, armed with a toothbrush and soap, in cleaning the grill. But I've found it to be the best method yet.
All the liquids and waxes will only be temporary. One splash of muck and everything is back to square one.
hakunabatata is offline   (2) Thanks
Old 30th September 2016, 08:39   #1884
balachandran's Avatar
Thanked: 11 Times
Have you tried using chemical guys trim and plastic cleaner or meguries restore plastic gel? These are very good on any plastic and give you the original look. Even cleaning is very easy just spray jet water. Since these gels will give smooth and shiny surface which allows cleaning Very easy. But these gels are at higher side about 2000 to 3000 INR.
Cheers!
balachandran is offline   (2) Thanks
Old 30th September 2016, 13:58   #1885
Thanked: 334 Times
Hello guys,
Any idea about way to replace the led strip on left side mirror of i20 elite sportz? I have a 2014 model and there seems to be water inside the strip. Please share info about the cost for repairing.
I contacted the dealer in Nagpur and they suggested to change the entire mirror. I am sure there has to be a way around to replace the strip.
saurabh89 is offline   (1) Thanks
Old 30th September 2016, 18:42   #1886
Thanked: 11 Times
Originally Posted by saurabh89 View Post
Hello guys,
Water inside ORVM? It's not common about this. Usually happens in non genuine parts only. Your dealer is correct, opening and closing an ORVM may cause ill fitment. Try park you car in sun light whole day where it may evaporate. To my knowledge water inside ORVM may be a manufacturer defect also. Try replacing if you have warranty.
Cheers!
Old 30th September 2016, 19:05   #1887
cs_rajesh's Avatar
Thanked: 339 Times
hello friends.. facing unusually heavy vandalism by street dogs! Since I have to park one car inside the house (portico), the other car that comes in late, i.e. the i20, stands outside. The street dogs run amok over my whole color car every night, stamp and scratch with muddy feet. Plus, the long stick antenna was chewed off last night, don't know what's yet to come. I welcome any suggestions to avoid their vandalism. Also kindly suggest where can I buy genuine antenna stick as replacement, either online or some auto shop in whitefield bangalore (without visiting a hyundai dealer)?
cs_rajesh is offline
Old 30th September 2016, 19:43   #1888
Tojo_GotBhp's Avatar
Thanked: 405 Times
A car body cover should be a good solution, another possible solution would be the one suggested by benzinblut.
My solution was:
I bought a thick rubber sheet and pierced it with cobbler's nails to make a bed of nails. The nails need not be too close.
At night before going off to sleep, i got the car covered with thick blankets and placed this bed of nails on the boot and roof.
Due to the weight of the rubber sheet, it wont get easily dislodged due to the wind.
This solution worked for me. Hope this helps
PS: Piercing the nails into the rubber sheet gives a sore thumb.
Link to the thread: http://www.team-bhp.com/forum/street...-my-car-2.html
For the antenna: http://www.99rpm.com/hyundai/antenna-elite-i20.html
Tojo_GotBhp is offline   (1) Thanks
Old 3rd October 2016, 14:12   #1889
verma_rahul's Avatar
Thanked: 150 Times
Got my Elite i20 serviced on the 1st of October'16. It's a 2015 August Asta CRDI and the car was due for its 1st paid service (30,000 kms.).
I generally get the service done at an interval of ~8500 kms., hence this time it was due at 25,000 kms. Did not opt of engine de-carbonisation, engine lacquering etc etc which the SA recommended. No alignment/balancing as well at the service center. The bill came up to a mere 7130/- Got the balancing done outside for 400/-, (although it wasn't needed).
Got the stabilizer bar bush replaced and the car has become as good as new! There's one clatter sound that has started somewhere near the steering column in the cabin. Seems as if something is loose and making a sound while going over rough road but it could not be replicated for the SA to identify and fix. Is anyone else facing this issue? It is pretty much not the ABS thing which I am aware of since Day 1 of my ownership.
Rahul
verma_rahul is offline
Old 4th October 2016, 16:06   #1890
Thanked: 334 Times
I also got my i20 elite 2014 sportz vtvt model serviced at 32000 kms in Nagpur. I got all the fluids {engine oil, gear oil, brake oil} changed in the car except the coolant and also got a decarnonizer treatment done for the engine. I was experiencing lack of power for past few thousand kms and all of that is gone now.
Although, I have few doubts about the brake bleeding done. The brakes seem to be less responsive now.
The pickup is back and the little sound I had when the car was running is gone now. It's difficult to identify if the engine is running, when the car is idle and I live that!
The total bill was 13000. I always use synthetic engine oil. The manager at Ketan hyundai tried to sell me changing the spark plugs as well, but I didn't go for it.
Saurabh
