Old 15th June 2007, 07:51   #166
Mpower's Avatar
Thanked: 1,735 Times
Originally Posted by hellstar View Post
I chose the second option because they assured me that driving the car does in no way affect the rest of the machinery in the car in the current state that it is in. i am not very sure about this because the sound i hear when changing the gears is the sound of metal against metal. Could somebody here who is familiar with the internals of the transmission system elaborate more of the functionality of the synchronizer so that i can get a better hold of the issue ?
syncros help meshing of gears by equalizing rpms. if its making metallic sounds who know its could be throwing metal pices into the trans.
Just dont use the 5th gear till its fixed.
Mpower is offline
Old 15th June 2007, 10:31   #167
Do you get a metal to metal grinding or clashing sound, in that case, the output shaft might have been damaged when your axle came off, do not let Hyundai get away with this please.
Gurkha is offline
Old 15th June 2007, 11:07   #168
hellstar's Avatar
Thanked: 44 Times
hi @MPOWER and @GURKHA , please note that the sound is similar to the sound you will hear if you try to change gears without depressing the clutch. and the sound is heard only when i try to shift from the fourth gear to the fifth gear , the sound is heard and then the fifth gear engages, after this the vehicle performs as smooth as ever , without a trace of trouble. Sometimes the noise gets really bad and , the sound is believe me nothing short of heart wrenching . If metal pieces are being thrown i believe that the sounds would be heard always right ?
hellstar is offline
Old 15th June 2007, 12:40   #169
Sounds like bad sync rings, have em checked before more damage takes place, try double clutching and making the revs match, if the noise goes away, surefire case of bad sync rings. I would also like you to drain the tranny oil and look for tell tale signs of metal flecks, run a magnet through the drained oil, if you see flecks of metal, have your tranny serviced ASAP.
Gurkha is offline
Old 15th June 2007, 19:05   #170
hellstar's Avatar
Thanked: 44 Times
@ Gurkha thank you very much for the info , I am just about to leave back for home and gotta try out the double clutching part , will check this and then the tranny oil part! over the week end and keep checking my mail for any response from HMIL , before i take this to the next level.
hellstar is offline
Old 16th June 2007, 20:23   #171
hellstar's Avatar
Thanked: 44 Times
i tried out the double clutching and yeah it did work , so when i change to fifth gear now i double clutch, and there is absolutely no problem , but hell yeah i am not gonna live with this forever . I am still waiting for a response from HMIL
hellstar is offline
Old 19th June 2007, 09:41   #172
hellstar's Avatar
Thanked: 44 Times
I did not get a response from HMIL till now so i mailed them again and this time also marking a copy to all my friends who happen to work in other MNCs
hellstar is offline
Old 19th June 2007, 09:47   #173
pogusingh's Avatar
Sam
Did you get any feedback from HMIL
-POGU
pogusingh is offline
Old 20th June 2007, 12:09   #174
Sam Kapasi's Avatar
Thanked: 2,480 Times
This morning, the car was taken out and the same exact loud grating sound comes from the Axel.
It's happened again.
To say I am upset, would be an understatement. I've beeb informed by the HMIL office in Delhi, that Ashika SIngh no longer works for them.
I've been asked to get in touch with Mr. Shyam Menon from Mumbai office.
I was handed over his mobile number. However after many calls, he did not answer his phone. I recieved another number then from the delhi office, which was answered by the reception and I was informed that Mr. Menon is in a meeting and will call me back shortly.
I am currently waiting for his call.
The Verna is parked at home.
Sam Kapasi is offline
Old 20th June 2007, 12:13   #175
suman's Avatar
Thanked: 281 Times
This is unbelievable, bad news. Axels, gearbox problems, certainly not expected from Hyundai. What next Sam?
suman is offline
Old 20th June 2007, 12:17   #176
Rtech's Avatar
Thanked: 371 Times
Whoa! A one off incident can be forgiven. But a repeat? This is rubbish. Lets wait and see what they say this time.
Rtech is offline
Old 20th June 2007, 12:18   #177
Vid6639's Avatar
Thanked: 44,150 Times
This is ridiculous. They better replace the car. i wouldnt demand anything lesser.
Don't even settle for a new axle replacement.
I say get monetary compensation and buy a car which aint like a boat. Optra Magnum.
Vid6639 is offline
Old 20th June 2007, 12:19   #178
horsepower's Avatar
Sam, why don't you approach Autocar? You must be knowing them real well. I can see JBL advertisement in every issue.
horsepower is offline
Old 20th June 2007, 12:24   #179
spadival's Avatar
Thanked: 29 Times
Yepp.. better get the car replaced. Sounds like a serious manufacturing defect which cannot be repaired, atleast not permanently.
spadival is offline
Old 20th June 2007, 12:27   #180
appuchan's Avatar
Thanked: 27 Times
Hey guyz, me too getting scared now. Hell lot of problems reported for Verna. This is awful. Fortunately, my car is yet to follow suit. Dont know when it decides the other way!
Think I did a mistake by favouring Verna over that ugly, ubiquitous NHC.
appuchan is offline
